cannot unlock AVR128DA32 with pymcuprog
4 posts / 0 new
I have used pymcuprog to program flash, userrow and eeprom without any problem. Now, I tried to lock the device by writing to the lockbits. This works too, I can't access the cpu anymore as expected.
However, I'm not able to remove the lock anymore. I thought that an erase together with -U should work. I'm getting an error and the device stays locked :-(
$ pymcuprog erase  -t uart -u /dev/ttyUPDI -d avr128da32 -U
pymcuprog.serialupdi.link - WARNING - Check failed
pymcuprog.serialupdi.application - ERROR - Timeout waiting for device to unlock
pymcuprog.nvm - ERROR - Device is locked.
Error:
Failed to enter NVM programming mode: device is locked
Error:
Pinging device...
pymcuprog.pymcuprog_main - ERROR - Error with st_ptr
Done.
Total votes: 2
sorry to follow my own post, I have just found the solution:
$ pymcuprog erase  -t uart -u /dev/ttyUPDI -d avr128da32 --chip-erase-locked-device
Looks like the course is really paying off for you!
Indeed - a "normal" erase uses the NVM key and then flash erase once in.  When its locked, the chip-erase key is the only way in.
