SW-UART big bang help
48 posts / 0 new
I try to use SW UART Transmitter for displaying into the serial terminal. I am using ATTiny461A and a FTDI usb to Serial board from Deek-Robot kit. I connect the PB0 of the MCU to the RX on the board, 5V and Ground.  The rest (cts, dtr) not connected. Is it error on the hardware ?  Any other hardware alternative or correct board i shall use ?
I use the Atmel Studio Visualiser to check the Serial Port Com10, nothing is display on it.
The code is a modified from Marcel Meyer-Garcia github here. I just amend the Timer code to suit ATTiny461A timer code and the Compare Match change to OCR0B, value change to 26.
#define F_CPU 16e6
#include <avr/interrupt.h>
#include <util/delay.h>
// change these to use another pin
#define TX_PORT PORTB
#define TX_PIN  PINB0
#define TX_DDR  DDRB
#define TX_DDR_PIN DDB0
volatile uint16_t tx_shift_reg = 0;
void UART_tx(char character)
   uint16_t local_tx_shift_reg = tx_shift_reg;
   //if sending the previous character is not yet finished, return
   //transmission is finished when tx_shift_reg == 0
   if(local_tx_shift_reg){return;}
   //fill the TX shift register witch the character to be sent and the start & stop bits (start bit (1<<0) is already 0)
   local_tx_shift_reg = (character<<1) | (1<<9); //stop bit (1<<9)
   tx_shift_reg = local_tx_shift_reg;
   //start timer0 with a prescaler of 8
   TCCR0B |= (1<<CS00)|(1<<CS01) ;
void UART_tx_str(char* string){
    while( *string ){
        UART_tx( *string++ );
        //wait until transmission is finished
        while(tx_shift_reg);
void UART_init(){
   //set TX pin as output
   TX_DDR |= (1<<TX_DDR_PIN);
   TX_PORT |= (1<<TX_PIN);
   //set timer0 to CTC mode
   // TCCR0A = TCW0 | ICEN0 | INCC0 | ICES0 | ACIC0 | - | - | CTC0
   //            0  |  0    |    0  |     0 |  0    | 0 | 0 |   1
   TCCR0A = (1<<WGM00);//for attint461A
   //enable output compare 0 B interrupt
   // TCCR0B = |- | -| - | TSM | PSR0 | CS02 | CS01 | CS00
   //          | 0|0 | 0 |  0  | 0    | 0    |  1   | 1    //64
   //if 16MHz divide by 64, timer will clock at 250K Hz
   //To get 9600 baud rate, which is 1/9600 = 104 usec
   //Count Value = 104us x 250 K = 26
   TIMSK |= (1<<OCIE0B);
   //set compare value to 26 to achieve a 9600 baud rate (i.e. 104µs)
   //together with the 16MHz/64 = 250kHz timer0 clock
   //IF use internal 16MHz, use precaler of 16.
   /*NOTE: since the internal 8MHz oscillator is not very accurate, this value can be tuned
     to achieve the desired baud rate, so if it doesn't work with the nominal value (103), try
     increasing or decreasing the value by 1 or 2 */
   OCR0B = 26;
   //enable interrupts
   sei();
   UART_init();
    UART_tx_str("Hello world!\n");
    _delay_ms(100);
   return 0;
If the USB-serial board has LEDs, does one flash when you try to transmit?
Have you opened a serial port that talks to the FTDI chip AND do you have the port baud rate set to the same that the MCU is generating?
Is
#define F_CPU 16e6
a valid statement and is your MCU REALLY running at 16MHz? I would use
#define F_CPU 16000000 UL
If you connect RX and TX together on the serial board can you send a character from a terminal program and see it echo back? And if you disconnect them does the echo stop?
Are you using a good 16MHz Crystal??...do not start off with an inaccurate frequency, or you can severely regret wasting days of your time for nothing.
Before you hooked up the AVR at all, did you take your adapter module and tie TX to RX  ???
Then your terminal should rcv & show what you type on the terminal...If that does not work, forget about even trying the AVR.
What does your scope show coming out of the AVR?
In Post#1, I don't see the ISR code.
Is the ISR in your program but not copied to the post?
+1
You have:
and
   //enable interrupts
   sei();
but apparently nothing "behind" this to catch the ISR()??
Surely the whole point
is that the value to send is placed in tx_shift_reg and then the timer started and then, on each interrupt it will shift one bit out. If you don't have the interrupt handler this is not going to happen.
//timer0 compare A match interrupt
ISR(TIMER0_COMPB_vect)
   //output LSB of the TX shift register at the TX pin
   if( local_tx_shift_reg & 0x01 )
      TX_PORT &=~ (1<<TX_PIN);
   //shift the TX shift register one bit to the right
   local_tx_shift_reg >>= 1;
   //if the stop bit has been sent, the shift register will be 0
   //and the transmission is completed, so we can stop & reset timer0
   if(!local_tx_shift_reg)
      TCCR0B = 0;
     // TCNT = 0;
The ISR was there, I miss copied into the forum.
