Hello. I'm waiting for some servos I ordered to come and I thought I would better use this time I have untill
they come to do something for educational sake.
So I wrote a software PWM implementation using Timer0 of Atmega8 because that timer lacks many features.
I defined some constants:
const float OVF_IN_1_SEC = F_CPU/256; const float SERVO_MIN = 1.0; // ms const float SERVO_MIN_IN_OVF = SERVO_MIN * OVF_IN_1_SEC / 1000; const float SERVO_NEUTRAL = 1.5; // ms const float SERVO_MAX = 2.0; // ms const float SERVO_MAX_IN_OVF = SERVO_MAX * OVF_IN_1_SEC / 1000; const float PRECISION = (float)1000 / ( (float)F_CPU / 256 ); // 1 s = 1000 ms; F_CPU / 256 = how many times it overflows per second; PRECISION tells you how much time passed since last overflow :) const float SERVO_FREQUENCY = 20; // ms const float SERVO_FREQUENCY_IN_OVF = SERVO_FREQUENCY * OVF_IN_1_SEC / 1000;
- OVF_IN_1_SEC represents how many times Timer0 overflows in 1 second without a prescaler (1)
SERVO_MIN_IN_OVF represents how many times Timer0 overflows in SERVO_MIN ms
SERVO_MAX_IN_OVF represents how many times Timer0 overflows in SERVO_MAX ms
PRECISION represents the time between overflows
SERVO_FREQUENCY_IN_OVF represents how many times Timer0 overflows in SERVO_FREQUENCY ms
void printInfo() { cout << "F_CPU = " << F_CPU << endl; cout << "OVF_IN_1_SEC = " << OVF_IN_1_SEC << endl; cout << "SERVO_MIN = " << SERVO_MIN << endl; cout << "SERVO_MIN_IN_OVF = " << SERVO_MIN_IN_OVF << endl; cout << "SERVO_NEUTRAL = " << SERVO_NEUTRAL << endl; cout << "SERVO_MAX = " << SERVO_MAX << endl; cout << "SERVO_MAX_IN_OVF = " << SERVO_MAX_IN_OVF << endl; cout << "PRECISION = " << PRECISION << endl; cout << "SERVO_FREQUENCY = " << SERVO_FREQUENCY << endl; cout << "SERVO_FREQUENCY_IN_OVF = " << SERVO_FREQUENCY_IN_OVF << endl; }
After that I created a class "Object" that represents a servo.
class Object { public: inline Object() : m_duty(SERVO_NEUTRAL), m_port(0), m_pin(0), m_expired(1) { } inline ~Object() { } inline void setDuty( float duty ) { if(duty >= SERVO_MIN && duty <= SERVO_MAX) m_duty = duty; else { m_duty = 0; setLow(); } } inline float getDuty() { return m_duty; } inline void setExpired( volatile uint8_t expired ) { m_expired = expired; } inline uint8_t isExpired() { return m_expired; } inline void setOutput( volatile uint8_t *port, uint8_t pin ) { m_port = port; m_pin = pin; } inline void setHigh() { bit_set(*m_port, BIT(m_pin)); } inline void setLow() { bit_clear(*m_port, BIT(m_pin)); } private: float volatile m_duty; // in ms volatile uint8_t *m_port; volatile uint8_t m_pin; volatile uint8_t m_expired; };
then an Objects manager called "ObjectsVector"
class ObjectsVector { public: inline ObjectsVector() : m_list(0), m_length(0), m_maxLength(0) { } inline ~ObjectsVector() { if(m_list) free(m_list); } inline void init( uint8_t maxLength ) { m_maxLength = maxLength; if( (m_list = (Object**)malloc( m_maxLength * sizeof(Object) )) == NULL ) m_maxLength = 0; } inline uint8_t add( Object *object ) { if( m_length < m_maxLength ) { m_list[m_length++] = object; sort(); return FALSE; } else return TRUE; } /*inline Object *getHead() { return m_list[0]; } inline Object *getTail() { return m_list[m_length]; }*/ inline Object **getList() { return m_list; } inline uint8_t getLength() { return m_length; } inline void sort() { if(m_length == 1) return; for(i = 0; i < m_length - 1; ++i) for(uint8_t j = i + 1; j < m_length; ++j) { if ( this->getList()[i]->getDuty() < this->getList()[j]->getDuty() ) { Object * temp = this->getList()[i]; this->getList()[i] = this->getList()[j]; this->getList()[j] = temp; } } } private: Object **m_list; uint8_t m_length; // m_index-1 is the last one added ;) uint8_t m_maxLength; // max length }; void softwarePWM(); extern ObjectsVector myList;
