SAM D10 - Event generation from EIC to TC1
3 posts / 0 new
Hello everyone,
I'm a newbie in SAM program. I want to know Events functionalities. I'm trying to generate an event on channel 0 from a external button (on EIC 5). Then the event0 have to  increment TC1 counter.
  • First step work OK: when button is pressed EXTIN5 bit in INTFLAG register is set
  • Second step doesn't work: TC1 is not configured yet to handle the event 0. Then when button is pressed and EIC generate event I don't see CHBUSY0 bit set in CHSTATUS register
EIC 5 configuration code:
void Eic5_init()
    /* Synchronous clock already enabled for default */
	//PM->APBBMASK.reg |= PM_APBBMASK_PORT;
	/* PA25 port configuration */
	PORT_REGS->GROUP[0].PORT_DIRCLR = PORT_PA25;
	PORT_REGS->GROUP[0].PORT_PINCFG[PIN_PA25] = PORT_PINCFG_PMUXEN(1) | PORT_PINCFG_INEN(1);
	GCLK_REGS->GCLK_CLKCTRL = GCLK_CLKCTRL_ID_EIC | GCLK_CLKCTRL_GEN_GCLK2 | GCLK_CLKCTRL_CLKEN(1);
	/* Abilito il clock sincrono per EIC_REGS: già abilitato di default dopo il reset */
	//PM->APBAMASK.reg |= PM_APBAMASK_EIC_REGS;
	/* Configuro evento sensibile al fronte di salita del pin */
	EIC_REGS->EIC_CONFIG[0] = EIC_CONFIG_SENSE5(EIC_CONFIG_SENSE5_RISE_Val);
	/* Abilito il pin su evento 0 */
	EIC_REGS->EIC_EVCTRL = EIC_EVCTRL_EXTINTEO0(1);
	/* Abilito EIC_REGS */
	EIC_REGS->EIC_CTRL = EIC_CTRL_ENABLE(1);
	while(EIC_REGS->EIC_STATUS & EIC_STATUS_Msk);
Event 0 configuration code:
void EvSys0_init()
	/* Enable Asynchronous clock for Evsys */
	GCLK_REGS->GCLK_CLKCTRL = GCLK_CLKCTRL_ID_EVSYS_0 | GCLK_CLKCTRL_GEN_GCLK2 | GCLK_CLKCTRL_CLKEN(1);
	/* Enable Synchronous clock for Evsys */
	PM_REGS->PM_APBCMASK |= PM_APBCMASK_EVSYS(1);
	/* Reset Evsys */
	EVSYS_REGS->EVSYS_CTRL = EVSYS_CTRL_SWRST(1);
	while (EVSYS_REGS->EVSYS_CTRL & EVSYS_CTRL_SWRST_Msk);
	/* User configuration */
	EVSYS_REGS->EVSYS_USER =    ((EVSYS_USER_CHANNEL_0_Val + 1) << EVSYS_USER_CHANNEL_Pos) |	//User listen on channel 0
                                EVSYS_USER_USER(0x0A);                                          //User is TC1
	/* Channel configuration */
	EVSYS_REGS->EVSYS_CHANNEL = EVSYS_CHANNEL_EDGSEL_RISING_EDGE |  //On the rising edge
                                EVSYS_CHANNEL_PATH_SYNCHRONOUS |    //Synchronous path
                                EVSYS_CHANNEL_EVGEN(0x11) |         //EXTINT5 generator
                                EVSYS_CHANNEL_CHANNEL(1);           //Channel 0
main code:
    /* Initialize the SAM system */
    //SystemInit();
	__enable_irq();
	PORT_REGS->GROUP[0].PORT_DIRSET |= PORT_PA09;
	PORT_REGS->GROUP[0].PORT_OUTCLR |= PORT_PA09;
	/* Initialize clocks */
	DFLL48M_init(false);	/* Synchronous clock */
	OSC8M_init();			/* Asynchronous clock */
    EvSys0_init();
	Eic5_init();
	//Tc1_init();
#if 0
	EVSYS_REGS->EVSYS_CTRL |= EVSYS_CTRL_GCLKREQ(1);
	EVSYS_REGS->EVSYS_CHANNEL |= EVSYS_CHANNEL_CHANNEL(1) | EVSYS_CHANNEL_SWEVT(1);
#endif
    while (1)
		PORT_REGS->GROUP[0].PORT_OUTSET |= PORT_PA09;
		asm("nop");
Where is my mistake?
Thank for your reply
Seems some non-standard register access is going on in your code but surely this must be wrong :
The event for EXTINT5 should be enabled not EXTINT0.
/Lars
Thank you Lars (again) for your reply. The mistake were 2:
//EIC_REGS->EIC_EVCTRL = EIC_EVCTRL_EXTINTEO0(1);
EIC_REGS->EIC_EVCTRL = EIC_EVCTRL_EXTINTEO5(1);
and:
                                //EVSYS_CHANNEL_CHANNEL(1);           //Channel 0
                                EVSYS_CHANNEL_CHANNEL(0);           //Channel 0
Now work!
Sorry, but there aren't very resources on the web for programming SAM devices in bare C
The only one I have found is microchipdeveloper site and......this forum of course
