Help with bit function for exFAT
11 posts / 0 new
Guys, I have a function that returns a bit from the exFAT heap to mark a new cluster.  But for some reason there are errors when I create thousands of folders and files to test the system.
When I test the routine to start returning bits using the following, it works:
Basically, the function returns the first free bit it finds.
//	test to see if the problem is in this routine!!!!!!!!
	static unsigned int test = 8;
	clear_cluster(stream, test);
	//return address of bit allocated
	return test++;
This is the function:
unsigned int dir_get_cluster_bit(FILEX * stream){
	// base the pointer
	unsigned char * bitMap = stream->cache;
	/* Bit Map table, its a bit like the FAT table in FAT32 only it is in bits*/
	unsigned int fat_table = data_to_cpu32(stream->exFAT_Boot_Sector->ClusterHeapOffset) + stream->partition_index;
	// read first sector
	dma_hardware_read(1, fat_table, 1, stream->cache, 0);
	unsigned int byte = 0, sector = 0;
	// scan sector for a free bit, i.e. one or more bits are Zero
	while(* bitMap == 0xff){
		byte++, bitMap++;
		// stop arithmetic errors when byte is zero
		if(((byte % 512) == 0) && (byte != 0)){
			// move to next sector
			sector++;
			byte = 0;
			// reset bitmap to start of sector
			bitMap = (unsigned char *)&bitMap[0];
			// read next sector
			dma_hardware_read(1, fat_table + sector, 1, stream->cache, 0);
	// UnMap free bit location
	unsigned int bit = free_bit[* bitMap];
	// write bit to target byte and update
	* bitMap |= (unsigned char)1 << bit;
	// write first FAT bit entry
	dma_hardware_write(1, fat_table + sector, 1, stream->cache, 0);
	unsigned int new_cluster = ((sector * 512) + (byte * 8) + bit + 2);
	clear_cluster(stream, new_cluster);
//	static unsigned int test = 8;
//	clear_cluster(stream, test);
	return new_cluster;
So, when I find a free cluster bit, i.e. a zero int the byte, I mark it and return the address that the bit was found.
Guys, I'm going to shoot myself.  The error occurs when test = 4098.  So take the 2 away and the error occurs at 4096.  This is clearly a math error.
Let us know where to send flowers before you off yourself!
Keys to wealth:
Belfast, Ireland.  God's Own Country.
What on Earth is that supposed to mean? How is it going to "reset bitmap to start of sector"? This is an obfuscated, but still fairly obvious NO-OP. It doesn't do anything.
Why don't you just do the plain and obvious
Dessine-moi un mouton
I need help with COVID FAT, and not just a bit! smiley
Was away for a view days holiday.  When I came back yesterday I realised I had forgot to multiply the sector by:
((sector * 512) * 8)!!!!!!!
	// base the pointer
	dma_hardware_read(1, fat_table, 1, &bitMap[0], 0);
	unsigned int byte = 0, sector_cnt = 0;
	while(bitMap[byte] == 0xff){
		byte++;
		if(((byte % bytes_per_sector(stream)) == 0) && (byte != 0)){
			sector_cnt++;
			byte = 0;
			bitMap = (unsigned char *)stream->cache;
			// read next sector
			dma_hardware_read(1, fat_table + sector_cnt, 1, stream->cache, 0);
	unsigned int bit = free_bit[bitMap[byte]];
	bitMap[byte] |= (unsigned char)1 << bit;
	// write first FAT bit entry **UPDATE**
	dma_hardware_write(1, fat_table + sector_cnt, 1, stream->cache, 0);
	// calculate cluster bit number
	unsigned int new_cluster = ((sector_cnt * (bytes_per_sector(stream) * 8)) + (byte * 8)) + bit + 2;
	// clear newly allocated cluster
	return new_cluster;
... and still quietly replaced the nonsensical
with
with
It worked with that statement, I just replaced it to be neater.
No, it did not work. As I said above, you original version is a no-op.
Oh but it did.  I said it was working, but that it appeared to be a math error which it was. In plain sight.
