Snap programmer with ATMega644
11 posts / 0 new
Has anybody experience with a SNAP programmer and an AVR controller? I used my SNAP to program a PIC18F46J50 via MPLAB X IPE 5.15, which works fine.
Now I try to program an ATMega644 (I connected the MISO/MOSI/SCK/RST pins) and supply an external 5V and GND to the controller and the SNAP.
When trying to program, I get a message "No device detected (32)". Any idea what I have been overlooking here ?
Edward
Edward
Welcome!
MPLAB IPE changes for AVR?
EDBG - MPLAB debuggers are configured for PIC at the factory; IIRC, selecting an AVR should set the debugger to EDBG mode.
MPLAB Snap | Page 2 | AVR Freaks
edit :
MPLAB® PICkit™ 4 Debugger Pinouts for Interfaces - Developer Help
I would suspect the wiring first - sure you have routed RESET to Snap's AUX pin (and not MCLR)?
Hi mraardvark,
The "reset" is connected to pin 6 on the SNAP (and not to pin 1).
Edward
Hi gchapman,
This is what I get when power up sthe SNAP: "Application version............0.14.230",
as I understand it from the reference, this should be a V5.10 compatible version.
Edward
Hmmm.
Next suspect would be clock, which must at least be:
- present on the AVR
- ISP clock specified in MPLAB to 1/4 of the clock frequency
emulder wrote:
V5.10
I would also recommend (for AVR at least) to use a newer MPLABX, like 5.40-ish, which should use v1.6.171 debugger.
Hi mraardvark,
My settings on the X-IPE side are: "isp mode" and "Speed = 0.5MHz"
I have a 2MHz crsytal on XTAL1 and XTAL2 with two 27pF capacitors to ground.
How does the AVR know that it should use the external crystal oscillator by the way?
Edward
Hi all,
I just downloaded and installed MPLAB V5.50, and the IPE that comes with it works well.
smiley
Thanks a lot to both mraardvark and gchapman for pointing out my mistake.
Edward
fuses, low byte, least significant four bits, fuse data is latched shortly after RESET is deasserted.
ATmega164A/PA/324A/PA/644A/PA/1284/P megaAVR® Data Sheet
[page 39]
[page 297]
Table 27-5. Fuse Low byte
ATMEGA644PA | Microchip Technology
A little heads-up since you are coming from the PIC-world: Fuses in AVRs are not cleared on chiperase, like configuration bits in PICs.
