What are the AVR28DA128 AVR32DA128 AVR48DA128 AVR64DA128 ??
276 posts / 0 new
Pages
to gchapman: Are you on some sort of mailing list that you get announcements for all these new documents that you post?  Is there some forum or web page at Microchip where they are announced?
(In any case, thank you for reposting them here, attached to relevant threads!)
No
web pages
You're welcome!
P.S.
A foundry's application engineers, by significant effort and work, create application notes and source code that expands on what's in the data sheets (ideally created by design engineers)
Same application engineers may write trade journal articles though these journals aren't like the ones in the past (circa '10)
Same engineers attend conferences that are now virtual (where's the swag?)
(sucking sound from the drain)
Chin up!
How to search for Microchip PCNs (change control board releases data sheets, errata, assemble & test, wafer fab for new die or new fabs)
TechDoc (PDF are the reference)
Online Docs (web docs, subset of TechDoc)
RSS Feeds | Microchip Technology (RSS's typical use case is feeds to journalists)
What's New? - Developer Help
Revision History | Getting Started with Serial Peripheral Interface (SPI)
B
02/2021
Updated the GitHub repository links, the References section, and the use cases sections. Added the AVR® DA Family Overview and Revision History sections. Added MCC versions for each use case, running on AVR128DA48. Other minor corrections.
TB3215 Getting Started with SPI (PDF)
Revision History | Getting Started with Timer/Counter Type B (TCB)
B
02/2021
TB3214 Getting Started with TCB (PDF)
edit :
Revision History | Getting Started with Timer/Counter Type D (TCD)
B
02/2021
Updated the GitHub repository links, the References section, and the use cases sections. Added the AVR® DA Family OverviewDithering Feature and Revision History sections. Added MCC versions for each use case, running on AVR128DA48. Other minor corrections.
Rev. DS40002198B - 02/2021 | AVR® Instruction Set Manual
1.Editorial change, code examples needed beautification.
2.Corrected instructions affecting two registers had a syntax that did not compile as inline in avr-gcc or xc8.
3.Defined overline symbol as negation.
4.Corrected core overview for AVR® DA Family AVRxm to AVRxt.
5.Added to core overview AVR® DB and AVR® DD Families.
6.Reintroduced the Conditional Branch Summary table with some simplification.
AVR® Instruction Set Manual (PDF)
I really don't understand what are DD and DE families for. All of them seem to be practically identical and no significant improvement since ATmega4809. I wish new AVRs have USB working as Virtual COM Port. This would be really nice to get rig o CP2102/FT230... old XMEGA AU serial have USB and this was really useful.
extronic.pl
Low pin count (growth from tinyAVR 0, 1, and 2-series)
extronic wrote:
... and no significant improvement since ATmega4809.
mega4809 has a single-ended ADC, no high frequency crystal oscillator, etc.; a mega4809 advantage is packaging (PDIP-40 vs PDIP-28)
Concur; maybe AVR DC.
USB is a mid-complexity peripheral; some difficulty to be complete, precise, and correct with USB and squeeze the USB controller into the limited die space.
Maybe AVR Dx USB access will be by another means (USB megaAVR : dual-port RAM, USB XMEGA AVR : pseudo dual-port RAM and the four RMW instructions)
Yet there's innovation in USB UART :
  • crystal-less
  • very high baud
  • 24MHz clock to the MCU
... and XMEGA B & C.
Features | ADC | ATmega4808/4809 Data Sheet
NEW! USB to UART G Series Archives | Prolific USA | IC Design & Manufacturing
XR21x14x Universal Async Receiver Transmitters - MaxLinear | Mouser due to CH340G IC vendor..... | AVR Freaks
USBXpress USB Bridges - USB-to-UART bridge controllers - Silicon Labs and Pololu - CP2102N USB-to-Serial Adapter Carrier
I looking forward to -DD because of the package size. 4mm QFN vs 5mm makes *a lot* of difference to me. Then I can drop SAMD11 which is too memory-constrained (although it does have USB, if you can afford the memory use).
