quick question about unsigned long long...
27 posts / 0 new
Hi guys, stumbled on to a ee problem that I can't see the solution to.  See the code below:
static unsigned int data_to_endian(unsigned long long value, unsigned char * endian){
	endian[0] = (unsigned char)value;
	endian[1] = (unsigned char)value >> 8;
	endian[2] = (unsigned char)value >> 16;
	endian[3] = (unsigned char)value >> 24;
	endian[4] = (unsigned char)value >> 32;
	endian[5] = (unsigned char)value >> 40;
	endian[6] = (unsigned char)value >> 48;
	endian[7] = (unsigned char)value >> 54;
but I'm getting a compiler saying:
warning: right shift count >= width of type [-Wshift-count-overflow]
but why, value is a 64bit integer?
You should do this.
	endian[1] = (unsigned char)(value >> 8);
	endian[2] = (unsigned char)(value >> 16);
	endian[3] = (unsigned char)(value >> 24);
	endian[4] = (unsigned char)(value >> 32);
	endian[5] = (unsigned char)(value >> 40);
	endian[6] = (unsigned char)(value >> 48);
	endian[7] = (unsigned char)(value >> 54);
	return 0;
If you want to promote the shifts to be "long long" then perhaps also consider:
(value >> 54ULL);
BTW do NOT use "unsigned long long" anyway. Use uint64_t.
If you port this code to a machine where a long is not 32 bit then it will not build correctly. However if you use uint64_t then not only does it tell the reader immediately that "this is an unsigned 64 bit variable" it also guarantees it whatever architecture the code is built for. You should never use any of "short, int, long". It is OK to use "char" but don't use it for numerics, only for characters, for 8 bit numerics use int8_t or uint8_t.
(value >> 54ULL);
That would work with other operators, but doesn't work with shifts. The type used for the shift operation is the (integer promoted) type of the left operand only.
So it would need to be (uint64_t)(value) >> 54
If value is already a uint64_t (or unsigned long long) then cast is not needed of course.
But as Cliff pointed out - why is anyone using long long in this day and age? Use a defined length variable: uint64_t
I have a vague idea that shifts are undefined/implementation dependent for signed variables - is this the case?
Neil
Compiler dependent?
#include <stdint.h>
void out(uint64_t val);
int main() {
  uint64_t value = 1;
  value >> 54ULL; // PC-lint generates a 522
  value = value >> 54ULL;
  out(value);
Gimpel On-Line Message Reference Manual
Copyright © 2011, Gimpel Software
[1/4 page]
522
   Highest operator or function lacks side-effects -- If a statement
      consists only of an expression, it should either be one of the
      privileged operators: assignment, increment, decrement or call to
      an impure function or one modifying its argument(s).  For example
      if operator * is the built-in operator, the statement *p++; draws
      this message but p++; does not.  This is because the highest
      operator is '*' which has no side effects.
      The definition of pure and impure functions and function calls
      which have side effects are given in the discussion of the pure
      semantic in section
PC-lint Plus Online Demo - Gimpel Software - The Leader in Static Analysis for C and C++ with PC-lint Plus
Some aspects are.
May as well just quote the C standard. Thsi is from C99, i don't think it will have changed since
The integer promotions are performed on each of the operands. The type of the result is
that of the promoted left operand. If the value of the right operand is negative or is
greater than or equal to the width of the promoted left operand, the behavior is undefined.
The result of E1 << E2 is E1 left-shifted E2 bit positions; vacated bits are filled with
zeros. If E1 has an unsigned type, the value of the result is E1 × 2 ^^E2 , reduced modulo
one more than the maximum value representable in the result type. If E1 has a signed
type and nonnegative value, and E1 × 2^^E2 is representable in the result type, then that is
the resulting value; otherwise, the behavior is undefined.
The result of E1 >> E2 is E1 right-shifted E2 bit positions. If E1 has an unsigned type
or if E1 has a signed type and a nonnegative value, the value of the result is the integral
part of the quotient of E1 / 2^^E2 . If E1 has a signed type and a negative value, the
resulting value is implementation-defined.
"Defined length" types are optional.
Firstly, shifts for positive signed values have always been perfectly defined (as long as there's no overflow). In C left shifts for negative values are undefined. Right shifts for negative values are implementation defined.
Secondly, C++ has already adopted "one true signed representation" to rule them all: 2's-complement. 1's-complement and sign-and-magnitude got outlawed. Now in C++ all shifts are perfectly defined in all cases for all values, including negative ones. C is not there yet. Maybe C will stick with multiple supported signed representations longer, but it will probably get there sooner or later as well.
Dessine-moi un mouton
Thank you both; that was what I had remembered.
Neil
It might still be a good idea to use them. Nobody said they were mandatory.
Except MISRA ? ;-)
EDIT: that is...
  • MISRA C:2004, 6.3 - typedefs that indicate size and signedness should be used in place of the basic types
  • MISRA C++:2008, 3-9-2 - typedefs that indicate size and signedness should be used in place of the basic numerical types
(one day I'll find my actual copies of MISRA - the efficiency bunny has hidden them!)
