ATXMEGAA1U-XPRO RTC interrupt
6 posts / 0 new
I need to use the 32 kHz external oscillator on the xmegaa1uxplained pro eval board. I need a 5 ms RTC clock. The RTC is completing the initialization but the RTC interrupt is not triggering. What is missing/wrong from the setup below? Thanks
void vRtcInitialize (void)
    /* Turn on external oscillator (32kHz on board). */
    OSC.XOSCCTRL |= OSC_XOSCSEL_32KHz_gc;
    OSC.CTRL |= OSC_XOSCEN_bm;
    do
        /* Wait for the 32kHz oscillator to stabilize. */
    while ((OSC.STATUS & OSC_XOSCRDY_bm) == 0);
    /* Set clock source for RTC to 32kHz on board oscillator. */
    CLK.RTCCTRL = CLK_RTCSRC_TOSC32_gc | CLK_RTCEN_bm;
//set RTC period to approx 5 ms
    RTC.PER = 163;    //32768/163 = 5ms
    RTC.INTCTRL = RTC_OVFINTLVL_LO_gc;
    while(RTC.STATUS & RTC_SYNCBUSY_bm);
ISR(RTC_OVF_vect){
    RTC.INTFLAGS = RTC_OVFIF_bm;
    _systemTicks += 1UL;
I take it there is an sei() in all this somewhere ?
The sei() is called before initializing the RTC, even before system_init. I added
    /* Enable interrupts. */
    PMIC.CTRL |= PMIC_LOLVLEN_bm;
to the bottom of RTC_initialize. It doesn't make a difference.
Priya
Not generally a good idea to enable an interrupt before you've correctly configured stuff.
Please post a minimum but complete example which illustrates the problem
See Tip #1 in my signature, below for how to properly post source code:
#define F_CPU (4000000UL)
#include <asf.h>
#include "conf_usb.h"
#include "ui.h"
#include "uart.h"
#include "tmrmodule.h"
#include "timeout.h"
extern volatile ticksize_t _systemTicks;
static volatile bool main_b_cdc_enable = false;
void vRtcInitialize(void);
void vIOWiegTimeout(void);
uint8_t bWiegData = FALSE;
/*! \brief Main function. Execution starts here.
	iram_size_t len = 6;
	char buf[6] = {'G', 'R', 'E', 'A', 'T', '\n'};
	uint16_t    chktick = 0;
	// Initialize the sleep manager
//	sleepmgr_init();
#if !SAM0
	sysclk_init();
	board_init();
#else
	system_init();
#endif
	vRtcInitialize();
		irq_initialize_vectors();
		cpu_irq_enable();
	vTmrInit();
	vTmrCfgFnct (WIEG_TIMER, (void *)vIOWiegTimeout, (void *)0);		// config WIEG timer
	vTmrSetT(WIEG_TIMER, 5);
//	ui_init();
//	ui_powerdown();
	// Start USB stack to authorize VBus monitoring
//	udc_start();
	// The main loop manages only the power mode
	// because the USB management is done by interrupt
	while (true) {
		chktick = to_GetTicks();
		while (chktick > 0)
			vTmrSignalTmr();	// update system timer
			chktick--;
//		sleepmgr_enter_sleep();
//		udi_cdc_write_buf(buf,len);
	do
ISR(RTC_OVF_vect){
I got the RTC_EXAMPLE1 setup to use the external 32kHz crystal and with RTC PER 5 ms. I am now able to get the RTC interrupt to trigger. I had to use ASF to add the RTC driver to the project. Now I need to use it the way the application needs.
