AVRDUDE Could not find USB device "USBasp" error, despite driver being installed
4 posts / 0 new
I'm trying to program an ATmega162 using my 51 AVR ISP programmer.  When I run avrdude, I get this error:
C:\Program Files (x86)\Atmel Studio\AVRDude>avrdude -p m162 -c usbasp -P USB -U "flash:w:""F:\Files\Dev\EE\BeerGoat\Test1\Test1\Debug\Test1.hex"":i" -vvv
avrdude: invalid file format 'i -vvv' in update specifier
avrdude: error parsing update operation 'flash:w:"F:\Files\Dev\EE\BeerGoat\Test1\Test1\Debug\Test1.hex:i -vvv'
C:\Program Files (x86)\Atmel Studio\AVRDude>avrdude -p m162 -c usbasp -P USB -vvv -U "flash:w:""F:\Files\Dev\EE\BeerGoat\Test1\Test1\Debug\Test1.hex"":i"
avrdude: Version 5.11-Patch#7610, compiled on Aug 31 2011 at 08:02:19
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Atmel Studio\AVRDude\avrdude.conf"
         Using Port                    : USB
         Using Programmer              : usbasp
avrdude: error: could not find USB device "USBasp" with vid=0x16c0 pid=0x5dc
avrdude done.  Thank you.
I'm not sure why avrdude is failing to find the device.  I used Zadig to install the driver (as documented here) and Windows can see it just fine (with the correct VID and PID).
I'm running Windows 7 64-bit, but I turned off UAC and the like for this test.  I didn't run into any hiccups installing the driver.  Avrdude is running with administrative privileges and should have no problem enumerating USB devices.
Any suggestions?
If anyone else bumps into this (it sounds like a lot of people tend to) I used the steps described here under "Device Driver Installation" and it fixed the problem of not being able to locate the programmer.  It involved downloading the latest libusb-win32 and using the bundled inf-wizard tool to create my own driver for the device.  Then in Device Manager I pointed USBasp to that INF and things are better.
I had the same problem on my Win7 PC.
I solved it by installing the USBAsp Driver with Zadig! But instead of chossing the default driver, chose the libusb-win32 driver!
That is all!
It's work for me ! thank you
a16
