tinyAVR 2-series: read supply voltage
7 posts / 0 new
Hey all,
I'm currently migrating a project from series 0/1 to series 2 tinyAVRs. I'm now using the ATTINY1626. Migration worked fine, except for my code to read the VDD supply voltage (without external circuit), see AN2447. That's a crucial feature and I'm not sure if the series 2 AVRs can actually do it. The only information I found was that here:
https://github.com/SpenceKonde/megaTinyCore#internal-sources
Now I'm massively confused ;-) I can set VREF to 1.024V on the series 2 (1.1V on series 0/1), so that seems to be fine. But then what should I choose as internal voltage? Just ADC_VDDDIV10 instead of ADC_INTREF?! Will that work?
Best, Timm
As far as I read the data sheet, it seems that there is no problem.
If 1.024V is used for Vref and ADC_VDDDIV10 is measured with 10 bits without amplification, it is given by VDD = ADC_Result * 10 (mV).
You already have a working chip. Now let's write the test code and evaluate it.
Thanks, kasaban! I will test asap, but don't have the chips yet. Will give code + feedback here, so that future series 2 users might benefit from it :-) Just thought that maybe someone already has some experience/code with that.
Best, Timm
Looks like you can now work it multiple ways, but can probably do as before-
ADC Vref = Vdd
MUXPOS = DACREF0 (AC VREF, why they name it DAC-anything without a dac in sight, who knows)
You can set AC0 VREF to 1.024 just like you did 1.1v in avr0/1, and is also the default value so don't need to touch.
Your formula just needs a little tweak.
edit- #2 sounds better/simpler, and leaving half the resolution unused will not matter, plus its an easy formula that stays in one place (resolution not moving around due to changing vref).
ADC Vref = Vdd
Hi curtvm,
sounds great! Thanks for your help. Didn't know that I could also use DACREF0. I will try out both methods and will post tested code soon.
Best, Timm
Hi all,
finally assembled an ATTINY1626 and did some tests. Wanted to share the results:
  • MUXPOS =  ADC_VDDDIV10 did not work at all, measurement value did not change with the supply voltage
  • MUXPOS = DACREF0 works, but with a "magic number conversion" ((4096UL * 1024UL) / res) that I don't understand, but is very accurate between Vcc = 2V and 4.2V, tested with F_CPU = 1 MHz
#define TIMEBASE_VALUE					(uint8_t)ceil(F_CPU*0.000001)
uint16_t readyVoltageSeries2() {
	uint32_t res;
	ADC0.CTRLA = ADC_ENABLE_bm;
	//ADC0.CTRLB = ADC_PRESC_DIV2_gc; // DEFAULT setting, no need to change
	ADC0.CTRLC = VREF_AC0REFSEL_1V024_gc | (TIMEBASE_VALUE << ADC_TIMEBASE0_bp); // Vref = 1.024V
	ADC0.CTRLE = 100; // sample duration ((100 * 2) / F_CPU seconds), 1 MHz = 0.2ms
	ADC0.MUXPOS = ADC_MUXPOS_DAC_gc; // using DAC as MUX voltage, ADC_MUXPOS_VDDDIV10_gc doesn't work
	ADC0.COMMAND = ADC_MODE_SINGLE_12BIT_gc; // single mode with 12 bit
	ADC0.COMMAND |= ADC_START_IMMEDIATE_gc; // start conversion
	while(true) {
		if(ADC0.INTFLAGS & ADC_RESRDY_bm) { // wait until measurement done
			res = (uint32_t) ADC0.RESULT; // get raw adc result
			if(res == 0) { res = 1; }
			res = (4096UL * 1024UL) / res; // convert result to mV
			break;
	ADC0.CTRLA = 0; // disable ADC
	return ((uint16_t) res);
Best, Timm
You are using the VREF value for AC0REFSEL 1.024v, which is 0 (VREF_AC0REFSEL_1V024_gc = 0), so you are getting Vdd as adc vref (also a value of 0) which is the method used on previous avr0/1 (you are getting 1.024v from dacref0 since that is default for VREF_AC0). Which is why your formula works. To be clear- the peripheral VREF and the adc vref are not the same thing, and the clue in the define or enum is VREF_anything is for VREF registers.
