Total beginner, change state of outputrs in this code? (Resolved, thanks)
11 posts / 0 new
I have some code that allows my Arduino Uno and Ethernet Shield to change the state of 4 relays over my hard wired ethernet. I have this working fine but the four relay module I have does not allow jumpering to change the inputs from high to low when changing whether a relay energises or not. I did not write this code, it's something from A N Other.
So when I graphically press a relay button on screen from off to on the relay changes from energised to de-energised.
I want to reverse this in the code, so when a button shows OFF the relay is NOT energised, for each of four relays individually, and each relay module LED is OFF when each button shows OFF.
I hope I have made this fairly understandable? I am totally new to this and it probably shows :)
I also hope zipping the .ino file is acceptable, thanks for any help in modifying the code.
Best regards, Chris Wilson
Thee are 252 files there, can you reduce the number, please!
in the INO file, change this:
// checks if received HTTP request is switching on/off Relays
// also saves the state of the Relays
void SetRelays(void)
    // Relay 1 (pin 6)
    if (StrContains(HTTP_req, "Relay1=1")) {
        Relay_state[0] = 1;  // save Relay state
        digitalWrite(6, LOW);
    else if (StrContains(HTTP_req, "Relay1=0")) {
        Relay_state[0] = 0;  // save Relay state
        digitalWrite(6, HIGH);
    // Relay 2 (pin 7)
    if (StrContains(HTTP_req, "Relay2=1")) {
        Relay_state[1] = 1;  // save Relay state
        digitalWrite(7, LOW);
    else if (StrContains(HTTP_req, "Relay2=0")) {
        Relay_state[1] = 0;  // save Relay state
        digitalWrite(7, HIGH);
    // Relay 3 (pin 8)
    if (StrContains(HTTP_req, "Relay3=1")) {
        Relay_state[2] = 1;  // save Relay state
        digitalWrite(8, LOW);
    else if (StrContains(HTTP_req, "Relay3=0")) {
        Relay_state[2] = 0;  // save Relay state
        digitalWrite(8, HIGH);
    // Relay 4 (pin 9)
    if (StrContains(HTTP_req, "Relay4=1")) {
        Relay_state[3] = 1;  // save Relay state
        digitalWrite(9, LOW);
    else if (StrContains(HTTP_req, "Relay4=0")) {
        Relay_state[3] = 0;  // save Relay state
        digitalWrite(9, HIGH);
to this:
    // Relay 1 (pin 6)
    // Relay 2 (pin 7)
    // Relay 3 (pin 8)
    // Relay 4 (pin 9)
AND:
Change:
 // **********  button Relay states
   // Relay1
    cl.print("<Relay>");
    if (Relay_state[0]) {
        cl.print("on");
    else {
        cl.print("off");
    cl.println("</Relay>");
 // Relay2
    if (Relay_state[1]) {
        cl.print("on");
    else {
        cl.print("off");
	// Relay3
    if (Relay_state[2]) {
        cl.print("on");
    else {
        cl.print("off");
    // Relay4
    if (Relay_state[3]) {
        cl.print("on");
    else {
        cl.print("off");
    cl.print("</inputs>");
TO:
   // Relay1
        cl.print("off");
    else {
        cl.print("on");
 // Relay2
        cl.print("off");
    else {
        cl.print("on");
	// Relay3
        cl.print("off");
    else {
        cl.print("on");
    // Relay4
        cl.print("off");
    else {
        cl.print("on");
UNTESTED, but should do the trick
JIm
I apologise, but I am not sure what you mean, I just zipped up the whole .ino file, is that not how i should post it?
<SNIP>
JIm
Thanks a lot Jim, I loaded it but now all relay buttons show ON and I am unable to toggle their state. I may be able to get a relay module where I can jumper the inputs from ON with HIGH to OFF with HIGH, which might be easiest :) I appreciate your help.
Restore the original code for the second part....
you just needed to change the state of the relays, not how they display...
Flyover Jim
Keys to wealth:
Lets go Brandon!
Flyover Jim
Thanks, that's done the trick! I did get an error issue, something like stray \357 in program
Maybe because I used Windows Notepad to edit the .ino? I tried afresh using Notepad++ to edit the original,
and it loaded OK.
Many many thanks, I'll keep both .ino files so I can run the original on relay modules with reversible inputs.
For future reference, how should I upload .ino files correctly please?
I only saw one file in your ZIP upload so I do not know what GHROTE is upset about.
jgmdesign wrote:
I only saw one file in your ZIP upload so I do not know what GROHOTE is upset about
Sorry, one of "those" days... apologies for "252".
When I am opening .zip it actually pop-up WinRAR, and it resulted in 252 files.
I will change it in Firefox, from now on, the file .zip will be associated with Total Commander.
I'm back again, please forgive the noise :) If I power off the Arduino Uno (currently powered via its USB port to my PC) by unplugging the USB cable, when I power it on again by plugging the USB cable back in all relays go to ON, whatever their state at power down, which could be a problem.
Is this a facet of the code or a quirk of the Arduino itself? With Windows PC's with true serial ports I have had issues with Windows toggling the ports on boot up, a known and apparently insurmountable issue with Windows. Thanks, I'll be going to bed soon, so peace will reign ;)
EDIT: Scrub this question, I found the French comment:
/ init : je mets toutes les pins à l'état haut car transistor vers relais inverse l'état
and changing HIGH to LOW now forces the Arduino to fire up with the relays de-enegised, which is what I want. Thanks.
No worries, being utterly new to this and the accepted ways to post code I naturally assumed I'd made a faux pas, Please don't apologise, I too have "those days". Lots of them... :)
