Flashing with AVRDude
6 posts / 0 new
Hey,
Currently im trying to flash my Attiny85 from RS (https://nl.rs-online.com/web/p/m...) with the AVRDUDESS tool that i found on AVRFreaks. However im receiving a message from AVRDude that the device has a strange signature.
>>>: avrdude -u -c usbasp -p t85 -B 0.5 -F
avrdude.exe: set SCK frequency to 1500000 Hz
avrdude.exe: error: program enable: target doesn't answer. 1
avrdude.exe: initialization failed, rc=-1
avrdude.exe: AVR device initialized and ready to accept instructions
avrdude.exe: Device signature = 0x6c6f63
avrdude.exe: Expected signature for ATtiny85 is 1E 93 0B
avrdude.exe done.  Thank you.
I'm new to flashing with AVRDude. What might be the problem causing this issue?
Let's start with the obvious...what is your hardware setup? Show a schematic and a picture of your board.
By Default.
USBASP Module (USBISP, but they are the same: https://nl.aliexpress.com/item/1...)
Mosi (PB0)-> Mosi ISP
Miso (PB1)-> Miso ISP
SCK (PB2) -> SCK ISP
RESET (PB5) -> RESET ISP
GND -> GND ISP
VCC -> 5V ISP
My Flasher seems te be broken. Arduino ISP works......
Thanks!
Never, NEVER use the -F flag.
this means what it says.
I suggest that you check your wiring carefully.   And try again.   If you still get the "failed" message,  post a clear photo of your wiring.
Total votes: 2
Found this picture of the AVR dude flashing on the Internet.  Perhaps that will help...
