usb project
8 posts / 0 new
Hello
Are all Avr processors capable of being connected to a computer via usb?
m&m
Yes. Either by using an on-chip peripheral, a separate USB chip, or a USB to serial cable.
 Thank you! Brian Fairchild
I want to design a project to control a motor step by step through the computer
- Is atmel avr studio enough to accomplish a project like this?
m&m
A stepper motor? Yes, absolutely.
monir7000 wrote:
atmel avr studio
Did you mean Microchip Studio: https://www.microchip.com/en-us/development-tools-tools-and-software/microchip-studio-for-avr-and-sam-devices ?
Note the 'Getting Started' videos and hands-on training at the bottom of that page ...
ADDENDUM
It is the current name for the IDE formerly known as "Atmel Studio":
https://www.avrfreaks.net/forum/release-microchip-studio-702542
The answer applies to all microcontrollers - not just AVR:
Like this:
                           PCB
                          :     USB Converter        Microcontroller    :
|      |       USB        :                         |               |   :
|  PC  +<==========================================>+USB            |   :
This is the only case where you actually have a USB project
a separate USB chip
Like this:
                           PCB
|      |       USB        :    |             |      |               |   :
|  PC  +<=====================>+USB      UART+<====>+UART           |   :
Like this:
                           PCB
                          :                          Microcontroller    :
|      |   USB-to-UART    :                         |               |   :
|  PC  +<==========================================>+UART           |   :
In the last 2 cases, your project is entirely oblivious to the USB - it's just a UART project.
(USB-to-SPI and other converters are also available)
#USBtoPC
Just to say that Andy's pictures 1 and 2 (and maybe even 3 in the case of "Tiny"?) are effectively what an Arduino is.
So if you want a board with an AVR that has an easy USB connection to a PC then just buy an Arduino. A $3-$5 "Uno" is probably the easy place to start. Note that just because the board is an "Arduino" it does not tie you to doing all your development in the Arduino IDE, in C++, using the Arduino libraries. You can pick whatever language you like.
Of course Andy's pictures (and Arduinos) are ONLY about adding a CDC-ACM Class device to the micro. If you wanted some other USB class then only his first picture can make that possible. In that (picking an AVR that has USB "inside") allows you to emulate any USB device class like HID, MIDI, MSD, Audio, Printer, etc etc. [EDIT: in fact anything on this list: https://www.usb.org/defined-clas... ]
But for motor control I guess CDC-ACM (ie "UART") will be just fine.
+1
And that also gives you access to the vast wealth of Arduino examples, tutorials, shields, etc available on the interwebs.
An alternative might be an Xplained-Pro/Mini/Nano or a Curiosity Nano - which gives you the added benefit of a debugger:
                           PCB
                          :     Debug Adapter        Microcontroller    :
|      |       USB        :    |             |      |               |   :
+------+                  :    |        Debug+<====>+Debug          |   :
See: https://www.avrfreaks.net/commen...
Example: https://www.avrfreaks.net/forum/xplained-mini-mega328pb
