libvmcu - Virtual MCU Library
21 posts / 0 new
Total votes: 2
Hello again,
Months ago I've started a changelog for the simulator I was working on. Recently I decided to detach the engine from the simulator in order to create a library out of it. I've created a new changelog since the library has nothing to do
with the simulator.
libvmcu is a library for static and dynamic analysis of AVR binaries.
It can be used to create regression tests for embedded systems or to analyze AVR programs on assembly level. You can build your own tools too.
There is also a Java binding, that supports basic functionality.
Features:
Cycle accurate realtime Simulation
Cycle accurate realtime simulation of the microcontroller including its peripherals.
Decode, Decompose, Disassemble, Analyze
The pipeline offers an interface for each stage: decode, decompose, disassemble and analyze. Stages can either operate on a single opcode or a whole binary.
Combine Static and Dynamic Analysis
Perform a static analysis on your binary to receive additional information, for example which SFRs are used by the program. Then, use this information to improve your dynamic analysis.
No further dependencies
libvmcu comes with no further dependencies, thus allowing easy setup and easy usage.
Examples:
       Printing disassembly of an intel hex file
int main(void) {
    /* ignoring checks for this example */
    vmcu_report_t *report = vmcu_analyze_ihex("file.hex");
    for(int32_t i = 0; i < report->progsize; i++)
        printf("%s\n", report->disassembly[i].mnem);
    vmcu_report_dtor(report);
    return EXIT_SUCCESS;
       Printing jumpers/callers of potential labels
int main(void) {
    for(int32_t i = 0; i < report->nlabels; i++) {
        vmcu_label_t *lx = &report->labels[i];
        printf("Label %d @ 0x%04x called/jumped by:\n", lx->id, lx->addr);
        for(int32_t j = 0; j < lx->ncallers; j++)
            printf("0x%04x\n", lx->caller[j].addr);
        printf("\n\n");
       Extracting details from opcode
int main(void) {
    vmcu_plain_t p;
    vmcu_disassemble_bytes(0xd8e0, &p);
    const VMCU_IKEY key    = p.key;        // VMCU_LDI
    const uint32_t opcode  = p.opcode;     // 0xe0d8 (big endian)
    const uint16_t addr    = p.addr;       // 0x0000 (undefined)
    const bool dword       = p.dword;      // false
    const bool exec        = p.exec;       // true
    const char *mnemonic   = p.mnem;       // ldi r29, 0x08
    vmcu_operand_t *src    = &p.src;
    vmcu_operand_t *dest   = &p.dest;
    VMCU_OPTYPE src_type   = src.type;     // VMCU_IMM8
    VMCU_OPTYPE dest_type  = dest.type;    // VMCU_REGISTER
    const uint8_t src_val  = src.value;    // 0x08
    const uint8_t dest_val = dest.value;   // (r)29
       Finding endloops (rjmp -1)
int main(void) {
    for(int32_t i = 0; i < report->progsize; i++) {
        vmcu_plain_t *p = &report->disassembly[i];
        if(p->opcode == 0xcfff) // rjmp -1 (big endian)
            printf("Endless loop at address 0x%04x\n", p->addr);
       Unittest: Testing interrupt frequency of driver/led/led.hex
#define TESTFILE  "../../driver/led/led.hex"
#define PORTB     0x0025
#define PB5       0x05
#define bit(v, b) ((v & (1 << b)) >> b)
int main(const int argc, const char **argv) {
    uint8_t led;
    vmcu_report_t *report = vmcu_analyze_ihex(TESTFILE);
    vmcu_system_t *sys    = vmcu_system_ctor(report);
    do {
        vmcu_system_step(sys);
        led = vmcu_system_read_data(sys, PORTB);
    } while(bit(led, PB5) == 0x00);
    const double f    = 16000000U;
    const double c    = sys->cycles;
    const double time = (c / f);
    assert((0.95 <= time) && (time <= 1.05));
    printf("Time between LED toggle: %lf [s]\n", time);
    vmcu_system_dtor(sys);
// [Expected]    0.95 [s] <= t <= 1.05 [s]
// [Test Result] Time between LED toggle: 1.000021 [s]
==> Test passed.
Note that, this library is a work in progress, so examples might change a bit.
https://github.com/Milo-D/libvmc...
Update (v.0.7.3)
VCD Trace tool written with libvmcu by pointbazaar
  • libvmcu supports xrefs (cross reference from) (this replaces vmcu_caller_t)
  • bug fix in 'or' assembly instruction.