EDIT2: so, in the absence of the book, it wasn't too hard to find a dodgy PDF on the internet in fact - so OK, 6.3 is just "(advisory)" rather than "(required)" - I'll grant you that.
54=9*6 is not a multiple of 8.
56 would seem to be wanted.
I didn't know I could have 64 bit unsigned integers in a mega.  Aren't floats and doubles both 32 bits?  Can I get a 64 bit floating point variable?
Yes
Libf7 | avr-gcc - GCC Wiki
Hard to believe but still these 8 bit micros pack quite a punch. A man can probably leave this solar system with a bunch of 8-bit megaAVR's controlling the rocket.
“Everyone knows that debugging is twice as hard as writing a program in the first place. So if you're as clever as you can be when you write it, how will you ever debug it?” - Brian W. Kernighan
“Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away.” - Antoine de Saint-Exupery
Surely you aren't really asking about "mega", but rather "with <insert name here> C toolchain...".
That tells me I need V10 of gcc.  How do I see what compiler my AS Version 7.0.2397 is using?  I know I have seen it somewhere in the past, and I that I can change compilers, but I can't seem to find it now.  I see gnu99 as one of the compiler flags.  I can declare a long double, and multiply it by itself, and it compiles, so my version seems to know what one is.
Thanks.  I'm pretty much hopeless at system level stuff and machine language level.  All I've ever done is algorithms in C and Fortran before that, so I live in that little slot between system and machine, blissfully ignorant of how it all works, but happy when the numbers coming out of my code are as should be.
ATmega1284P and ATmega328P
Lee's point was that it doesn't matter what model of AVR you have, whether you can do uint64_t, 64 bit double and so on is down to which C compiler you choose to use. IAR and the Pro version of the (now demised) Imagecraft both offered 64bit double by default I believe (though they cost $3000 and $800). Other compilers like GCC and Codevision have both float and double as 32 bit. There is no 64 bit support. As for uint64_t ((unsigned) long long) I think IAR/Imagecraft/GCC have this but I'm not sure about Codevision. There are, of course, other compilers like MikroC - but who knows about them !
As for a GCC that is >=10, this page appears to have V11:
https://blog.zakkemble.net/avr-g...
In Studio 7 you would set this up as a "toolchain flavour", see:
https://microchipsupport.force.c...
EDIT: Just checked Codevision user manual so it has 64 bit integers too...
Rowley/CrossWorks, pay-for, has long-long as well as true double.
Yup, apart from David I don't know anyone who ever uses Rowley but it sounds like it's probably actually pretty good. I know David likes the debug environment too. No idea what it costs though?
EDIT: OK, $150 for a personal/non-commercial license apparently.
Thanks Cliff.  That helps.
I guess, yeah.  It's as Cliff says.  It's all about the compiler.  But I would think the hardware platform imposes some constraints.
It has always been like magic for me.  I write my code and numbers come out.  How that happens is a black box I don't much think about.  I know lots of people find the workings of the black box fascinating.
The absolute minimum you need for an ALU to be able to do arithmetic is the ability to subtract one register from another (or from memory) and the ability to NAND two registers/memory locations. With those you can do the whole suite of basic arithmetic operations - though it's more common to find addition, subtraction, and AND/OR/XOR which makes it a bit simpler.
The size of the operations you can perform is limited not by the register size but by the amount of memory you can address... if an eight-bit micro is trying to do 64- or 128-bit arithmetic, it just has to take more steps to do it. There's nothing intrinsic in the processor that inhibits larger variables and operations, in the same way there's no practical difference between adding two single digit decimal numbers and decimal numbers with more digits. Just more of the same, and keep an eye on the carry!
Neil
Remember that the very early calculators in the 70's were using 4 bit micros.
Later I owned a Sinclair Programmable, things had moved on a bit by then, but if you typed "45, sin, cos, tan, atan, acos, asin" you could basically walk away and get a coffee in the time it took for the result to appear ! It probably had an 8 bit micro but I'm guessing 1MHz so maths was "do-able" but it took a long long time.
It's more about the "cleverness" of the software than the capabilities of the hardware.
It seemed to me that Segger Embedded Studio is a re-badge of Rowley (I think "Rowley" got a mention in some of the config/system files?)
https://www.segger.com/products/development-tools/embedded-studio/
So that might count me in as a "Rowley user" ?
Neil, now you are talking my language.  That makes perfect sense.
Cliff, I got a 4 function calculator for graduation from high school - add subtract multiply divide.  It cost $100.  I recall it was LED display.  In 1967, it was probably the LEDs that cost so much.  Not the arithmetic chips.  I never found it very useful.  At the time I could do arithmetic in my head, but my parents thought it was pretty cool.  I still use a Casio fx-82 that uses 2 AA batteries.  It sits next to my laptop because I can't do arithmetic in my head so clearly anymore.  I have to wait a second or two for a cosine to pop up, but I have plenty of time.  I did a Bing search and was amused the image was from the IT History Society.  Now that made me feel old.
