Atmel Studio puts wrong name in auto-generated file header comment.
8 posts / 0 new
I used 'New Project...' from the AS7 'Start' page, then chose 'GCC C Executable Project'
It creates the project, and a main.c file containing the usual "skeleton":
But it's put the wrong name in the automatically-generated header comment, Gromit!
In this case, it's put 'uart.c' - when it's actually 'main.c'
In general, it puts '<project-name>.c' - but the file name is always 'main.c'
Not a big deal, of course - but not right.
When I create a new file, it does put the correct name into the automatically-generated header comment.
Note to self: maybe some clues here to fix it:
Go on.   It seems perfectly appropriate to me.
I created a project called nobbyv_twi and AS7.0 creates a "main.c" file with a comment block saying nobbyv_twi.c,  Created,  Author
I immediately rename "main.c" to "nobbyv_twi.c"
Yes,  I would prefer a new project to create "project.c" in the first place.
But hey-ho,  some people like having multiple "main.c" files in a solution.
p.s. "uart" seems an unusual sort of name for a project.   I would expect uart.c to be library file and "uart_andy" to be a project name.
david.prentice wrote:
Go on.
did you not read the OP?
Go on!  It's created a file called X.c - so why on earth would it then write a comment saying that it's called Y.c ?!
From Cliff's recent post which I linked, I suspect it's probably just used the wrong $blah$ token ..
Indeed. IIRC, it was the client's choice of name.
Likewise.
I guess the linked post from Cliff might also give hints on how to achieve that ...
It seems a common IDE or Wizard feature.   i.e. create a "main.c" file
Judging by the sheer number of GCCApplication1 projects there would be a lot of GCCApplication1.c files
Yes,   you could write a more appropriate template.
https://onlinedocs.microchip.com... shows the macros.
I think this is a case "can't please everybody all of the time"
Oh, personally I would put F_CPU in the Project Symbols with any template.    Much like AS4.xx did
However it is far too late to do anything like that in AS7.0 now
Ah ha - I was just about to point you in the direction of that!
Rather curiously the placeholder seems to be called $safeitemname" and is suppose to be the name of the project (like GccApplication1 or something).
Confirmed: https://www.avrfreaks.net/commen...
