Problem ssh:ing into a Linux machine
9 posts / 0 new
I have a device running a Linux system that I am having issues SSHing into. It keeps refusing all of my attempts. I can connect to the device through a serial cable and do some debugging.
On the client side I did a tcpdump and got the following when trying to SSH into the device:
11:33:35.205600 IP [my computer] > [the_device]: Flags [S], seq 2666683521, win 64240, options [mss 1460,sackOK,TS val 2735211423 ecr 0,nop,wscale 7], length 0
11:33:39.237315 IP [my computer] > [the_device]: Flags [S], seq 2666683521, win 64240, options [mss 1460,sackOK,TS val 2735215455 ecr 0,nop,wscale 7], length 0
11:33:47.430088 IP [my computer] > [the_device]: Flags [S], seq 2666683521, win 64240, options [mss 1460,sackOK,TS val 2735223648 ecr 0,nop,wscale 7], length 0
11:34:01.322396 IP [the_device] > [my_computer]: Flags [R.], seq 816065780, ack 747600049, win 8192, length 0
11:34:03.557950 IP [my computer] > [the_device]: Flags [S], seq 2666683521, win 64240, options [mss 1460,sackOK,TS val 2735239776 ecr 0,nop,wscale 7], length 0
11:34:32.235436 IP [the_device] > [my computer]: Flags [R.], seq 719236264, ack 2666683522, win 8192, length 0
So it keeps sending the same package with seemingly no response and then the device seems to reset the connection...!? The on-board Linux does not have tcpdump installed so I cannot get the same log from there. However, I can see that the SSH process is running and with netstat I can see that it is listening on port 22:
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
When trying the command "ssh testuser@[ip-address]
It simply responds with
connect to host [IP-address] port 22: Connection refused
On the device if I try "telnet localhost 22" I get
Connection closed by foreign host
and "lsof -i"
COMMAND   PID USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
sshd      299 root    3u  IPv4   1279      0t0  TCP *:ssh (LISTEN)
I'm utterly confused at this behavior. Clearly the ssh daemon is running - why is it not responding to anything?!
1010001010111101110111
Is your host SSH configured such that the client must supply a previously exchanged key ?
Usually a new key gets "doled out" to all newcomers but this isn't exactly secure. Perhaps the default behaviour has changed.
Have a look at /var/log/auth.log on the server that is running sshd. I see stuff like this (after I just SSHd into it to look at the log!):
Nov 23 11:15:01 lxd0308u CRON[13704]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 23 11:15:01 lxd0308u CRON[13704]: pam_unix(cron:session): session closed for user root
Nov 23 11:17:01 lxd0308u CRON[13708]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 23 11:17:01 lxd0308u CRON[13708]: pam_unix(cron:session): session closed for user root
Nov 23 11:18:38 lxd0308u sshd[13711]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=172.19.249.58  user=itsme
Nov 23 11:18:38 lxd0308u sshd[13711]: pam_sss(sshd:auth): authentication success; logname= uid=0 euid=0 tty=ssh ruser= rhost=172.19.249.58 user=itsme
Nov 23 11:18:38 lxd0308u sudo:     root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/opt/continental/bin/lib.sh pam_script
Nov 23 11:18:38 lxd0308u sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 23 11:18:38 lxd0308u sudo: pam_unix(sudo:session): session closed for user root
Nov 23 11:18:38 lxd0308u sshd[13711]: pam_listfile(sshd:account): Couldn't open /etc/ssh.server.user.allowed
Nov 23 11:18:38 lxd0308u sshd[13711]: pam_listfile(sshd:account): Refused user itsme for service sshd
Nov 23 11:18:38 lxd0308u sshd[13711]: message repeated 2 times: [ pam_listfile(sshd:account): Refused user itsme for service sshd]
Nov 23 11:18:38 lxd0308u sshd[13711]: Accepted password for itsme from 172.19.249.58 port 55331 ssh2
Nov 23 11:18:38 lxd0308u sshd[13711]: pam_unix(sshd:session): session opened for user itsme by (uid=0)
Nov 23 11:18:38 lxd0308u systemd-logind[1967]: New session c11 of user itsme.
Nov 23 11:19:07 lxd0308u sudo: itsme : TTY=pts/0 ; PWD=/home/itsme ; USER=root ; COMMAND=/bin/cat /var/log/auth.log
Nov 23 11:19:07 lxd0308u sudo: pam_unix(sudo:session): session opened for user root by itsme(uid=0)
Is the  Linux system set up to block access on port 22 ?
OK so I wondered if you could telnet to the SSH port (22) to actually interact with the SSH server. So at first I tried:
Telneting in to 22 prompted it to respond "SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3". At this stage I did not know how to respond so I typed "just testing" which it did not expect so it closed the connection.
So then I read:
https://stackoverflow.com/questi...
which took me to the RFC for SSH:
http://www.networksorcery.com/en...
From which I learned that a possible response was "SSH-2.0-billsSSH_3.6.3q3<CR><LF>". So I tried that:
and it looks like I have started to have a conversation with the sshd.
If you were patient you could read the RFC and learn how an entire SSH dialog might proceed and try each step to see if you can see at what point the SSH is rejecting your approach.
Thank you all for your input very much. I will go through your suggestions one by one and report any progress - however I am going home for today so please do keep an eye out tomorrow morning/afternoon. Thanks again.
I just re-read this thread. First time through I missed the fact you had said:
in which case it does look like a port 22 access problem and is probably caused by a firewall. Maybe try:
sudo ufw status verbose
If it is active and denying port accesses try:
sudo ufw allow ssh
and see if that helps.
It's inactive on my vanilla Mint installation; I've never had cause to use it.
Neil
I didn't used Linux in decade.But seems the port 22 didn't open.
Nevertheless We already entered the Moria long time ago.laugh
www.tokopedia.com/madagang cheap and free worldwide shipping with discount