  • merged VCD trace tool (driver) by pointbazaar. This driver is able to trace memory values while simulating an AVR binary.
printing xrefs of potential labels
int main(void) {
        printf("0x%04x\tL%d\n\n", lx->addr, lx->id);
        for(int32_t j = 0; j < lx->nxrefs; j++) {
            vmcu_xref_t *x = &lx->xrefs[j];
            printf(" xref from 0x%04x ", x->p->addr);
            printf("(%s)\n", x->p->mnem);
        printf("\n");
Output:
0x0000  L0
 xref from 0x0051 (jmp +0 ; PC <- 0x0)
0x0034  L1
 xref from 0x0000 (jmp +52 ; PC <- 0x34)
0x0040  L2
 xref from 0x0044 (brne -5 ; (Z = 0): PC <- PC - 0x5 + 1)
0x0042  L3
 xref from 0x003f (rjmp +2 ; PC <- PC + 0x2 + 1)
0x0049  L4
 xref from 0x004c (brne -4 ; (Z = 0): PC <- PC - 0x4 + 1)
0x004a  L5
 xref from 0x0048 (rjmp +1 ; PC <- PC + 0x1 + 1)
0x0051  L6
 xref from 0x0002 (jmp +81 ; PC <- 0x51)
 xref from 0x0004 (jmp +81 ; PC <- 0x51)
 xref from 0x0006 (jmp +81 ; PC <- 0x51)
 xref from 0x0008 (jmp +81 ; PC <- 0x51)
 xref from 0x000a (jmp +81 ; PC <- 0x51)
 xref from 0x000c (jmp +81 ; PC <- 0x51)
 xref from 0x000e (jmp +81 ; PC <- 0x51)
 xref from 0x0010 (jmp +81 ; PC <- 0x51)
 xref from 0x0012 (jmp +81 ; PC <- 0x51)
 xref from 0x0014 (jmp +81 ; PC <- 0x51)
 xref from 0x0016 (jmp +81 ; PC <- 0x51)
 xref from 0x0018 (jmp +81 ; PC <- 0x51)
 xref from 0x001a (jmp +81 ; PC <- 0x51)
 xref from 0x001c (jmp +81 ; PC <- 0x51)
 xref from 0x001e (jmp +81 ; PC <- 0x51)
 xref from 0x0020 (jmp +81 ; PC <- 0x51)
 xref from 0x0022 (jmp +81 ; PC <- 0x51)
 xref from 0x0024 (jmp +81 ; PC <- 0x51)
 xref from 0x0026 (jmp +81 ; PC <- 0x51)
 xref from 0x0028 (jmp +81 ; PC <- 0x51)
 xref from 0x002a (jmp +81 ; PC <- 0x51)
 xref from 0x002e (jmp +81 ; PC <- 0x51)
 xref from 0x0030 (jmp +81 ; PC <- 0x51)
 xref from 0x0032 (jmp +81 ; PC <- 0x51)
I am currently looking for contributors for the following submodules:
Bindings
I am planning a binding for python. A python binding would allow us
to examine and simulate AVR binaries (or parts of it) without having to
compile and link a program. It would be a very interactive way of analyzing
and simulating binaries.
Bindings need to be maintained, since the libvcmu interface can change over time.
In general, a binding forms a subsystem of the repository for which
you would be responsible.
If the binding can not be built for a longer time, it is no problem, the binding becomes
archived until someone agrees to resume.
Bindings for other languages ​​are not planned, but I would have
nothing against it, as long as these are also maintained. Currently pointbazaar maintains the Java Binding.
Bindings require in general, because the library interface
can change and you have to adjust the binding, high effort.
Driver
Drivers, on the other hand, are less expensive in time. If you have little time
but still want to contribute, creating a driver might be the right choice.
A driver is an utility or example program, that fulfills certain functions by using the libvmcu library.
An example of a driver would be the "findisr" driver, which
locates ISRs in an AVR binary by using libvmcu.
There are no precise specifications for the drivers. You can create anything you want as long as
it combines libvmcu functions in order to achieve something new.
I will maintain the drivers afterwards to ensure that they withstand library changes.
Tests
More testing.
Generally there are so many tests
needed that I won't be able to keep up with it on my own.
Thanks for reading.
You might want to look at other efforts and coordinate, etc.  Here is the list I have.
