The €40 Arduino
7 posts / 0 new
Celebrating 10 million Unos (and presumably just "official ones") you can order a special anniversary memento...
https://store.arduino.cc/products/uno-mini-le
The one on the right...
Now market will flood with it's clones.
“Everyone knows that debugging is twice as hard as writing a program in the first place. So if you're as clever as you can be when you write it, how will you ever debug it?” - Brian W. Kernighan
“Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away.” - Antoine de Saint-Exupery
The pins looks like 1.27mm spacing instead of 2.54mm of the original. Might be a problem for the regular dupont cables.
Also now it has actual crystal instead of resonator.
Posts on Twitter were suggesting you could get these as a Christmas stocking filler so they must be expecting stocks to be available imminently.
I was thinking of getting my wife a wooden leg for Christmas.
Not her main present, of course - just a stocking-filler ...
a wee bit in stock with a lot more ETA tomorrow 19 20-Jan'22
UNO Mini Limited Edition - Arduino | Mouser
