Reading [2:0] in register
7 posts / 0 new
Anyone can advise what does clko_rate[2:0] mean? Is it trying to denote the 3rd bit of the register?
The CLKO frequency is programmed using clko_rate[2:0], CLKO_Ctl Register 0A, Bits 2-0. Table 4-13
lists each setting and its respective frequency.
Edinburgh
Total of 16 bits. Which device you use, please.
HI
  I am using AT91SAM9263 EK (host) to interface to NXP MCU as a coprocessor via I2C, and saw this datasheet with [2:0], and wonder what does [2:0] means in a nut shell.
Edinburgh
The notation [2:0] refers to the three lowest bits of that register.
Indeed. It is a common notation - not just used by Microchip (or Atmel, before them).
In general, [<start>,<end>] refers to a field starting at bit <start>, and ending at bit <end>.
The bit numbers are (usually) zero-based, with zero being the least-significant bit (LSB)
So, in the OP example:
xtal_trim is an 8-bit field: its bits are numbered 7..0, and it occupies bits 15..8  15..0  of the register;
clko_rate is a 3-bit field: its bits are numbered 2..0, and it occupies bits 2..0 of the register.
ADDENDUM
So the notation is actually used in two subtly different applications:
  1. xtal_trim[7,0] and clko_rate[2,0] tell you the sizes of the fields;
  2. Register[15,8] and Register[2,0] tell you the locations of the fields within the register
    (and you can also deduce the field sizes)
Because clko_rate occupies the bottom (least-significant) three bits of the register, clko_rate[2,0] corresponds to Register[2,0]
EDIT
Fixed typo - see #6
awneil wrote:
xtal_trim is an 8-bit field: its bits are numbered 7..0, and it occupies bits 15..0 of the register;
Correction. It occupies bits 15..8 of the register.
Oops! - corrected.
blush