   + https://github.com/buserror/simavr
   + https://www.nongnu.org/simulavr/
   + https://github.com/ghewgill/emulino/
   + http://www.avr-asm-tutorial.net/avr_sim/index_en.html
   + https://github.com/Milo-D/libvmcu-Virtual-MCU-Library
- Improved SFR analyzer module
  - added vmcu_sfr_t to vmcu_report_t
  - added vmcu_xref_t to vmcu_sfr_t
  - removed mnemonic manipulation in sfr analyzer
  - sfr analyzer is now collecting SFRs and storing xrefs
- Minor change in naming convention
  - using singular of structnames instead of plural
  - using prefix n_ for list counts
  - example: lists of structs in report: structname
  - example: list count of structs in report: n_structname
- Bugfix in occurence driver
- COMn(A/B)x bits are now overriding normal port function
      Printing SFRs and their xrefs
#define FILE "avr_filesystem/avr_filesystem.hex"
    vmcu_report_t *report = vmcu_analyze_ihex(FILE);
    for(int32_t i = 0; i < report->n_sfr; i++) {
        vmcu_sfr_t *sfr = &report->sfr[i];
        printf("SFR ID: %d\n", sfr->id);
        for(int32_t j = 0; j < sfr->n_xref; j++) {
            vmcu_xref_t *x = &sfr->xref[j];
        printf("\n");
       Output
SFR ID: 0
  xref from 0x0112 (out 0x01, r16 ; IO[addr] <- R16)
  xref from 0x011c (out 0x00, r16 ; IO[addr] <- R16)
SFR ID: 33
  xref from 0x011f (in r16, 0x31 ; R16 <- IO[addr])
SFR ID: 38
  xref from 0x0152 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x016f (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x018d (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x01a0 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x01c5 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x01df (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x01fc (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x020c (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x021c (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x0223 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x0264 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x026d (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x0296 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x029e (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x02e1 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x02e8 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x0357 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x03f4 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x03fd (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x04c2 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x04d0 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x04d8 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x0a35 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x0a44 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x0b65 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x0b96 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x0b9d (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x0c34 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x0c3a (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x0c41 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x0ca1 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x0caf (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x0cb6 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x0d24 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x0d33 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x0d8e (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x0d95 (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x12a4 (in r28, 0x3d ; R28 <- IO[addr])
  xref from 0x12ac (out 0x3d, r28 ; IO[addr] <- R28)
  xref from 0x12c6 (out 0x3d, r28 ; IO[addr] <- R28)
SFR ID: 39
  xref from 0x0151 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x0170 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x018e (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x01a1 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x01c6 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x01e0 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x01fd (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x020d (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x021d (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x0221 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x0262 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x026e (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x0297 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x029c (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x02df (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x02e9 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x0358 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x03f2 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x03fe (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x04c0 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x04d1 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x04d6 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x0a33 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x0a45 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x0b66 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x0b97 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x0b9b (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x0c32 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x0c3b (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x0c3f (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x0c9f (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x0cb0 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x0cb4 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x0d22 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x0d34 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x0d8f (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x0d93 (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x12a5 (in r29, 0x3e ; R29 <- IO[addr])
  xref from 0x12aa (out 0x3e, r29 ; IO[addr] <- R29)
  xref from 0x12c4 (out 0x3e, r29 ; IO[addr] <- R29)
SFR ID: 40
  xref from 0x014e (out 0x3f, r1 ; IO[addr] <- R1)
  xref from 0x021f (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x0222 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x0260 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x0263 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x029a (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x029d (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x02dd (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x02e0 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x03f0 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x03f3 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x04be (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x04c1 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x04d4 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x04d7 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x0a31 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x0a34 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x0b99 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x0b9c (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x0c30 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x0c33 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x0c3d (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x0c40 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x0c9d (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x0ca0 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x0cb2 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x0cb5 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x0d20 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x0d23 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x0d91 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x0d94 (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x12a8 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x12ab (out 0x3f, r0 ; IO[addr] <- R0)
  xref from 0x12c2 (in r0, 0x3f  ; R0 <- IO[addr])
  xref from 0x12c5 (out 0x3f, r0 ; IO[addr] <- R0)
Update (v.0.8.0)
- Added devices and device models
A device model is an abstraction over a microcontroller type. It contains MCU specific
data, like memory sections and layouts.
Each implementation of a virtual microcontroller has a device loader which fills the device model with data. The device model is then
used to supply the analyzer with all the relevant data it needs.
This feature might be the first step to bring static analysis to many different AVR microcontrollers.
