ST7920 LIBRARY
4 posts / 0 new
Hi. I want to write a library for St7920 in Xmega but I have problem in reading data from GLCD. It's part of my code.
Read function should read pixels and because of "write_word(0,0,0XC000);" it should return 0xc000 but when I ran my code with atxmega128a1u (Harware). On GLCD it displayed just "set_pixel(2,0);". Why? And how can I fix it.
And it's part of datasheet.
main()
    set_pixel(2,0);
uint16_t read_word(uint8_t type)    // read data byte(type=1) or command register(type=0)
    uint8_t i, j = 0;
	uint16_t temp;
	PORTJ.DIR = 0x00;    // set data port for input
	//PORTJ.OUT = 0x00;
	e_lo();
	if (type == 0)
		rs_lo();
		rs_hi();
	rw_hi();
	e_hi();            // toggle byte in
	i = PORTJ.IN;    // need I read this twice?
	e_lo();
	delay_ms(1);
	e_hi();
	j = PORTJ.IN;
	e_lo();
	temp = j;
	temp = temp | (i << 8);
	return(temp);    // return byte read
void write_word(int x, int y, uint16_t data)   // x=0-7 (8 words per line), y=0-63, starting from top left
    PORTJ.DIR = 0xff;    // set data port for output
    e_lo();//?
    rs_lo();//?
    rw_lo();
    // convert coordinates to weirdly-arranged 128x64 screen (the ST7920 is mapped for 256x32 displays).
    if (y > 31)
        y -= 32;    // because there are only 31 addressable lines in the ST7920
        x += 8;        // so we overflow x (7 visible bytes per line) to reach the bottom half
    x |= 0x80;    // bit 7 signals that this is a data address write
    y |= 0x80;
    DATA_PORT.OUT = y;    // Set vertical DDRAM address
    toggle_E();
    DATA_PORT.OUT = x;    // Set horizontal DDRAM address
    toggle_E();
    rs_hi();    //   signal for WRITE
    DATA_PORT.OUT = (data >> 8);    // Set horizontal DDRAM address
    toggle_E();
    DATA_PORT.OUT = data;    // Set vertical DDRAM address
    toggle_E();
void gotoxy(uint8_t x, uint8_t y)    // x=0-7, y=0-63  (for 128 x 64 display)
    e_lo();
    rs_lo();
    rw_lo();
    if (y > 31)
    y |= 0x80;
    toggle_E();
    toggle_E();
void set_pixel(uint8_t x, uint8_t y)
	uint8_t x_wd, x_pixel;
	uint16_t temp=0;
	uint16_t dot = 0x8000;    // this will be rotated into it's correct position in the word
	x_wd = x / 16;        // find address of word with our pixel (x; 0-7)
	x_pixel = x - (x_wd * 16);        // get the modulo remainder; that's our pixel's position in the word
	//gotoxy(x_wd, y); it makes trouble
	temp = read_word(1);    // read word from screen at that position
    //temp should be 0xC000 but it isn't
	temp = (temp | (dot >> x_pixel));    // convert x_pixel into a bit position, 0-16
	write_word(x_wd, y, temp);
Thank you for your help.
I strongly advise you to use the existing CodeVision library.   It supports ST7920 in 8-bit parallel or 4-bit parallel.
Build the examples.   If you are unsure how to do something,  quote the "nearest" example and say what the problem is.   Or what function you can't find.
Hi actually I used that library 2 or 3 months ago and I sent my code for you but it didn't work for me on my xmega (we had different type of xmega), even it didn't show a simple word like "Hi".
I tried to use 4bit and 8 bit and both of them didn't work. So I try to use another library and actually now it shows word (in lcd font), it sets a pixel (in graphic mode) and all. But I have problem in reading data.
I seem to remember running the CV example on an ATxmega128A4U but I might have used 32A4U or even 128A1.
Anyway the example ran fine.
Obviously I had different data and control pins to you.
But you simply edit the GUI to match your wiring.
If I had attached a CV project or AS7.0 to a previous message thread,  please post a link.
I am happy to step you through a library example.   It is not much good to be told 3 months later that it "did not work".
There is no point in attempting "your custom project" until you have run examples successfully.