and the implementation of SoftwarePWM()
// the list must be sorted from the highest duty to the lowest ObjectsVector myList; //todo: put the ++Timer0_OVF_Counter at the very beginning of the softwarePWM then compare everything to value+1 void softwarePWM() { static float time_passed = 0; static uint16_t Timer0_OVF_Counter = 0; if(Timer0_OVF_Counter == 0) // we are starting again :) { for(i = 0; i < myList.getLength(); ++i) if ( myList.getList()[i]->getDuty() ) { myList.getList()[i]->setHigh(); myList.getList()[i]->setExpired(0); } //return; } //if(Timer0_OVF_Counter >= 62 && Timer0_OVF_Counter < 125) if(Timer0_OVF_Counter >= SERVO_MIN_IN_OVF && Timer0_OVF_Counter <= SERVO_MAX_IN_OVF) // ONLY if we are between SERVO_MIN - SERVO_MAX, there is no point to check SERVO_MAX - SERVO_FREQUENCY ms, everyone should be "sleeping" already :) { //time_passed = Timer0_OVF_Counter * 0.016; time_passed = Timer0_OVF_Counter * PRECISION; for(i = 0; i < myList.getLength(); ++i) { if( !myList.getList()[i]->getDuty() ) continue; else if( myList.getList()[i]->isExpired() ) break; // because our list is ordered from the highest to the lowest, if we found one that is expired, everyone after him should be expired else if( time_passed >= myList.getList()[i]->getDuty() ) { myList.getList()[i]->setLow(); myList.getList()[i]->setExpired(TRUE); } } //return; } // if(Timer0_OVF_Counter == 1250) // 20 ms passed! reset :) if(Timer0_OVF_Counter == SERVO_FREQUENCY_IN_OVF) // SERVO_FREQUENCY ms passed! reset :) Timer0_OVF_Counter = 0; else ++Timer0_OVF_Counter; }
ObjectsManager sorts the list of servos like this: the one with the highest duty is the first, and the one with the lowest duty is the last.
(I know, I have a bug, if you modify the duty, the list can become unsorted. )
When a period of SERVO_FREQUENCY starts, Timer0_OVF_Counter is 0 and SoftwarePWM() puts every Object to high (setHigh()) and expired to 0. After that if we are between SERVO_MIN_IN_OVF and SERVO_MAX_IN_OVF it checks to see if an object has used its time, if it did, it sets it as expired (setExpired(1)) .
SoftwarePWM() is called here:
SIGNAL( TIMER0_OVF_vect ) { if( Timer0::_timer0OvfHandler ) Timer0::_timer0OvfHandler(); }
and here is my test program:
int main() { DDRB = 0b11101110; //PB4 = MISO DDRC = 0b11111110; // DDRD = 0b11110000; //PORTD (RX on PD0) //wdt_enable( WDTO_1S ); //adcInit(); //adcSetPrescaler(ADC_PRESCALE_DIV128); UART::Init( 0, 9600 ); unsigned float duty = 1.5f; Object led; led.setDuty( duty ); led.setOutput( &PORTC, 1 ); myList.init( 3 ); myList.add( &led ); Timer0::init( TIMER0_CLK_DIV1 ); Timer0::attachHandler( softwarePWM ); uint8_t c = 0; //wdt_reset(); for( ;; ) { //wdt_reset(); /*if( adcConvert10bit(0) < 500 ) bit_set(PORTC, BIT(1)); else bit_clear(PORTC, BIT(1));*/ bit_set( PORTB, BIT(1) ); if( (c = UART::getByte()) ) { (void)printf( "code = %c\n", c); /*if(c == '1') { (void)printf( "ADCH = %i\n", adcConvert10bit(0) ); }*/ if( c == '2' ) { duty += 0.1f; led.setDuty( duty ); } else if( c == '3' ) { duty -= 0.1f; led.setDuty( duty ); } else if( c == '4' ) { led.setDuty( 0.0f ); } UART::sync(); } } return 0; }
As you can see, I don't have a servo yet, so I tested it on a LED. It works okay, but my space is very limited on Atmega8 and I need some help in making the code lighter(I'm not a professional programmer, as I bet you saw that already) because it takes 99.8% flash space ( Program: 8172 bytes (99.8% Full) )
Thanks in advance,
reSpawn.
