what is wrong with my two pwm and adc sketch for atmeg4809 {SOLVED}
14 posts / 0 new
the idea is to control the brightness of two LEDs independently, this issue is that both potentiometers control both lights
#include <avr/interrupt.h>
void main(void) {
    SREG = 0b10000000; //enable global interrupts
  PORTA.DIR = 0b111; //set output pins for the pwm
    TCA0.SINGLE.CTRLB = 0b1110011; //enables compare channel and
    TCA0.SINGLE.PER = 0x3FF; //set period
    ADC0.CTRLC = 0b1010000; //set sample capacitance for above 1 volt and set the reference to VDD
    ADC0.CALIB = 0b1; //this is recommended for peripheral frequencies above 1.5 MHz
    ADC0.INTCTRL = 0x1; //allow interrupts on this peripheral
    TCA0.SINGLE.CTRLA = 0x1; //enable the timer
    ADC0.MUXPOS = 0x0; //set the starting analog input at port d pin 0
    ADC0.CTRLA = 0x1; //enable the adc
ADC0.COMMAND = 0x1; //star a conversion
    while(1){
ISR(ADC0_RESRDY_vect)
    switch (ADC0.MUXPOS){
            case 0x0:
                TCA0.SINGLE.CMP0 = ADC0.RES;
                ADC0.MUXPOS = 0x1;
                break;
           case 0x1:
               TCA0.SINGLE.CMP1 = ADC0.RES;
               ADC0.MUXPOS = 0x0;
               break;
  ADC0.COMMAND = 0x1;
Corrected word in title and code blocked application - JGM
Sorry, but I only read as far as this:
Don't write directly to SREG when programming in C. It can have unpredictable results, since you are changing all the flags - you are setting the interrupt flag, but clearing all the others.
Use
sei();
instead (it's defined in <avr/interrupt.h> ).
thanks for the tip and ill make sure to use it from now on but nothing changed
Which pins of Port A?  THeres 8 of them.
THeres quite a bit that you need to fix in MAIN loop.  Much of it only needs to be run once, and that should be in an INIT loop thats only run once.
Are you using the Arduino environment, or the Studio environment?  Sketches are done in Arduino predominntly
JIm
Also don't enable the interrupts at the start of your initialization . Make sure all interrupting peripherals are fully initialized and only THEN enable the interrupt system.
@Moderator: perhaps the word "two" is better than "dual"- can you correct the title.
"dual" would be fine, but it actually says "duel" - which is something completely different
...total of 29 hits in Forums search- dangerous word it is. Word two can be better, guess.
I made a few 'tweaks' to the OP.
Now, onward.....
So what investigation / testing / debugging have you done to find out what's going on ?
As always, break the problem down into manageable chunks - don't try to do multiple things all at once.
For a start, leaving aside any PWM, are you able to separately read 2 pots?
At first glance I don't see any errors.
On the AVR-0/1 series, interrupt flags in general need to be cleared explicitly inside the ISR by writing a "1" to the flag bit. However, the ADC is an exception and reading the result also clears the interrupt flag. It should be ok the way you did it.
This means I would need to setup a test (I do have a few DIP mega4809 somewhere) and now it's a bit late around here. Maybe tomorrow.
after messing around with the code a bit i finally got it to work, thank you for your help
void main(void) {
    TCA0.SINGLE.CTRLB = 0b1110011; //enables compare chanle and
    ADC0.CTRLC = 0b1010000; //set sample capacatnce for above 1 volt and set the refrince to VDD
    ADC0.CALIB = 0b1; //this is recomended for periferal fequincies above 1.5 mhz
    ADC0.INTCTRL = 0x1; //allow interupts
     sei(); //enable global interupts
    while(1){
    int in_1;
    int in_2;
            case 0x0:
                in_1 = ADC0.RES;
                TCA0.SINGLE.CMP0 = in_1;
                ADC0.MUXPOS = 0x1;
                in_1 = 0;
                break;
           case 0x1:
                 in_2 = ADC0.RES;
                TCA0.SINGLE.CMP1BUF = in_2;
                ADC0.MUXPOS = 0x0;
                in_2 = 0;
                break;
  ADC0.COMMAND = 0x1;
See Tip #1 in my signature, below, for how to properly post source code - as Jim did to your initial post.
Also Tip #5 for how to mark a thread as solved - no need to edit the title:
sorry, I'll do that next time