Steps to add a new microcontroller to the static analysis:
  • create a new device arch/device/new_avr.c
  • create a device loader function called load_device_new_avr within arch/device/new_avr.c
  • fill the device model with MCU specific data within load_device_new_avr
  • connect the device loader to the device model constructor
That's it. new_avr should be now available for static analysis.
The device model currently only contains basic information and will be extended whenever new fields are required.
- added missing vmcu_ prefix for some functions (no name clashes possible anymore)
- added decoder tests (com -> sbic)
- some minor bug fixes
Device Model Example
    vmcu_model_t  *m328p  = vmcu_model_ctor(VMCU_M328P);       // ATmega328P
    vmcu_report_t *report = vmcu_analyze_ihex(argv[1], m328p);
        if(p->src.type == VMCU_REGISTER && p->src.value == 16) // filter src = r16
            printf("0x%04x\t%s\n", p->addr, p->mnem);
    vcmu_report_dtor(report);
    vmcu_model_dtor(m328p);
First we create a device model for the ATmega328P (vmcu_model_t *m328p). Now this model can be used to disassemble, analyze, etc. for a specific microcontroller, in this example the ATmega328P.
Can you elaborate on the use of static and dynamic analyses and what they achieve?
Hey Matt,
sure.
The dynamic analysis can be used to simulate small snippets or to create automated tests for the ATmega328 family. Although some few peripherals are supported, the simulation still lacks support for other peripherals like USART, ADC, etc. Other simulators are definitely better suited, especially since the simulation currently only focuses on the ATmega328 family. So if someone is purely interested in simulating AVRs, I would suggest another tool.
The static part takes care of the preparation of raw data, which can then be further processed by other programs. The goal here is to make it possible to interact programmatically with AVR source code.
Currently achieving
  •  extracting and classifying usage of special function registers
  •  extracting jump/call destinations (potential label position)
  • providing disassembly
  • classifying instructions
  • classifying and extracting operands
  • providing cross references within disassembly
Planned to achieve
  • subroutine analysis (start/end of a subroutine plus subroutine cross references, ...)
  • cycle analysis of ISRs and subroutines (min. cycles, max. cycles, average cycles)
  • controlflow graph in order to navigate statically through the disassembly
  • dead code analysis
  • dataflow analysis
  • instruction groups and subgroups (like arithmetic, controlflow, etc.)
  • instruction addressing modes
  • which flags a certain instruction affects
Edit: I must confess, I am interested in analyzing binaries. It might not be that interesting for everybody ;)
Thanks. Sounds like fun..
Update (v.0.8.1)
  • Added: Instruction Groups
    • arithmetic/logic instructions (VMCU_GROUP_MATH_LOGIC)
    • data transfer instructions (VMCU_GROUP_TRANSFER)
    • MCU control instructions (VMCU_GROUP_SYS_CTRL)
    • flow control instructions (VMCU_GROUP_FLOW)
    • bit and bit-test instructions (VMCU_GROUP_BIT)
  • rename vmcu_plain_t to vmcu_instr_t
    • this might be a more obvious name than "plain"
  • fixed some bugs
  • added decoder tests (sbis -> sez)
    • added decoder tests (sleep -> st(Y))
      instruction groups example (filtering all flow instructions in file.hex)
    vmcu_report_t *report = vmcu_report_ctor("file.hex", m328p);
        vmcu_instr_t *instr = &report->disassembly[i];
        if(instr->group != VMCU_GROUP_FLOW)
            continue;
        printf("0x%04x\t", instr->addr);
        printf("%s\n", instr->mnem);
      output
0x0000  jmp +52                   ; PC <- 0x34
0x0002  jmp +81                   ; PC <- 0x51
0x0004  jmp +81                   ; PC <- 0x51
0x0006  jmp +81                   ; PC <- 0x51
0x0008  jmp +81                   ; PC <- 0x51
0x000a  jmp +81                   ; PC <- 0x51
0x000c  jmp +81                   ; PC <- 0x51
0x000e  jmp +81                   ; PC <- 0x51
0x0010  jmp +81                   ; PC <- 0x51
0x0012  jmp +81                   ; PC <- 0x51
0x0014  jmp +81                   ; PC <- 0x51
