CLKCTRL.MCLKSTATUS bits
5 posts / 0 new
I'm struggling with XOSC32K of an avr128da32.
My plan was to check bit 3 of above mentioned register to test the actual working of the external quartz oscillator but I get this
And PIT ISR won't get called (at difference when I switch to internal 32k oscillator).
So my question is --what does it means finding one in that bit?--
Disclaimer: I know my hardware is suboptimal but to stay as close at possible to the chip I arranged this
capacitors from quartz pins to ground are 12pf (I found the value on the schematic of curiosity nano)
Datasheet says:
So it means it is "stable" doesn't it?
You have inconsistent settings.
And the RTC has a CLKSEL register where you have to specify the clock source.
That's funny!
To remove all other variables (possibly due to me being a total newbie), even if i dislike it, I used Atmel Start:
Nevertheless your observation is precious and I will follow along it.
(there's still hope, at least till I can believe to stable bit!)
You were right, I was looking in the wrong part of startt
I can even see it running :-)
