CanOpen / CiA anyone?
2 posts / 0 new
Hi all.
Just some kind of announcement. I'd like to know what the general interest in CanOpen is. I was thinking about publishing all the code but then again I need to do some documentation work, which doesn't make much sense for me if there isn't any real interest.
I wrote a complete stack in C which runs on the AT90Can128 devices. There are about 100 nodes active in my house which are used for shutters, light, door-locks and some fans. It's even possible to update devices via standard CiA messages in the running system without disturbing the communication using my CiA-bootloader.
Here are some pictures:
https://next.vtx.cloud/s/GT8aXdL...
Let me know what you think.
Regards.
Seems to come up ~ once a year: https://community.atmel.com/search/site/CanOpen?solrsort=ds_created%20desc&filter_by=9631
CAN in general probably comes up more often - but a simple forum search can't distinguish "CAN" (the bus) from "can" the plain English word.
Maybe it could go under 'Projects': https://www.avrfreaks.net/forums/avr-freaks-projects - note the 3 pinned posts
https://community.atmel.com/projects