0x0016  jmp +81                   ; PC <- 0x51
0x0018  jmp +81                   ; PC <- 0x51
0x001a  jmp +81                   ; PC <- 0x51
0x001c  jmp +81                   ; PC <- 0x51
0x001e  jmp +81                   ; PC <- 0x51
0x0020  jmp +81                   ; PC <- 0x51
0x0022  jmp +81                   ; PC <- 0x51
0x0024  jmp +81                   ; PC <- 0x51
0x0026  jmp +81                   ; PC <- 0x51
0x0028  jmp +81                   ; PC <- 0x51
0x002a  jmp +81                   ; PC <- 0x51
0x002c  jmp +83                   ; PC <- 0x53
0x002e  jmp +81                   ; PC <- 0x51
0x0030  jmp +81                   ; PC <- 0x51
0x0032  jmp +81                   ; PC <- 0x51
0x003f  rjmp +2                   ; PC <- PC + 0x2 + 1
0x0044  brne -5                   ; (Z = 0): PC <- PC - 0x5 + 1
0x0048  rjmp +1                   ; PC <- PC + 0x1 + 1
0x004c  brne -4                   ; (Z = 0): PC <- PC - 0x4 + 1
0x004d  call +130                 ; PC <- 0x82
0x004f  jmp +134                  ; PC <- 0x86
0x0051  jmp +0                    ; PC <- 0x0
0x0071  cpse r24, r1              ; (R24 = R1): PC <- skip
0x0072  rjmp +9                   ; PC <- PC + 0x9 + 1
0x007b  reti                      ; PC <- DATA[SP]
0x0081  rjmp -14                  ; PC <- PC - 0xe + 1
0x0085  rjmp -1                   ; PC <- PC - 0x1 + 1
0x0087  rjmp -1                   ; PC <- PC - 0x1 + 1
Update (v.0.8.2)
  • Added: interrupt vector analysis
    • finding vectors in disassembly at default table position
    • storing vector ID (VMCU_VECT enum), vector address and a xref-to vector's ISR
  • Added: vtable section in vmcu_model_t.
    • holds data related to the MCU's vector table
  • Created analyzer/util/util.h for frequently (> 1) used subroutines
    • moved get_abs_addr to analyzer/util/util.h:vmcu_get_abs_addr
      printing interrupt vectors and their xref-to
    vmcu_report_t *report = vmcu_analyze_ihex("file.hex", m328p);
    for(int32_t i = 0; i < report->n_vector; i++) {
        vmcu_vector_t *vect = &report->vector[i];
        vmcu_instr_t  *isr  = vect->xto->i;
        printf("Vector ID %d @ 0x%04x\n", vect->id, vect->addr);
        printf(" interrupt service routine at 0x%04x", isr->addr);
        printf("\n\n");
      output
Vector ID 16 @ 0x0020
 interrupt service routine at 0x03f5
Vector ID 17 @ 0x0022
 interrupt service routine at 0x008a
Vector ID 18 @ 0x0024
 interrupt service routine at 0x03c3
Vector ID 19 @ 0x0026
 interrupt service routine at 0x039d
This intrigues me - I can see by the names you are thinking of this in a very "C++ like" way. If so is C++ not the obvious choice ?
Hey clawson,
I've actually rewritten this project from C++ to C (one year ago). I like the simplicity and syntax of C. It was a personal choice ^^
v.0.8.6
- Added submodule for discovering strings in binary
- supporting ASCII encoding, and maybe UTF16 in the future
- structure vmcu_string_t represents a string found in the binary
  - holds string start address in flash memory
  - holds string length
  - holds actual bytes of string
- Bug fixes
Discovering strings in binary
    vmcu_model_t  *m328p  = vmcu_model_ctor(VMCU_DEVICE_M328P);
    for(int32_t i = 0; i < report->n_string; i++) {
        vmcu_string_t *str = &report->string[i];
        printf("Found string \"%s", str->bytes);
        printf("\" l = %d", str->length);
        printf(" @ 0x%04x\n", str->addr);
    printf("\nTotal strings found: %d\n", report->n_string);
Output
Found string "Welcome " l = 8 @ 0x092e
Found string "[1] Login\n" l = 11 @ 0x0933
Found string "[2] Memory management\n" l = 23 @ 0x0939
Found string "Please authenticate yourself with your hardware token\n" l = 55 @ 0x0946
Found string "Please insert token. (%d characters)\n" l = 38 @ 0x0962
Found string "Token can only contain the characters [A-Z/a-z/0-9]\n" l = 53 @ 0x0975
Total strings found: 6
Note that this example does not handle non printable bytes. You'll have to write your own small function to handle non printable bytes.
v.0.8.8
- Added: vmcu_mnemonic_t structure to vmcu_instr_t
  - replaces char *mnem
  - holds char literals (base, src, dest, comment)
  - base = instruction string ("ldi", "movw", etc.)
