External oscillator in START not selected?
10 posts / 0 new
NOTE: I am intentionally mis-posting this!  It belongs in the AVRFREAKS forum, not in ARM, but I can't log into the avrfreaks forum.  So hopefully an admin will move it to the correct place.  Thank you...
I have created an Atmel START project for the XMEGA16D4.  In the Clocks page, I specified the external oscillator running at 12MHz.
(And I would post an image, except the forum software is giving me "You are not authorized to access this page." when I add the screen shot...)
But the generated code in osc.c reads:
	OSC.CTRL = 0 << OSC_PLLEN_bp     /* PLL Enable: disabled */
	           | 0 << OSC_XOSCEN_bp  /* External Oscillator Enable: disabled */
	           | 0 << OSC_RC32KEN_bp /* Internal 32kHz RC Oscillator Enable: disabled */
	           | 1 << OSC_RC32MEN_bp /* Internal 32MHz RC Oscillator Enable: enabled */
	           | 0 << OSC_RC2MEN_bp; /* Internal 2MHz RC Oscillator Enable: disabled */
... which, unless I'm mis-reading this, uses the internal oscillator, not the external.  But in clock_config.h, it knows that I've set the oscillator to 12MHz:
#ifndef F_CPU
#define F_CPU 12000000
#endif
Is this a known bug, or is it a cockpit error?
(Created a new account so I could at least log in!)
Dear moderator: I still can't add media -- is there a known workaround to "You are not authorized to access this page" when trying to add media?  Instead, I've added the two images as attachments.
rdpoor wrote:
I still can't add media ("You are not authorized to access this page.")
Don't worry; it's not you - See: https://www.avrfreaks.net/forum/media-browser-you-are-not-authorized-access-page
As noted in that thread, attaching & pasting images should still work ...
EDIT - your attachments, copied & pasted:
Copy/Paste works for me! ^C/^V
Solved, after a fashion.  I noticed that on START's Dashboard panel, there were additional OSC settings (see attached).  Why the setting for OSC_XOSCEN_bp isn't on the clock page, I can't say.  But checking the check box to enable it on the Dashboard panel solved the issue.
(and yes, ^C/^V works to paste images.  thanks for the tip!)
I can.  It's because OSC_XOSCEN_bp is for the OSCILLATOR, not the clock the CPU or peripherals use.
Therefore it is in the right place.
JIm
Please mark what you consider the solution so as to  close out the thread.
Jim:
That's solid reasoning, but -- to indulge in a bit of pedantry -- START certainly blurs your OSC/CLOCK distinction in the "EXTERNAL CRYSTAL OSCILLATOR CONFIGURATION" dialog.  There, you can enable "External crystal oscillator drive" (which neither the CPU nor any of the peripherals care about) and other attributes specific to the xtal.  I think you'd agree that enabling the xtal itself COULD be on that dialog.
Anyway, I've figured it out and I'll know better next time!  Thanks for your help!
About that.  I looked the page over multiple times for a "mark this as solution" button, but can't find it.  Is it inhibited for new users (or old users with brand new accounts)?  Equally likely: I'm just unobservant.
To wit:
No, I don't agree.  your question was about OSCILLATOR, not Clock.  Yes, teh Clocks page does allow you to select the external OSCILLATOR, but you still need to enable teh oscillator that is in teh OSCILLATORS menu system..
To each his own.  I dont use Start much, if t all.
I'll mark the solution for you, teh reason you do not see it is because you opened another account and used that to post your solution.
As you are having problems accessing the fearless_fool account what I will do (as both your accounts appear to be in exactly the same place using IP lookup) is reset the password on that then send the new password by direct message to rdpoor. It's then your choice as to which account to continue with.
Actually I seem to remember the system has the ability to "merge accounts" but probably best if we don't attempt that as the system also has a history of crashing and losing stuff when anything "exciting" is attempted.
Moderator.
