ATTINY816 - Enabling WO4 on Pin PA4
3 posts / 0 new
Hello all,
I am fairly new to programming with AVR, so I apologize if this is a very simple question.
I am trying to generate a PWM signal (WO4) on PA4 with Timer TCA0.
I thought this could be done by changing the PORTA.DIR to the appropriate pin and setting the PORTMUX.CTRLC to the default pin for but I am still unable to get the PWM signal out that specific pin.
I have a feeling I may be setting up the compare registers incorrectly, but I'm a bit to new to this to understand where the issue is.
Thank you!
Relevant Code:
// PWM test using timer A
#define F_CPU 2660000 // 2.66 MHz
#include <util/delay.h>
#define PWM_DUTY_CYCLE	0
#define PWM_PERIOD 256
void timer_Init(void)
	// Set PA4 as output (waveform output)
	PORTA.DIRSET = PIN4_bm;
	// Port Multiplexer TCA0 Output 4 select
	PORTMUX.CTRLC = PORTMUX_TCA04_DEFAULT_gc;
	// Frequency: Fpwm_ss = Fclk_per/(N(PER+1))
	// Max resolution: Rpwm_ss = (log(PER+1))/(log(2))
	TCA0.SINGLE.PER = PWM_PERIOD;
	// CMP sets the duty cycle of the PWM signal -> CT = CMP0 / PER
	// DUTY CYCLE is approximately 50% when CMP0 is PER / 2
	TCA0.SINGLE.CMP0 = PWM_DUTY_CYCLE;
	// Counter starts at 0
	TCA0.SINGLE.CNT = 0x00;
	// Configuring CTRLB register
	// Compare 0 Enabled: Output WO4 (PA4)
	// Single slope PWM mode is selected
	TCA0.SINGLE.CTRLB = TCA_SINGLE_CMP0EN_bm | TCA_SINGLE_WGMODE_SINGLESLOPE_gc;
	// Using system clock (no frequency division, the timer clock frequency is Fclk_per)
	// Enable the timer peripheral
	TCA0.SINGLE.CTRLA = TCA_SINGLE_CLKSEL_DIV1_gc | TCA_SINGLE_ENABLE_bm;
	timer_Init();
		for(uint8_t brightness = 0; brightness < PWM_PERIOD; brightness++)
			TCA0.SINGLE.CMP0 = brightness;
			// wait to see the LED brightness change
			_delay_ms(150);
This pin only works in split mode.
Thank you kabasan!!
Just that little piece of information fixed everything by enabling split mode.
Cheers!
