I am using the SAMD21 Xplained Pro board with an ATWINC3400 expansion on expansion port 1. I am attempting to connect to an enterprise wifi network (MSCHAPv2) using the example project that is provided by Atmel/Microchip (called WINC3400_SECURITY_ENTERPRISE_NETWORK_MSCHAPV2_EXAMPLE). The only changes I have made to the code is to add a username/password where necessary for the wifi connection. All the setup code is running fine, and then I attempt to actually make the wifi connection. After making the attempt, the wifi_cb function receives a message with a value of 34, and I am not sure how to interpret this message. According to the documentation, this is not even a value that should ever be passed into this function.
For reference, "wifi_cb" is the callback function that is defined in code to fulfill the role of this function pointer found in m2m_wifi.h:
typedef void (*tpfAppWifiCb)(uint8 u8MsgType, void *pvMsg);
According to the documentation, the following values can be passed in for u8MsgType:
@param[in] u8MsgType
Type of notification. Possible types are:
- @ref M2M_WIFI_RESP_CON_STATE_CHANGED
- @ref M2M_WIFI_RESP_CONN_INFO
- @ref M2M_WIFI_REQ_DHCP_CONF
- @ref M2M_WIFI_REQ_WPS
- @ref M2M_WIFI_RESP_IP_CONFLICT
- @ref M2M_WIFI_RESP_SCAN_DONE
- @ref M2M_WIFI_RESP_SCAN_RESULT
- @ref M2M_WIFI_RESP_CURRENT_RSSI
- @ref M2M_WIFI_RESP_CLIENT_INFO
- @ref M2M_WIFI_RESP_PROVISION_INFO
- @ref M2M_WIFI_RESP_DEFAULT_CONNECT
- @ref M2M_WIFI_RESP_ETHERNET_RX_PACKET (If Bypass mode is active)
- @ref M2M_WIFI_RESP_WIFI_RX_PACKET (If monitoring mode is active)
The integer value of 34 (the value that my function is receiving as a message) does not match any of those possible values as defined by the documentation. Therefore, I am at a complete loss for what is going wrong with my program.
I have tried my code with firmware versions 1.2 (it had a 2017 build date and it came stock on the WINC3400), 1.3.1 (it has a June 2019 build date), and 1.4.1 (It has an Oct 2020 build date).
Any suggestions on how I can figure out what is going wrong?
[edit]
After some further research, it looks like the value 34 corresponds to M2M_WIFI_RESP_BLE_API_RECV. Has anyone experienced this issue? Any suggestions?
A similar issue was posted by another user last year, but no one responded to his post with an answer: https://community.atmel.com/foru...
[/edit]
