Confusion about TWI interrupt on tinyAVR 2
4 posts / 0 new
Hello, I've been reading documentation about master mode TWI of tinyAVR 2 and found TWI Master Operation diagram. It seems to indicate that interrupt is only raised before M1 and M2. When reading the description of M4 I've noticed that it also seems to raise the interrupt. Does M4 raise the interrupt? If M4 raises the interrupt what is the meaning of "Interrupt flag raised" diamond on the diagram? I've added relevant images to the attachments, I had problem with adding them directly to the post.
Assuming tinyAVR2 is similar to the AVR-0 series, with which I am familiar, the interpretation is that the associated flag is set in the status register and if the associated interrupt is enabled, it is triggered.  If the interrupt is not enabled, you should be polling the associated status register.
That also seems to be the case in tinyAVR2. I'm just confused about the meaning of "Interrupt flag raised" diamond because it's not present in every place the interrupt flag is raised so it seems meaningless.
There are only 2 interrupts- read and write, RIF/RIEN and WIF/WIEN, so nothing of interest (where you need to do something) happens until either of those flags are set. Once you get an R/WIF flag then its time to check all the flags.
You can treat these flags 'simply' if wanted-
for a RIF, if STATUS == RIF|CLKHOLD|OWNER , then is a 'good' read interrupt
for WIF, if STATUS == WIF|CLKHOLD|OWNER , then is a 'good' write interrupt
anything else is an error of some kind, and in most cases it does not matter much why the flags are not correct, you simply try again.
