MC34063(NE555)
24 posts / 0 new
Hai All
This thread related to
Probably this simple way to create the DC-DC converter.Since no NE555 as step-up converter.
Cause the HVPP/Parallel programmer only need HV(11.5-12.5 VDC) and required small current only.
As replacement for MC34063 for AT89X programmer with "USB"(only 5 VDC from USB for power supply).
buckboostconv
Above picture is NE555 DC up converter.
Micro-CAP didn't had MCU simulation,So I used on NE-555 and Signal sources to replaced the MCU.
Did someone also already made this DC up converter ? Any info will be appreciated.
www.tokopedia.com/madagang for cheap electronics and manuscript
Search for voltage doubler / trippler circuit, ARRL handbook perhaps!
Keys to wealth:
If you want something you've never had...
...you must be willing to do something you've never done!
Lets go Brandon!
I already read at ARRL but non of that equal.At chapter power supply(for tubes).
The concept is the same, feed in an AC signal, and capture the peaks to boost the voltage up, the more diodes/caps, the higher the voltage.....
duplicate this x2 circuit for x3, x4, x5......
Your circuit is x3, so 5v becomes 15v, then zener regulates back to 12v needed for programming.
edit:  added circuit
Keys to wealth:
Lets go Brandon!
Thank’s Ki0bk but look at the P1 and P2 also the entire schematic.
Keys to wealth:
Lets go Brandon!
Cockroft and Walton called; they want their multiplier back!
Neil
Why not simply use a very low cost/low current booster?
https://www.onsemi.com/pdf/datas...
Another option.Where Exactly  we could found the Chip ?
Good Ol' Pete has ideas:              ChargePumps
A Hex inverter may be worth experimenting with. I have 74hc14n
Brawndo's got what plants crave... It's got electrolytes!
I used AT89 and NE555.yes
13 volts for older PIC
+5v to +12v converter by Roman Black
I was contacted by hobby PIC programmer legend Myke Predko about designing a simple and cheap circuit to produce the 13v Vpp voltage needed to program PIC chips from a standard 5v regulated supply. This would eliminate the need for an smps 13v converter chip.
The NE555 gebnerated the pulse then microcontroller pin added the ~5 VDC pulse to made the other micro's in program mode(11.5-12.5 VDC).
Do you know an estimated maximum value of this small current?
Basically nothing, not even 1 ma drawn by the HV reset pin.  There may be loading elsewhere, if you have other things on the pin.   Put your bus bars away!
Think a little about a chip security. If you do, then Vin will be 15V any you will use a 12V regulator.
Of course, you can try any petty multiplier, perhaps it will work.
At the Attachment
How you intend to meet this requirements, ie. to hit the right voltage?
Multipliers are notorious high voltage on no current, but drop dead quickly on any current.
I heard of a tippler that uses NE555. I drew it on LTspice as an example which could be another useful option for the case in question on this thread.
Note:
The Add Media button is not displayed on my editor toolbar. Also, copy then paste on the message window didn't work.
* Allow me Kerim. Ross *
See: https://www.avrfreaks.net/forum/image-cut-and-paste-broken-again
Note:
Package icon SuppX3_01-12V-3mA.zip
yes Little bit similiar
Thank you Ross for posting the attached circuit (post #20).
I searched and read some of your recent jokes though I didn't comment.
(Note: Ross is valusoft)
yes
