Cannot program AVR128DA64 by MPLAB SNAP-in programmer.
21 posts / 0 new
Hi there,
I am getting a problem. I have purchased MPLAB snap-in programmer kit to program AVR128DA64. I have given the 5v supply to board the supply is 4.990volt. I have connected mplab snap-in 2,3,4(supply, gnd, updi) to mcu supply, gnd, and updi. In microchip studio, in programmer icon mplab-snap is showing connected, then I select MCU, after when I press the apply it asks to change pic mode to avr mode. When I press yes then after some time mplab snap-in connection get reset to the pc and then following error comes
Communication mode timeout.
in Mplab ide following error comes.
Data transmission failed. Error code -10121 returned while trying to receive USB data.
A communication error with the debug tool has occurred. The tool will be reset and should re-enumerate shortly.
Connection Failed.
I have removed the R48 resistor as per the guideline for Avr programming and connected the 4.7kohm resistor between supply and data.
Madhusudan Jadhav
Connect to MPLAB X IDE only once.
I seem to have had trouble when my SNAP was new, also.
Have a look here:  MPLAB® Snap Troubleshooting - Developer Help (microchipdeveloper.com)
IIRC, some SNAPs worked if one first selected a PIC micro, (not an AVR), and got the communications working with the MPLAB, and then switched to an AVR.
I, (and many others), had to jumper the Emergency Recovery Jumper and do a Boot Firmware Recovery process, (several steps, it guides you through them).
Since doing that it has worked fine.
Yes, this should fix it - fresh-from-fab SNAPs don't even know about "AVR mode" :| so they need to upgrade first in a PIC session.
Yes, This solved my problem. now when I try to download the program. The error was coming cannot configuration bit. So I unchecked configuration bit in proprties. Now error is coming.
An illegal configuration parameter was used. (57)
Madhusudan Jadhav
OK, so at this point, what version of debugger firmware is on there?
Sorry for Late
Please find below details. It is coming in mplab x.
Connecting to MPLAB Snap...
Currently loaded versions:
Application version............1.9.223
Boot version...................01.00.00
Tool pack version .............1.8.552
Target voltage detected
Erasing...
Programming did not complete.
Madhusudan Jadhav
Following Error is coming in Microchip Studio
Timestamp:    2021-10-14 18:08:49.874
Severity:        ERROR
ComponentId:    20100
StatusCode:    1
ModuleName:    TCF (TCF command: Device:startSession failed.)
An illegal configuration parameter was used. Debugger command Activate physical failed.
Madhusudan Jadhav
Ouch :/
Last 'check': are you using latest DFP for the Dx?
yes
Madhusudan Jadhav
Which one is preferred?
Madhusudan Jadhav
1.8.112 in mplab x
Madhusudan Jadhav
xc8 compiler
Madhusudan Jadhav
mysterious...
1) this error on activate _can_ be caused by electrical issues - its worth checking that board pullup mod and data line to the target for any debris that could be affecting signal quality
2) to help debugging the point of failure, it might be useful (if you are python savvy) to try pymcuprog and use -v debug logging
pip install --user pymcuprog
pymcuprog -d avr128da64 -v debug ping
Concur on pull-up that can be split between the MPLAB Snap and the AVR128DA64 PCBA (too much pull results in lack of tri-state that's required for UPDI)
UPDI Enable | AVR® DA Family (Hi-Z)
TinyX-OCD (UPDI) Special Considerations | Atmel-ICE
I did the same pinout for UPDI pinout and there no pullup on the board except on mplab-snap between power and data 1 kohm. The voltage measured between data and gnd is 2 volt of mplab-snap without connecting to pc.
Now the error is
PDI physical timed out. (25)
Snap requires an additional pullup resistor for the UPDI, TPI and PDI communication protocols. Please see the readme for more information.
Read did not complete.
Madhusudan Jadhav
I put 2 resistors value of 680 ohm, one on snap and other on board where pins are attached to snap. now following error is coming.
Erasing...
Error code 25 received from the debugger
Verify device selection, interface settings, target power, security bit, and connections to the target device.
Madhusudan Jadhav
Please post your schematic, a picture is worth 1K words of description and much more accurate!
Keys to wealth:
Lets go Brandon!
Madhusudan Jadhav
Not if you post a picture like #19
SNAP has been on the market for about 2 years.   If you make the hardware mod it should work fine with PDI and UPDI.
I have only used an external programmer with ATmega4808.
Otherwise I have used mega4809-XPRO, xmini-tiny817, curiosity-mega4809, curiosity-AVR128DB48 which all have on-board debuggers.
I doubt if the AVR128DA64 will behave differently to the 48-pin chips.
Please post a conventional schematic of your board.   And SNAP connections.
Sorry, My mistake,
5v supply wasnot going to avr mcu supply pins. Silly mistake Boards tracks were open. So corrected it and now supply 5volt ok.
 Now I put only one 4.7 Kohm resistor on SNAP between data and supply.
Programmed OK.
Madhusudan Jadhav
