avrdude 6.4 missing libhidapi-0.dll
6 posts / 0 new
Hi everyone,
I am trying to use my USBasp avr programmer to program the Atinny202.  Unfortunately, Avrdude 6.3 doesn't support it, so
I had to download Avrdude 6.4, which is generating a missing libhidapi-0.dll error.
Does anyone know where I can find this .dll?  Or has someone run across this issue?
A second question, which pins on the Atinny202 should I be using to program it?
By the way, I am using Atmel Studio 7 as the IDE.
Neil
Don't cross post!
Mod, lock this thread!
 My bad, two similar posts about the same thing!  Sorry
and Welcome to AVRFreaks!
FF = PI > S.E.T
Looks like it only uses the Reset pin 6 and VCC/GND of course but you need to have a read of the following in the datasheet "30. Unified Program and Debug Interface (UPDI)  "
 as it need 12V it seems.
The USBasp only does ISP programming, not UPDI, IIRC!
Take a look at a SNAP programmer/debugger for a low cost tool for UPDI chips.
FF = PI > S.E.T
https://github.com/mariusgreuel/...
Maybe you can find an avrdude build that is statically linked to that lib?
But check inside the compressed file in this link:  https://packages.msys2.org/package/mingw-w64-x86_64-hidapi
It seems to use an uncommon compression format, but I think this will open it:  https://mcmilk.de/projects/7-Zip-zstd/
But anyways, you have a bigger problem: USBasp doesn't support UPDI, so you can«t program the tiny202 with it.