  - src = source operand string ("r29", "0xff", etc.)
  - dest = destination operand string ("r29", "0xff", etc.)
  - comment = comment string ("; r21 <- 0xab", "IF <- 0", etc.)
- Added: disasm driver with syntax highlighting (driver/disasm/)
- disassembler rewrite
- adjusted examples, drivers, readme
This change makes instruction printing more flexible. For example you can now choose your favorite syntax flavor (Intel, AT&T). It also allows easy syntax highlighting of different substrings within the mnemonic.
Downside is you need to write a small utility function in order to print a mnemonic.
Here is an example of a printer function
/* this snippet can be used to assemble and print an instruction */
void print_instruction(vmcu_instr_t *instr) {
    vmcu_mnemonic_t *mnem = &instr->mnem;
    printf("%s ",  mnem->base);
    printf("%s",   mnem->dest);
    if(instr->dest.type != VMCU_OP_NONE)
        printf(", ");
    printf("%s ",  mnem->src);
    printf("%s\n", mnem->comment);
And that's the new layout of the vmcu_instr_t structure
typedef struct vmcu_instr {                   ///< instruction structure
    struct {                                  ///< instruction core
        VMCU_IKEY key;                        ///< instruction key (instruction identifier)
        VMCU_GROUP group;                     ///< instruction group
    int opcode;                               ///< 16-bit or 32-bit opcode (todo: change type to uint32)
    int addr;
    bool exec;                                ///< instruction executable ?
    bool dword;                               ///< 32-bit instruction ?
    vmcu_operand_t src;                       ///< source operand (right operand)
    vmcu_operand_t dest;                      ///< destination operand (left operand)
    vmcu_mnemonic_t mnem;                     ///< disassembled mnemonic of instruction
} vmcu_instr_t;
Where this is the layout of the new vmcu_mnemonic_t structure
typedef struct vmcu_mnemonic {                ///< disassembled mnemonic structure
    char base    [7];                         ///< mnemonic base string (ldi, sts, etc.)
    char src     [9];                         ///< source operand string (r29, 0xff9a, etc.)
    char dest    [9];                         ///< destination operand string (r29, 0xff9a, etc.)
    char comment[40];                         ///< comment string (todo: make comments optional)
} vmcu_mnemonic_t;
As you can see, the biggest part of a mnemonic is the comment substring. I am planning to make comments optional by introducing conditional compilation in order to minimize memory usage.
v.0.8.9 - Rework and improvement of vmcu_operand_t and VMCU_OPTYPE
- VMCU_OP rework
  - rename to VMCU_OPTYPE
  - added new types to enumeration. Enumeration after rework:
    - VMCU_OPTYPE_NONE = -1 (no operand, therefore no type)
    - VMCU_OPTYPE_R,        (register operand)
    - VMCU_OPTYPE_RP,       (registerpair operand)
    - VMCU_OPTYPE_X,        (x pointer operand)
    - VMCU_OPTYPE_Y,        (y pointer operand)
    - VMCU_OPTYPE_Z,        (z pointer operand)
    - VMCU_OPTYPE_B,        (bit number 0-7)
    - VMCU_OPTYPE_K4,       (4-bit immediate)
    - VMCU_OPTYPE_K6,       (6-bit immediate)
    - VMCU_OPTYPE_K8,       (8-bit immediate)
    - VMCU_OPTYPE_IO5,      (5-bit I/O address)
    - VMCU_OPTYPE_IO6,      (6-bit I/O address)
    - VMCU_OPTYPE_D7,       (7-bit data address)
    - VMCU_OPTYPE_D16,      (16-bit data address)
    - VMCU_OPTYPE_P22,      (22-bit program address)
    - VMCU_OPTYPE_S7,       (7-bit signed displacement, program memory)
    - VMCU_OPTYPE_S12       (12-bit signed displacement, program memory)
  - similar types can be found at https://en.wikipedia.org/wiki/Atmel_AVR_instruction_set
- Added: VMCU_REGISTER - an enumeration of AVR general purpose registers (r0-r31)
- Added: vmcu_registerpair_t structure
  - this structure is able to represent a registerpair by holding
    - a VMCU_REGISTER low - low byte of pair
    - a VMCU_REGISTER high - high byte of pair
- vmcu_operand_t rework
  - vmcu_operand_t now consists of a
    - VMCU_OPTYPE - an enumeration of different operand types
    - value union - a c-union holding different kinds of operand values
- The value union of vmcu_operand_t contains
  - uint8_t k  for type = K4, K6, K8
  - uint8_t b  for type = B
  - uint8_t io for type = IO5, IO6
  - uint16_t d for type = D7, D16
  - uint32_t p for type = P22
  - int16_t s  for type = S7, S12
- disassembled .dw directive (= illegal opcode) does not have its opcode as source operand anymore
  - instead, an illegal opcode (.dw xxxx) has following attributes
    - instr->src.type  = VMCU_OPTYPE_NONE
    - instr->dest.type = VMCU_OPTYPE_NONE
    - therefore no operand values
  - in order to simplify printing these "instructions", I've decided to move the .dw value (xxxx)
    to instr->mnem.base. So the base mnemonic is now ".dw xxxx" with no operands.