Initially I did not use Crystal, because I in am using PLL mode setting in the switch. Since this is confusing.
I change to 8MHz at the fuse setting, 62, D7, EE.  Then I try, it doesnt show anything on the scope of PB0. I change the 8MHz program to below.
My terminal program did reflect back what I type if I tied RX and TX together.
#define F_CPU 8000000UL
#define TX_DDR  DDRB
   TCCR0B |= (1<<CS01) ;
    while( *string ){
void UART_init(){
   //          | 0|0 | 0 |  0  | 0    | 0    |  1   | 0    //8
   //use internal 8MHz, timer will clock at 1MHz
   //Count Value = 104us x 1M = 104
   OCR0B = 104;
   //enable interrupts
   sei();
   UART_init();
    _delay_ms(100);
   return 0;
      TCCR0B = 0;
     // TCNT = 0;
Why would TX_DDR_PIN be something different to TX_PIN ?!? That opens the potential for making one pin "output" but then actually driving the data on another pin?!?
#define TX_DDR      DDRB
A misunderstanding that PINB0 is somehow different from DDB0, perhaps ... ?
EDIT
There was a thread about it recently: https://www.avrfreaks.net/forum/how-read-input-particular-bit-port
add PORTB0 and PB0 to the list ...
I saw the code miss the start bit. I added the code
  local_tx_shift_reg &=~(1<<0);//start bit
after the stop bit line. Anyhow, still nothing from the scope.
How many PIN is require to connect to the Serial hardware module ?  So far, I only connect PB0 to RX. GND, 5V.
Have you tried the unmodified code first?
Always best to spend some time with the original to gain understanding before trying to hack it
It also means you have a working version to compare against ...
I have the continuous pulse out from the scope. The hardware module TX LED is continuous blinking. I think the Studio Serial Terminal have problem, doesnt display anything and was always reseting the Atmel Studio. I cant use putty, any other hyper serial terminal I can use for Window system ?
Just do this:
#define F_CPU 16e6
int main(void) {
    DDRB = (1 << 0);
    while (1) {
        PORTB ^= (1 << 0);
        _delay_ms(100);
What do you see on the scope? If nothing then that would appear to be the core of the problem !
If something is seen then one would then need to question whether the flow of execution is making it as far as your ISR().
(this is where debuggers come into their own! The 461 has debugWire - you may want to explore what would be involved in making use of that!)
again, that's a place where having a known-good reference would help you
Where, exactly?
Post a trace (if it's a digital scope, use it's trace capture facility - far better than a photo!)
hamisu wrote:
I cant use putty
Why not?
Loads!
See: https://www.avrfreaks.net/commen...
I use another Serial Terminal, I only see continuous ............ Look like the timing is wrong ?
Indeed - see Tip #2 in my signature.  Also FAQ #3 in clawson's
You said you've got a scope - so you should be able to see what the timing is.
Hint: continuously transmitting 'U' gives a nice signal for looking at on a 'scope ...
Where, exactly?
hamisu wrote:
I cant use putty
Why not?
Loads!
Putty does not response on setup. Just hang there.
It's too soon to be looking at putty if your scope shows there aren't any pulses on the line - what were you expecting putty to show if there is NO activity on the wire.
You have to solve problems by taking it a small step at a time.
For my money that starts by "wiggling the wire" using software in the micro, then looking for wire wiggling activity on the scope. See #14. If something as fundamental as that won't work then UART won't work and putty definitely won't show anything.
(BTW if you want to do a project that involves using a UART why would you pick a chip that does not actually have a UART?!)
Absolutely!
And, as this thread demonstrates, it's not trivial - so is it really worth the effort ?
It's not like chips with UARTs are rare or expensive these days ...
It's not too bad if you take it step-by-step, almost like good exercise.  As a practical matter--a built in UART wins hands-down.
Why fool with the PLL and other clock messing around???---start with a simple xtal & one major issue is put to rest...you can get a fancy source or scheme later.
Could this be a simple case of the clock/8 fuse setting causing the baud rate to not be what the OP expects it to be?
So this would indicate that some thing is leaving the port pin, as suggested above, write a simple test program to send the letter "U" over and over again, this will produce a square wave signal you can easily measure the bit time of the data that is sent, to verify your baud rate beliefs.
+1
clawson wrote:
#define F_CPU 16e6
int main(void) {
    DDRB = (1 << 0);
    while (1) {
        PORTB ^= (1 << 0);
        _delay_ms(100);
Hi, this code is working perfectly with train of square pulse display on the scope.
