Putting data in a specific section in Flash
7 posts / 0 new
I’m currently stuck on a topic with a M0 based ATSAM HA0 microcontroller.
I’m trying to place a value at a given address in the Flash (note : this value is GIT credential automatically generated during the compilation, to simplify my explanations a consider the variable “m”=1,2,3......).
I’ve tried several ways to do it, each time I’ve got a different problem :
static uint8_t __attribute__((__section__(".id_section")))  m[9] = {1;2 ;3 ;4 ;5 ;6 ;7 ;8 ;9}
  • It puts the value in the section at good adress (I checked the BIN), but sometimes I get an hardfault reset at the startup.
const uint8_t __attribute__((__section__(".id_section")))  m[9] = {1;2 ;3 ;4 ;5 ;6 ;7 ;8 ;9}
  • It puts the value in the section (I checked the BIN), but changes some other data at other adresses in the output bin => Why ?
  • It uses 4 bytes less flash, and 4 bytes less ram (not sure why)
Compilation in GCC is made with optimisations activated (o1).
In case 1) where I can have a hardfault reset at startup, in some cases if I made small changes in the code like adding a variable, removing a line.... the hardfault reset will disappear. (And may reappear the next time I made changes in the code)
Also, when putting the beginning of the custom section not at address 0x7FF4, but at address 0x7FF0, the hardfault reset seems also to disappear (see .ld file below for adresses)
For information, here is the custom section in the ld file :
MEMORY
  rom      (rx)  : ORIGIN = 0x00000000, LENGTH = 0x00007FF4
  custom_rom   (r)  : ORIGIN = 0x00007FF4, LENGTH = 0x0000000C
  ram      (rwx) : ORIGIN = 0x20000000, LENGTH = 0x00001000
.id_section :
        . = ALIGN(4);
        _s_id_section = .;          /* start of mysection */
       KEEP(*(.id_section*));
        . = ALIGN(4);
        _e_id_section = .;          /* End of mysection */
        } > custom_rom
I hope someone could explain me the best way to do it....
Thank you very much
if it's purely in Flash, then there's no need to copy to RAM ?
doesn't sound like it's really related to (just) this variable.
You need to find what's actually causing the HardFault
https://community.arm.com/developer/ip-products/system/f/embedded-forum/3257/debugging-a-cortex-m0-hard-fault
https://www.embedded.com/debugging-hard-faults-in-arm-cortex-m0-based-socs/
I need access in both Flash and RAM, but I would like that at each compilation, there is only a specific section of the BIN which change. The customized section which I placed at the end of the flash section. Everything else should remain the same.
You will ask me why : its simple. I'm using it in order to store GIT information such as Tag number and hash number inside the code. But I need to be certain that after a merge (for example after a merge to master branch), the new code beeing compilated is exactly the same than the code being tested (exception being the few bytes used to store the GIT information).
What do you mean by that?
That's a common enough requirement - but why does it need to be in a specific section?
Surely, so long as it's somewhere in Flash you can either inspect it in the debugger, or "print" it to some debug stream or display - none of which require it to be in a specific sction.
most hard faults are from missalignment of memory...
try an alignment of 8 bytes, maybe this helps.
It is not so trivial to check what the compiler exactly does in your case:
As you said the const variant is different from the static one. What may happen is that your array is stored in your section,
but the pointer to your array is not located there. Due to its static behaviour it may be initialized first by 0 and afterwards by the pointer value pointing to your array. (so it needs a bit more memory)
Maybe the missalignment happens here. (https://infocenter.nordicsemi.co... ;
Unaligned read/write Cortex-M4F allows unaligned reads/writes, but on Cortex-M0 this leads to a HardFault. [....] In Cortex-M4F the default stack alignment is 4 bytes, while in Cortex-M0 it is 8 bytes.  )
So try changing to 8 byte alignment and fit the length to 8 byte alignment, this may help.
Flo1991
After additional tests and tries those last days, the problem seems solved with the 8 bytes alignment.
I had to wait a little bit before confirmation... I already observed this behavior, but I'm very happy that someone managed to find a written explanation somewhere :)
Thank you very much
Good to hear. Please mark the solution - see Tip #5 in my signature, below:
