Hi All
I have recently started using Git for my backups in terms of version control.
Visual Studio has an inbuilt plugin got Git.
Is there any way to enable this also on AVR Studio ?
Hi All
There's an git extension. Git Source Control Provider
I will give this a go.
Will the effect anything on Visual Studio ? As there already GIT integrated.
I just need this for AVR studio
AVR studio
Do you mean Atmel Microchip Studio?
personally, I just use Git (or whatever) at the file system level - so don't have to worry about integrating it into each tool that I use.
If you like a graphical interface, there's things like Tortoise Git: https://tortoisegit.org/
Yes, sorry Microchip Studio. I am running a local server with Gitea. Which has go templet called Atmel Studio, but maybe this is referring to AVR studio 6.
Yes I can use a terminal command, but thought if i can have something similar to what I have on VS for my C# projects then it would be good.
With SVN I could maybe understand why you might want to version control from within the IDE but with git I wonder exactly what git functions benefit from being done inside the IDE
(having said that I do love the fact that inside VS2017 it's so easy to "git blame" a file and find out who has really screwed things up and the reasons they gave in the commit for doing so!)
A Visual Studio 2015 extension will likely work in Microchip Studio 7; otherwise, the Microchip Studio 7 extension.
Microchip Gallery | Packages matching git
Source Control | Microchip Studio
The vsix file has specific versioning embedded. I've gone in and modified the file to include other versions but in most cases was unsuccessful.
Just to confirm was it unsuccessful go VS2015
If so I can stick with Microchip version
Wrangle :
AS7 updating gallery and ASF | AVR Freaks
Viewing CR, LF, and CRLF inside Atmel Studio's Editor? - SOLVED | AVR Freaks
Installing a generic Visual Studio extension | AVR Freaks
adding an extension not in the Studio gallery | AVR Freaks
Microchip Gallery | Packages (Microchip Studio extensions)
I stand corrected. Nice script!