- endloop driver (driver/endloop/) improvement
  - endloop driver is now able to detect unconditional and conditional endless loops
- adjusted driver code
- minor improvements
vmcu_operand_t after rework
typedef struct vmcu_operand {
    union {
        uint8_t k;
        uint8_t b;
        uint8_t io;
        uint16_t d;
        uint32_t p;
        int16_t  s;
        VMCU_REGISTER r;
        vmcu_registerpair_t rp;
    VMCU_OPTYPE type;
} vmcu_operand_t;
VMCU_OP after rework
typedef enum {
    VMCU_OPTYPE_NONE = -1,
    VMCU_OPTYPE_R,
    VMCU_OPTYPE_RP,
    VMCU_OPTYPE_X,
    VMCU_OPTYPE_Y,
    VMCU_OPTYPE_Z,
    VMCU_OPTYPE_B,
    VMCU_OPTYPE_K4,
    VMCU_OPTYPE_K6,
    VMCU_OPTYPE_K8,
    VMCU_OPTYPE_IO5,
    VMCU_OPTYPE_IO6,
    VMCU_OPTYPE_D7,
    VMCU_OPTYPE_D16,
    VMCU_OPTYPE_P22,
    VMCU_OPTYPE_S7,
    VMCU_OPTYPE_S12
} VMCU_OPTYPE;
Added VMCU_REGISTER enumeration
typedef enum {
    VMCU_REGISTER_NONE = -1,
    VMCU_REGISTER_R0,
    VMCU_REGISTER_R1,
    VMCU_REGISTER_R2,
    VMCU_REGISTER_R3,
    VMCU_REGISTER_R4,
    VMCU_REGISTER_R5,
    VMCU_REGISTER_R6,
    VMCU_REGISTER_R7,
    VMCU_REGISTER_R8,
    VMCU_REGISTER_R9,
    VMCU_REGISTER_R10,
    VMCU_REGISTER_R11,
    VMCU_REGISTER_R12,
    VMCU_REGISTER_R13,
    VMCU_REGISTER_R14,
    VMCU_REGISTER_R15,
    VMCU_REGISTER_R16,
    VMCU_REGISTER_R17,
    VMCU_REGISTER_R18,
    VMCU_REGISTER_R19,
    VMCU_REGISTER_R20,
    VMCU_REGISTER_R21,
    VMCU_REGISTER_R22,
    VMCU_REGISTER_R23,
    VMCU_REGISTER_R24,
    VMCU_REGISTER_R25,
    VMCU_REGISTER_R26,
    VMCU_REGISTER_R27,
    VMCU_REGISTER_R28,
    VMCU_REGISTER_R29,
    VMCU_REGISTER_R30,
    VMCU_REGISTER_R31
} VMCU_REGISTER;
Added vmcu_registerpair_t structure
typedef struct vmcu_registerpair {
    VMCU_REGISTER low;
    VMCU_REGISTER high;
} vmcu_registerpair_t;
Are you accounting for the possibility that your host computer may be big endian?
For example, if you load a little endian U16 address from the AVR code and increment it using your possibly big endian simulator CPU.
Some time ago, I loaded a few snippets into the simulator to test this case. As far as I know, it had no issues with the endianess.
