AVR assembler and clearing bits...
16 posts / 0 new
Please excuse this simple question - I'm a bit new to AVR assembler, but have many many years of other assemblers and languages.
In the ATmega48 manual (2545-AVR-09/07) on page 52 the follow code is commented as "Clear WDRF in MCUSR":
in   r16, MCUSR
andi r16,(0xff & (0<<WDRF))
out  MCUSR, r16
Am I missing something here? The above looks like it sets MCUSR to zero. In my ignorance, I would have expected:
andi r16, ~(1<<WDRF)
...or similar which only clears the specified bit.
Nick
Nicko
It's a typo. Your version is correct.
Chuck Baird
http://www.cbaird.org
if you look at the C-Code example below the assembler example
MCUSR &= ~(1<<WDRF);
you see exactly what you have suggested.
Send a mail to Atmel. So they can do a correction of the datasheet.
Regards
Sebastian
I think it is correct, the (0xff & 0<<bitname) is used frequently and I have the feeling it is the IAR assembler syntax.
Does ANYONE out there still uses the IAR assembler to clarify this?
This is no IAR specific syntax but general C. It's usually used for OR operation:
DDRD = (1<<PD7) | (0<<PD6) | (1<<PD5) | (0<<PD4) | (1<<PD3) | (0<<PD2) | (1<<PD1) | (0<<PD0);
(0 << bit) will always result 0 and thus will have no effect in the example above. This is usefull if you later need to change a bit in a SFR. And for legibility this is an improvement, too. All bits in the SFR are listed this way.
But in an AND operation the expression (0 << bit) will clear the complete register.
Regards
Sebastian
I'm familiar with C syntax (in the dim and distant past I was part of the ANSI C X3 J11 standardisation process and have written two full standards-compliant compilers myself) - the question was whether this was some arcane artifact of the AVR assembler or not.
It seems that its a straightforward typo, which is interesting as I've seen it quoted verbatim in production code and it just "looked wrong". Code snippets in data sheets should hopefully be reliable...
FWIW, I just check the list file for the above code snippets in AVR Studio 4 SP1, and the code snippet in the manual is definitely wrong. It should be the example I provided... (as per the C code).
Cheers
Nick
Nicko
I don't think that'd be valid in ANY assembler. 0 shifted by anything is always 0 and anything ANDd with 0 is always 0. So the above could never deliver anything but 0.
As for the question of anyone using the IAR assembler (which is completely free to all by the way - the full, unlimited version comes with the Kickstart version of the C compiler) the fact is that everyone using IAR C is using it - like almost all C compilers it works by converting C to Asm source then assembling it.
Cliff
It is perfectly valid. Just not useful.
Steve A.
Steve,
Apologies, "valid FOR CLEARING A SINGLE BIT"
(it does a cracking job of clearing 8 though)
As this has come up before, and in order to clear it up in my mind once and for all whether it is a typo or some weird IAR assembler syntax, I installed the IAR asm from an old CD.
With this source file:
	NAME	main
	PUBLIC	main
MCUSR equ 0x34
WDRF  equ 3
main
        in      r16, MCUSR
        in      r16, MCUSR
        andi    r16,~(1<<WDRF)
	END	main
the (0xff & (0<<WDRF)) produces the expected result of clearing all bits
      1    00000000                      NAME    main
      2    00000000
      3    00000000                      PUBLIC  main
      4    00000000
      5    00000000
      6    00000034              MCUSR equ 0x34
      7    00000003              WDRF  equ 3
      8    00000000
      9    00000000              main
     10    00000000 B704                 in      r16, MCUSR
     11    00000002 7000                 andi    r16,(0xff & (0<<WDRF)) ;Produces 0x00 as a mask
     12    00000004
     13    00000004 B704                 in      r16, MCUSR
     14    00000006 7F07                 andi    r16,~(1<<WDRF) ;Produces 0xf7 as a mask-Correct
     15    00000008                      END     main
because I doubted such esteemed freaks, I shall make myself a vegemite sandwich for lunch as a punishement. It may prove fatal, so if you don't hear from me for a while you know what happened. Cards, flowers or money can be send to the address shown on my website :mrgreen:
If on the other hand you just don't want to hear from me (as some do), full stop, money can still be send at the same address, say AU$100.00 would shut me up for 24 hours :?
Bidding War! I'll shut up for 24 hours for $50! (I know of several here who will be tempted...)
whoops. my wife beat you to it. anybody interested in buying tomorrow?
Chuck Baird
She probably paid using your checkbook (you better go order some more blank checks). She'll have a good thing going until you figure that one out (you'll figure it out when you go to the bank to deposit it- the bank teller will look at it, tear it up, and say 'Its all taken care of, Mr. Baird.').
Be aware that a few bits (interrupt flag bits, mostly, I think) are CLEARED by writing a 1 to the bit. So, it pays to read the text description for the register and its bits carefully.
If it does prove fatal but we then DO hear from you after a while then that's kind of spooky! :lol:
FWIW I had a very nice reply from the AVR documentation team thanking me for the correction and saying that the datasheet will be changed. (didn't say when, though...)
They did point out that they really appreciate the updates as I guess it just increases the quality of the product. I also got the impression that the individual concerned is a member of this forum...
Nick
Nicko
.....I shall be haunting in Finchifield tonight.......woaaa haaaa oooo :evil:
