A general overview of what happens before main()
15 posts / 0 new
I found this link in one of Jack Ganssle's The Embedded Muse (#427) that I thought might be helpful to others and beginning programmers, there are links at the bottom for continued study.
Here is the link: https://embeddedartistry.com/blo...
I hope you find it useful.
Not sure if the Arduino forum is the best place for this.....
FF = PI > S.E.T
General Programming, surely?
https://www.avrfreaks.net/forum/what-startup-code-and-where-does-it-come
Feel free to move it, my thoughts were some Arduino users wanting to learn more about bare metal programming may find it here.
FF = PI > S.E.T
The article seems to be rather biased to a hosted OS environment rather than what actually happens in micros. The CRT for an AVR does not need to concern itself with things like argc/argv or MMUs etc.
Obviously the CRT for AVR will be a bit different depending on the compiler in question but on the whole it probably:
1) disables I in SREG
2) may handle possible watchdog restart
3) initalises stack
4) optionally clears BSS if used
5) optionally copies initial .data from flash to RAM
6) CALLs main
7) if the CALL to main returns handle it somehow
In the case or C++ there are extra steps in there for calling the c'tors before main() and the d'tors after.
EDIT: bit of a shame this post I made on 2010 on the old Freaks appears to have gone through the mangler:
It shows the approach used by avr-gcc
(kind of a shame I never followed Eric's advice in a subsequent post and made it into a tutorial!)
I'm pretty sure I have typed pretty much the same kind of explanation a few times now. If only I could find them!
It is a General overview.....    although it does cover bare metal(restart vector) and bootloader startups further down the page.....
Thanks for AVR specifics!
FF = PI > S.E.T
clawson wrote:
3) initalises atck
Assume you meant: 3) initializes stack  (typo)
FF = PI > S.E.T
Yup, corrected above.
Total votes: 3
Boy, oh, boy. Trying to find something I know I've typed previously among 102,500 posts is fraught!
Anyway for avr-gcc I had a go at explaining it's CRT in this post (mainly comments in a disassembly): https://www.avrfreaks.net/commen...
EDIT: SAINTS BE PRAISED! I can't believe I finally found the post I was looking for...
That is a fairly recent explanation (so hopefully up to date info) about the CRT that AVR-libC provides to for avr-gcc.
With all the great info you've provided over time...it is time to get your book on Amazon--print on demand!
But, who has time to read?  sad
I have 😏 and probably many others. I already open/read this forum multiple times a day.
“Everyone knows that debugging is twice as hard as writing a program in the first place. So if you're as clever as you can be when you write it, how will you ever debug it?” - Brian W. Kernighan
“Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away.” - Antoine de Saint-Exupery
Total votes: 2
Surely before main you have appetisers or antipasto (salami, olive, bruschetta etc...)
Some of us eat desert first!
FF = PI > S.E.T
js wrote:
Surely before main you have appetisers or antipasto (prosciutto, gorgonzola  etc...)
No, thanks. No main, I like to assemble it my way.
ki0bk wrote:
 eat desert
Beware of a flavors of Main, some are indigestible.