When I try the debug-wire, I am not very good at it. It seem the code is stuck at second while loop here.
    while( *string ){
        while(tx_shift_reg);  //<=====  stuck here....
Why do you need that?  Send out some chars & see if the proper bits are present and the timing is correct...that tells you if you are really sending, at least for getting it going.
Like any skill, it does take some learning & practice.
That's why I recommend it's one of the things you should learn right from the beginning: https://www.avrfreaks.net/commen...
    while( *string ){
So it thinks that tx_shift_reg is never getting cleared.
So look into why that might be:
  • what should be clearing it?
  • why is that not happening?
It is declared as volatile, isn't it ... ?
https://www.avrfreaks.net/forum/tutcoptimization-and-importance-volatile-gcc
If your chip has debug, why would you not use it?!
But, agreed, to answer the problem of #16 - the oscilloscope is the tool for that job.
It looks like Cliff might already have answered that right back at the start of the thread:
Andy, he said that was just an omission from posting - see the complete code in #8
The obvious way to proceed if using debugWire to me would therefore seem to be to put a breakpoint in the top of that ISR and see (a) is it even hit (ie has the timer interrupting been correctly configured and enabled) and (b) if it reaches the ISR what path does it take through it? As the interrupts occur do the bits in tx_shift_reg slowly move >> and if they do why does it never reach the tx_shift_reg==0 state which would break it from the while() wait loop?
From Post#7
You are using COMPB interrupt vector and enabling the interrupt on the OCF0B Flag while the datasheet specifies OCF0A.
11.7.2 Clear Timer on Compare Match (CTC) 8-bit Mode   (ATtiny461A Datasheet - 8197C–AVR–05/11)
In Clear Timer on Compare or CTC mode, see Table 11-3 on page 76, the OCR0A Register is
used to manipulate the counter resolution.
Also
An interrupt can be generated each time the counter value reaches the TOP value by using the
OCF0A Flag.
Oh....Chuck is right that the OCR0B cannot be used for Compare match for CTC mode.  Only OCR0A is used for CTC mode. When I change the code to the OCR0A, the scope output is shown as attached file. (I still cant embed image in the media browser, always error). But the output from the serial terminal show only black background "?"
Somehow, the reading value is not correct.  I attached the output of the terminal as well.
Actually i wanted to use OCR0B because my OCR0A already used for millis counting.
Can you read out and post the fuse settings for the  ATTiny461A?
Also, Please post the current source code.
This is the code.
#define TX_DDR  DDRB
    while( *string ){
void UART_init(){
   TIMSK |= (1<<OCIE0A);
   OCR0A = 104;//i change to 103 also the same.
   //enable interrupts
   sei();
   UART_init();
    UART_tx_str("U\n");
    _delay_ms(100);
   return 0;
ISR(TIMER0_COMPA_vect)
      TCCR0B = 0;
     // TCNT = 0;
Ummmm why didn't you show the clock settings  ?  we don't want ot see spien, we want to see the clock selections!!
This one ?
It should be very easy to spit out some characters on the uart with no more than 10 lines of code.  Even in asm , it might only be 2 dozen instructions to set up  & send out a little test stream.
Actually I dug around and found some simple examples....perhaps the port direction need set too, but you can see, there is not much to it....at least to get the ball rolling
setup_uart:ldi r16, 5  ; write correct clock divider value
	  out UBRR, r16
          ldi r16, 0b00011000 ;set Rx and Tx enable bits
          out UCR, r16 ; write them to the UART Control Register
tx_uart:  in r17, USR
          sbrs r17, UDRE   ;check if ok/ready to send something
          rjmp tx_uart
          ldi R16, 'Q'  ;send out QQQQQ forever
          out UDR, r16
          rjmp tx_uart
That's more or less all that's needed to start spitting something (anything!) out the uart to see it do something
Don't start off by making a task of a few lines so short & simple turn into pages and pages of stuff & fluff.  ...Concentrate on making actual progress.  Rememebr, evrything you type is a chance for a typo.
Well, obviously , you prob want to turn off the divide by 8---why do you want to run the AVR at 1 MHz?  Also, as mentioned, you make a big mistake by starting with the ratty internal oscillator...might work...might not...so if you get no results...who knows (if it does work, then claim your prize).
But there is no UART in this ATTiny461A.
Did you try to paste the image - as noted in Tip #1 ?
So it is a digital scope - but you didn't do that?
So what character do you think it should be?
Have you analysed your scope trace and asked yourself:
  • What, exactly, is the actual baud rate there? [1]
  • What character does that trace represent?
The Sparkfun tutorial linked in Tip #2 shows you how to "read" the UART waveform ...
EDIT
[1] your scope probably has features to easily measure the pulse widths (possibly also frequency);
Also, see the Hint in #17 (also #22) on how to get a nice, regular waveform ...
