about zero crossing detector
10 posts / 0 new
i want to make a simple but accurate zero crossing detector whose input is an ac sine wave and its output is digital signal(0 and 5V).
what i am doing is using LM339 to make it, if i use single 5V supply power, it is easy but no one have mentioned this before(simulation also tells it is unsteady), but if i use split power supply , i don't know whether the one(74LS04) can endure the negative voltage for a long time.
what's your opinion?
Our Martians are beginning to learn AVR
What you can do is run the LM339 off + and - supplies and on the output put a 1K resistor to 5V and then stuff that into your logic chip.
Good luck
i have tried this, but the result is that it outputs +5v and a negative voltage.
what i am meditating is whether the digital IC is able to endure the negative voltage(-18V), and if it can endure, it can last a long time to keep steady??
No, the digital IC won't like the negative voltages. In the datasheet you'll find a section 'Absolute maximum ratings', usually there's a item that says 'Max input voltage' that says 'VCC+0.7V and GND-0.7V". -18V surely violates this :D
If you put a resistor (say 1K) in series from the opamp output to the logic gate input, the resistor and the input protection diode that's built in the gate will clamp the negative voltage to ~-0.7V and keep the current through the diode small enough (this diode has a max.rating too). And the aforementioned pull-up resistor is needed too.
got it! you say just puting a resistance between LM339 and 74LS04 will make it ok . it is so simple. several hours ago, i place an ac sine wave(+-18V) to the AVR MCU, but i forgot to add a resistance, then the microcontroller sees the lord in the heaven in a few seconds.
Sorry, there is also a diode to ground on the output of the comparator to clamp the negative voltage.
Thanks for pointing that out as the prototype has been running with this diode omitted for the last 3 weeks!
Another real simple idea is to place a diode in series with the gate. Anode to the comparator, cathode to the gate. Then add a pull down resistor to the cathode of the diode to ground. The diode prevents the negative voltage from passing.
Another option is to use a comparator that has an isolated output. Take a look at the LM311.
Indeed, i have simulated the above methods before, but the simulation result is not like we have imagined( i use diode 1n4148 )
the best way is using LM311. but i lack of LM311, so i use LM311's schematic diagram to change LM339. i place a transistor following the LM339, its emitter to the GND, and its collector plus a 10k resistance to the +5V. then it is done!
Excellent work Marty the Martian!!