Revision History | Getting Started with Analog-to-Digital Converter (ADC)
B
03/2021
Getting Started with Analog-to-Digital Converter (ADC) (PDF)
Revision History | Getting Started with Digital-to-Analog Converter (DAC)
B
03/2021
Getting Started with Digital-to-Analog Converter (DAC) (PDF)
edit :
Revision History | Getting Started with Configurable Custom Logic (CCL)
B
03/2021
Updated the GitHub repository links, the References section, the use cases sections, and the use cases figures. Added the AVR® DA Family OverviewAdvanced Examples and Revision History sections. Added MCC versions for each use case, running on AVR128DA48. Other minor corrections.
TB3218 Getting started with CCL
http://packs.download.atmel.com/#collapse-Atmel-AVR-Dx-DFP-pdsc
[AVR Dx web page URLs]
1.7.85 (2021-03-05)
Added support for AVR64DD.
There are so many monolithic buck converters, some which only require outboard capacitors. Don't see why one would build one oneself.  You can control the voltage with a filtered PWM signal to bias the Feedback pin.
  • voltage
  • digital control (in primary or secondary)
  • digital compensation (flexibility in matching load to source as either or both change impedance)
though current BCD processes and designs have transistors with significant drain-source max voltage; there are significant use cases for 40Vdc and greater (power tools, mowers, engine start-stop, hybrid EV, etc)
or a DAC though DAC are more prevalent in follow-on AVR.
BCD - Bipolar-CMOS-DMOS (low noise analog front-end, control logic, power switches)
Hysteretic control though very low price :
2-transistor Black Regulator by Roman Black
[3/4 page]
High voltage use
84Vdc :
Electric propulsion system for PPG and Ultralights | AVR Freaks
Secondary control, digital control :
MCP1012 - AC/DC - Auxiliary Controllers
Schematic | AVR128DB48 Curiosity Nano Hardware User Guide (second sheet, A2)
One of the main reasons to switch the power with a micro is to be in sync with the switching noise.
AN3998 - Sensorless BLDC Motor Control for AVR® Microcontrollers
[last sentence of page 1]
The presented solution creates a cost-effective motor driver by using an 8-bit microcontroller when traditionally, only 16-bit microcontrollers or more were used in creating this device.
The motor control board could drive the motor for some water well pumps; Plug-In Module (PIM) for AVR DA and AVR DB are forthcoming.
edit : web doc
edit2 : 16 bit
Microchip's dsPIC33CK Low Voltage Motor Control (LVMC) Development Board - YouTube (6m6s)
edit3 :
Revision History | Sensorless BLDC Motor Control for AVR® Microcontrollers
B
6/20201
Updated Introduction section with GitHub link.
August Development Tools sale
AVR128DB48 Curiosity Nano Evaluation kit
Use Coupon Code:
TP2127
$18.99  $15.19
Curiosity Nano Touch Adapter Kit
Use Coupon Code:
TP2130
$19.99 $16.99
via e-mail
AVR128DB48 CURIOSITY NANO EVALUATION KIT | Microchip Technology
Coupon codes are nice, but can anyone actually buy anything from them?
I have been trying to buy the DB48 eval kit for the last hour, but I can't get past the checkout. It says there is something wrong with one or more fields in my address, but all is fine when I look. The address is the same as last time I ordered from Microchip Direct, and back then there was no problem.
Web sites are updated and have several applications that must communicate else fubar.
Try during business hours or try
Contact Us | World's Largest Inventory of Microchip Products
though there's a Denmark office.
FUBAR - Wiktionary
version 1.1 released 23-Aug'21
ISO 26262 Functional Safety Packages for AVR® DA
Additions are AVR Dx and Seiko Instruments crystals.
Revision History | Selecting and Testing 32.768 kHz Crystal Oscillators for AVR® Microcontrollers
C
09/2021
1.General review of the application note text.
2.Corrected Figure 1.
3.Updated section Crystal Recommendations with new AVR devices and crystals
Revision History | Using the Internal OPAMP as Regulated Power Supply for MVIO
B
09/2021
Corrected some formulas and made notation more consistent
Pages