Do you mean loading a 16-bit address from the flash via lpm and then incrementing the loaded address ?
v.0.8.10
- Added: vmcu_access_t
  - vmcu_access_t holds bitfields (representing booleans)
  - following bitfields are available
    - registers (true if instr reads/writes gpr)
    - flash     (true if instr reads/writes flash)
    - stack     (true if instr reads/writes stack)
    - io        (true if instr reads/writes io segment)
    - ds        (true if instr reads/writes data segment)
    - sp        (true if instr reads/writes stack pointer)
    - pc        (true if instr reads/writes program counter)
    - c_flag    (true if instr reads/writes carry flag)
    - z_flag    (true if instr reads/writes zero flag)
    - n_flag    (true if instr reads/writes negative flag)
    - v_flag    (true if instr reads/writes overflow flag)
    - s_flag    (true if instr reads/writes sign flag)
    - h_flag    (true if instr reads/writes halfcarry flag)
    - t_flag    (true if instr reads/writes t flag)
    - i_flag    (true if instr reads/writes interrupt flag)
  - NOTE: Although (stack, io, registers ⊂ ds), (stack = true) or (io = true)
    or (registers = true) does not imply (ds = true).
- Added: annotator stage in pipeline
  - this stage annotates instructions by adding additional information about
    the instruction itself, like groups and explicit/implicit read/write access.
- Added: rwaccess driver (driver/rwaccess/)
- Adjusted drivers, etc.
implicit/explicit read/write access example
/* A possible implementation of print_instruction can be found in the README */
        if(instr->writes.c_flag == true)
            print_instruction(instr);
        if(instr->reads.c_flag == true)
Possible Output
subi r18, 0x00     ; r18 <- r18 - 0x00
adiw r29:r28, 0x1a ; r29:r28 <- r29:r28 + 0x1a
sbci r23, 0xff     ; r23 <- r23 - 0xff - CF
cpc r19, r17       ; r19 - r17 - CF
I did some spot-checks on your code.   You are moving byte at a time around, so I think you should be OK.
In my simulator I use unions for manipulating 16-bit values a byte at a time, so the union layout depends on the host endianness:
typedef union {
  uint16_t w;				/* wide (16 bit) value, unsigned */
  int16_t ws;				/* wide (16 bit) value, signed */
  struct {
#if __BYTE_ORDER == __LITTLE_ENDIAN
    uint8_t lo;
    uint8_t hi;
#else
    uint8_t hi;
    uint8_t lo;
#endif
} wreg_t;
v.0.8.11 - Finally added the control flow graph (cfg)
libvmcu has now control flow graphs
- added: CFG - control flow graph
  - vmcu_cfg_t is the controlflow graph of libvmcu. It holds,
    - vmcu_cfg_t node*, a dynamic array of vmcu_node_t structures
    - node[0] is the entry node
      - a node consists of
        - vmcu_xref_t xto, a cross-reference to the corresponding instruction (xref-to)
        - vmcu_cfg_node_t *t, a node pointer for the true branch
        - vmcu_cfg_node_t *f, a node pointer for the false branch
    - int32_t used, a simple node counter, should be equal to report.progsize
- added: CFG example driver (driver/cfg/)
- using CMake now
- added syntax highlight for stepper driver
A controlflow graph will allow us to analyze and model functions, loops, cycles, ...
Example: Printing control flow of a binary
/* A possible implementation of print_instruction can be found in repository */
    for(int32_t i = 0; i < report->cfg->used; i++) {
        vmcu_cfg_node_t *node = &report->cfg->node[i];
        print_instruction(node->xto.i);
        if(node->t != NULL) {
            printf("true  -> ");
            print_instruction(node->t->xto.i);
        if(node->f != NULL) {
            printf("false -> ");
            print_instruction(node->f->xto.i);
        printf("\n");
Example Output:
         0x0000  .... f1f3  breq -2         ; (ZF == 1): PC <- PC + -2 + 1
true  -> 0x3fff   .... 839a  sbi 0x10, 3     ; IO[0x10, 3] <- 1
false -> 0x0001  .... 0fef  ldi r16, 0xff    ; r16 <- 0xff
true  -> 0x0002  .... 5817  cp r21, r24     ; r21 - r24
true  -> 0x0003  .... 19f4  brne 3          ; (ZF == 0): PC <- PC + 3 + 1
true  -> 0x0007  .... 0127  eor r16, r17    ; r16 <- r16 ^ r17
false -> 0x0004  .... a895  wdr             ; watchdog reset
true  -> 0x0005  .... 8895  sleep           ; circuit sleep
true  -> 0x0006  .... 0000  nop             ; no operation
true  -> 0x0000  .... f1f3  breq -2         ; (ZF == 1): PC <- PC + -2 + 1