So, again, why on earth did you choose that chip if your project needs a UART ?
EDIT
But it does have USI:
Hold on. Your fuses say "int RC" and "ckdiv8". The first selects 8MHz, the second divides it by 8. So your AVR is running at 1MHz. Therefore do not use:
However I don't think this is the root of the problem as I think the only thing using F_CPU is going to be:
    UART_tx_str("U\n");
    _delay_ms(100);
So it just means there will be an 800ms delay between transmission attempts rather than 100ms. Not fatal.
However it did make me study the timer set up. The first thing that is confusing is this:
The first part of the comment is confusing, talking about a 16MHz clock. Don't leave "dead" comments that are wrong. It just misleads the maintenance engineer. The second part of the comment has all the signs of being right but then the actual OCR setting is not found after this. So that part of the comment is in the wrong place. You may say that is OK but then you have:
So at the end is where OCR0A is finally set to the right 104 as explained in the (right part) of the previous comment, but this OCR0A setting is proceeded by comment nonsense that once again talks about the calculation for 16MHz.
So in summary I'd suggest:
void UART_init(){
   //enable interrupts
   sei();
Except that even that is "wrong". Don't bury the setting of the global I bit in SREG (that is sei()) within a peripheral init function like UART_init(). Bring the sei() out to main():
   UART_init();
   // all peripherals now configured so enable interrupts...
   sei();
This way, if you start to use other peripherals you can call there XXX_init() functions in any order but only when they are all complete do you enable interrupts. Otherwise if you had UART_init() being called before some other ADC_init() or SPI_init() or whatever it would have the nasty consequence of enabling interrupts before that other peripheral had finished configuring its own interrupt.
Anyway that is not the actual problem either.
But this is:
The comment on this TCCR0B setting is exactly right. Using CS01 does use a /8 prescaler whereas CS00 does not. But the /8 that was being used is all part of that old 16MHz calculation. They worked out the right OCR0A value for 16MHz but it also relied on the timer being run at 1/8th F_CPU speed and that is still happening.
So just make this:
   //start timer0 with a prescaler of 1
   TCCR0B |= (1 << CS00) ;
and then the OCR0A = 104 value should deliver 104us interrupts.
(but I still think you should use a micro that has a UART if your project is based around the use of a UART!!)
Ah, I see again, my bonehead reading,  I was just glancing at the code & forgot the beginning.   I'm Thinking why so much length to spit out some char!.
Maybe so much commentary becomes blinding.  Calling everything Uart...leads the unwary to a wrong conclusion!
If you kill the divide by 8, you may finally have your stroke of luck
From  Post#32
void UART_init(){
   //enable interrupts
   sei();
You are showing a "div by 8" for TCCR0B to result in 1MHz  to the counter.
But the Fuse LOW.CKDIV8 fuse is checked so the 8MHZ is already divided by 8 for 1MHz clock
so your counter gets a 125KHz clock instead of a 1MHz clock.
Your can change TCCR0B to "div by 1"  or you can reprogram the fuses to uncheck the LOW.CKDIV8 fuse.
Also, since you are using the internal 8MHz RC oscillator, you may need to calibrate it.
Well that would get over the TCCR0B thing but you'd just be removing one of the /8s to have it put back in another. I'd sort of the CS01 versus CS00 thing first and then worry about CKDIV8 later.
Finally it work. The clock shall not divide by 8.  Sorry for my stupidity.
I can get my scope to save the data out because the storage external and disk management not activated as shown below. even I plu in the usb drive and restart.
I also try using USB wire at the back, it does not shown any internal save files as well.
That has caught just about everyone...in fact we wear a badge of honor & special pin for experiencing it.
Oh well - you tried.
I'd suggest that it's worth pursuing this; being able to capture traces is a Really Useful Thing - not just for forum posts.
I've found Rigol support to be pretty helpful - have you contacted them?
I brought the Rigol from a second hand seller equipment seller shop.  The Model is Rigol DS1102D which suppose to have Logic Analyser. But there is no LA  cable, I thought the cable is cheap but finally found the cable is very expensive.
One question I wish to ask since the data transfer is "U", will I be able to see the Binary code of "U" in the oscilloscope ?  Or I need to have Logic Analyser ?
Still worth an email to Rigol support.
If you're just using it as an oscilloscope, then it will just show you the voltage levels vs time.
But you can easily decode that manually - see the linked tutorial.
You would have to study the User Manual to see if it can do Async Serial Decode on the scope analogue channel inputs.
Manuals can be downloaded online: https://int.rigol.com/ - see the 'Support' tab
See also: https://www.rigolna.com/contact-us/ - even though I'm outside the US, they have been helpful.
EDIT
I have found that mine will sometimes not "like" a particular USB stick - so have you tried some different ones?
That looks like two characters were sent, "U" and a control character ACK (0x06)
