PIN CHANGE INTERRUPTS
11 posts / 0 new
I have this issue and can't solve it, it in pin  change interrupts in AVR?
I have setup pin change interrupt on PB1
DDRB &~(1<<1); //Make PB1 Input
PORTB |=(1<<); //Pullup PB1
PCICR |=(1<<0); // Enable Interrupts on PB0 - PB7
PCMSK0 |=(1<<1); // Enable interrupt PCINT0 - PCINT7
sei();
then in my ISR
This will not work.
ISR(PCINT0_vect)
  if(PINB &(1<<1) callback();   //Check to ensure the interrupt from PB1
//This is working perfectly WHY?
ISR(PCINT0_vect)
      callback(); ///Check to ensure the interrupt from PB1
Post the exact code please - this won't compile due to missing parenthesis:
ISR(PCINT0_vect)
What is connected to PB1?
please see Tip #1 in my signature, below, for how to properly post source code:
Total votes: 2
Would have helped if you had said which AVR this was! Also I can't help thinking this:
sei();
would be more readable as:
DDRB   &= ~(1 << 1);     // Make PB1 Input
PORTB  |= (1 << 1);      // Pullup PB1
PCICR  |= (1 << PCIE0);  // Enable Interrupts on PB0 - PB7
PCMSK0 |= (1 << PCINT1); // Enable interrupt PCINT0 - PCINT7
sei();
The first two lines had obvious typographical errors and the latter two will benefit from use of the symbolic names (PCIE0, PCINT1)
(I've assumed a 48/88/168/328 - perhaps I'm wrong?)
PS forgot to say: don't become addicted to using |= and &=~ all the time! Only use those to add bit settings into an already configured registered - for the first setting of a register just use plain old =
Thank you all for your helping hands.
I was able to get the code working, see attached below.
What I am doing?
I am using ATMEGA328P,
I want to have a Pinchange Interrupt.
I should be able to set the tracking level HIGH or LOW, since the PIN change state trigers interrupt.
I also want to select single or multiple pins when needed.
Each pin has function callback address stored in array (array of function pointer).
Whenver void ISR_PIN_ATTACH( void (*Fnc)(void), uint8_t bits, uint8_t track_state); is call
You need to pass address of the callback function, the PIN, and the level.
#include <string.h>
#include <avr/interrupt.h>
#include <util/delay.h>
typedef void (*FNCptr)(void);
FNCptr PCIINT[24]={nullptr};
uint8_t TRACK_LOGIC[24]={1};
ISR(PCINT0_vect)
    if((PINB &(1<<0))==TRACK_LOGIC[0]) PCIINT[0]();    //PB0
    else if((PINB &(1<<1))&&TRACK_LOGIC[1]) PCIINT[1]();    //PB1
    else if((PINB &(1<<2))&&TRACK_LOGIC[2]) PCIINT[2]();    //PB2
    else if((PINB &(1<<3))&&TRACK_LOGIC[3]) PCIINT[3]();    //PB3
    else if((PINB &(1<<4))&&TRACK_LOGIC[4]) PCIINT[4]();    //PB4
    else if((PINB &(1<<5))&&TRACK_LOGIC[5]) PCIINT[5]();    //PB5
    else if((PINB &(1<<6))&&TRACK_LOGIC[6]) PCIINT[6]();    //PB6 XTAL
    else if((PINB &(1<<7))&&TRACK_LOGIC[7]) PCIINT[7]();    //PB7 XTAL
    PCIINT[bits]=Fnc;
    TRACK_LOGIC[bits]=track_state;
    PINB &=~(1<< bits);
    DDRB |= (1<< bits);
    PCICR |= (1<< PCIE0);
    PCMSK0 |= (1<< bits);
void BlinkLed()
    PORTB ^=(1<<5);
    _delay_ms(50);
    DDRB |=(1<<5);    //PB5 OUTPUT
    DDRB &=~(1<<1); //PB1 Input
    PORTB |=(1<<1);    //Pull UP PB1
    TRACK_LOGIC[1]=false;
    ISR_PIN_ATTACH(&BlinkLed, 1, 1);
    sei();
    return 0;
You are very correct (ATMEGA328P)
then:
You don't seem to be checking to see if a function pointer has been assigned - if PCINT[0] (BTW don't use all upper case for C symbols!) has not been assigned you will call nullptr and effectively reset the AVR.
I thought your TRACK_LOGIC (again don't use all upper case - it looks like a pre-pro macro!) was a protection again this but you seem to have that "upside down" - you assign 1's to the entries and set "false" when one is used but your test in the ISR() is for 1/true not 0/false ??
Also don't do this:
ISR(PCINT0_vect)
where you read PINB multiple times - by the last read the stimulating input might have changed state - do something more like:
ISR(PCINT0_vect)
    uint8_t readB = PINB;
    if((readB &(1<<0))==TRACK_LOGIC[0]) PCIINT[0]();    //PB0
    else if((readB &(1<<1))&&TRACK_LOGIC[1]) PCIINT[1]();    //PB1
    else if((readB &(1<<2))&&TRACK_LOGIC[2]) PCIINT[2]();    //PB2
    else if((readB &(1<<3))&&TRACK_LOGIC[3]) PCIINT[3]();    //PB3
    else if((readB &(1<<4))&&TRACK_LOGIC[4]) PCIINT[4]();    //PB4
    else if((readB &(1<<5))&&TRACK_LOGIC[5]) PCIINT[5]();    //PB5
    else if((readB &(1<<6))&&TRACK_LOGIC[6]) PCIINT[6]();    //PB6 XTAL
    else if((readB &(1<<7))&&TRACK_LOGIC[7]) PCIINT[7]();    //PB7 XTAL
then you just read it once at the start.
Also do you really want this as if/else? That means only one call back can be made - what if more than one is activated at the same time - even though only one triggered you in to the ISR() I would have thought you might want to handle any that are set ?
Oh and try to get into the habit of putting spaces on either side of a C operator - it makes code more readable..
ISR(PCINT0_vect)
    if ((readB & (1 << 0)) == TRACK_LOGIC[0]) PCIINT[0]();    //PB0
    else if ((readB & (1 << 1)) && TRACK_LOGIC[1]) PCIINT[1]();    //PB1
    else if ((readB & (1 << 2)) && TRACK_LOGIC[2]) PCIINT[2]();    //PB2
    else if ((readB & (1 << 3)) && TRACK_LOGIC[3]) PCIINT[3]();    //PB3
    else if ((readB & (1 << 4)) && TRACK_LOGIC[4]) PCIINT[4]();    //PB4
    else if ((readB & (1 << 5)) && TRACK_LOGIC[5]) PCIINT[5]();    //PB5
    else if ((readB & (1 << 6)) && TRACK_LOGIC[6]) PCIINT[6]();    //PB6 XTAL
    else if ((readB & (1 << 7)) && TRACK_LOGIC[7]) PCIINT[7]();    //PB7 XTAL
Oh and in main() why are you (confusingly) doing:
when the call to:
is going to do:
    PINB &=~(1<< bits);
    DDRB |= (1<< bits);
anyway ?
I have taken note of all recommendations.
The double statements
DDRB &=~(1<<bits);
PORTB |=(1<<bits);
was because i failed initially for get the needed interrupt work, manipulating to know
where the trouble lie.
I really agree with you on this
ISR(PCINT0_vect)
Thanks for your time
What is connected to your port to generate the interrupts?
I connected CC1101 (GDO0).
I need to know when payload arrived. the device signify arrival of payload by pulling GDO0 HIGH.
