Cheap sine wave, and DAC
32 posts / 0 new
Moderators, please post this to a more appropriate group if necessary. * Done. *
I've seen a few posts here about generating a sine wave from an AVR. These usually include a look-up table in flash and a DAC chip.  I'm using an Atmega128 at 16MHz.
1) If you don't need a perfect sine wave, but just want an audio tone output which isn't clipped, you can put a two-stage R/C filter on the output pin of a timer, say TIMER3_COMPA.  The output of the R/C filter will give an approximation of a sine wave for audio purposes.
2) A cheap SPI DAC can be made from a Microchip MCP4261, which has two digital potentiometers.  It can be accessed at 10MHz and requires no external components, though I put an Op Amp voltage follower after my wipers.
These two suggestions are not related; I'm not suggesting audio over DAC.
The comma in the title is an Oxford comma.
I can supply code and schematics if anyone is interested.
Was there a question in that, or did I just miss it?
FF = PI > S.E.T
No question, I just thought I'd share what I learned during my project.
If there is any interest in making a dual 256-bit SPI DAC for a couple of AU$, or a nice-sounding audio output for just a few lines of code and a dollar, I can post my tested code and schematic.
If my posting is inappropriate in some way, I can remove it.
I'm only trying to be helpful.
Peter
Could you quantify that?
What frequency range is achievable? What sample rate?
It sounds like it'd be a lot of work for the processor as it's going to have to be constantly updating the wiper position(s) at the sample rate.
How does it compare to PWM - which is probably the more "conventional" approach?
I think you or I may have caused confusion.
I'm offering a solution to a nice sinewave-ish output, and the DAC suggestion is a separate thing.
I'm not offering a solution to audio over DAC; that's not implied in my post.
I'm sorry if you inferred that.
Peter
Thanks for the clarification - I wasn't sure.
But the questions/comments still stand:
What frequency range of the sinewave is achievable? What is the step rate?
It sounds like it'd be a lot of work for the processor as it's going to have to be constantly updating the wiper position(s) at the step rate.
Total votes: 2
Perhaps if the OP just posted the code and schematics people could make up their own mind?
Peter
Are you aware of Atmel's application note AVR335 ? Aer you proposing something different to that? It shows how to add a filter to the output of a timer PWM to "smooth" the signal.
AVR335: https://community-storage.elemen...
specifically this bit...
He's just talking about a single sinewave; eg,
EDIT
Diagram stolen from here: http://www.learningaboutelectronics.com/Articles/Square-to-sine-wave-converter-circuit.php
in #1, George and Mildred wrote:
Microchip MCP4261
in #3, George and Mildred wrote:
256-bit (sic?) SPI DAC
The MCP4261 is an 8-bit pot - giving 256 steps.
I have a lot of time for people who ask sensible questions.
 0 to 15,00 at lest, without interrupts.
If you had read my posts you'd realize I'm not suggesting audio over DAC.
Just a few lines of C to turn it on and off, set the frequency and use the output pin as an analogue input to test the volume.
Look folks, I'm just offering a few lines of code and a few dollars of hardware.
If you want to flame me, I'll just sit by and let you do it.  It doesn't really bother me, I just thought my post would be of interest.
peter
Yes.  It doesn't need all that crap.
Yes.  My job here is done thank you.
Peter
Was there a typo there? Is that frequency of the sinewave, or the step rate (ie, update rate of the pot) ?
I have and I do - but the observation still stands.
What you're doing, I presume, is updating the wiper position to give you the steps to approximate a sinewave:
So, at every step, you have to write to the pot to update it - and that sounds like quite a lot of work for the processor.
EDIT: fair enough, (probably) no more work than updating a DAC at each step.
We're not trying to flame you - just get a clear idea of what you're suggesting/offering.
As Brian said, posting the code & schematic should make it all clear ...
Peter,
Please upload your schematic and the source code. I am interested.
Cheers,
Ross
Ross McKenzie, Melbourne Australia
Hum.
I'm not. Please do me a courtesy and read my posts.
Pots and audio are separate; I have made this clear.  Your presumption is incorrect.
I'm frankly getting tired of this thread.
Peter
I believe everyone here is an expert on my subject so I'll just exit stage left.
What a wonderful day it has been sharing an idea with everyone.
Peter
Hi Peter, I think people are interested but you haven't actually shared anything. That information vacuum has simply prompted people to speculate, sometimes incorrectly.
That. ;-)
(we can only guess at what you are talking about/suggesting until something is actually presented - I suspect this post started life on the tail end of something else which might have explained more context which we are not missing as the thread has been split off).
You have our interest as witnessed by the questions, will you please post the these items.....
FF = PI > S.E.T
to answer my own question
 MCP4261 ... can be accessed at 10MHz
that's the SPI max clock (at 5V).
Write command seems to be 16 bits, so max update rate ~ 625kHz (or somewhat less, as there's some delays required after CS is asserted, and before it's released)
There are 8-bit commands for increment/decrement, so could go faster in cases where they could be used.
You should get some of these I2S DAC ICs:https://www.ebay.com/itm/1916742...
16-bit dual serial DAC CD-audio quality for less than $1 each.  Why fool around with software waveforms?
But no AVR has I2S so you would have to bit-bang it?
Simonetta wrote:
CD-audio quality
I think George & Mildred may have hinted that he/she/they aren't actually talking about audio - "CD-Quality" or otherwise.
but here's the thing:
I fear I have been misled by the (multiple) use of the word "audio" ?!?
I really would like to see some more details in this thread to get some idea about what we can only just speculate about so far!
OP's first suggestion was fairly clear until the end of its second sentence.
"for audio purposes" seems to have driven some off the deep end.
In this case, "audio" just means relating to sound,
not multi-channel high fidelity audio equipment.
OP's other suggestion might require more detail,
but I expect those details are in the Microchip MCP4261 spec sheet.
Everyone here knows how to use SPI, correct?
OP should post the offered code and schematics.
The code and schematics for OP's first suggestion should be in one post.
The code and schematics for OP's second suggestion should be in a separate post.
I really do not understand why posters on this thread are determined to conflate the two suggestions.
OP explicitly stated that the two suggestions are separate.
The questions assuming otherwise seemed to have caused an understandable frustration.
I think that part was added later - it wasn't in the original OP ...
or SPI (create codec frame signal from SPI clock and a port bit)
Interfacing an I2S Device to an MSP430 Device - slaa449a.pdf (Texas Instruments)
[mid-page 6]
6 Conclusion
...  and can be implemented simply and inexpensively using a 4-bit counter, a 'D' type flip-flop, and a dual inverter gate.
The conflation continued after 6:14 AM,
but that probably just shows why one should not edit posts for more than tipos and such.
edit: the "and such"es should probably be labeled.
would be much clearer to say
 or a nice-sounding sinewave output for just a few lines of code and a dollar
That seems to be what momentarily sent things hurtling off the train track.
A nice offer & gesture that unfortunately landed in the ditch of history.
hmmm ???
https://en.wikipedia.org/wiki/Ge...
As Peter has left the room there appears to be little or no benefit in continuing with endless speculation.
The key is in the lock. If Peter wants it unlocked, he can PM me.
Ross (Moderator)
Topic locked
