Best way to do protected write?
5 posts / 0 new
I'm working with the AVR128DB28 and AVR128DB48.  In some cases, like when changing configuration of the oscillators, a protected write is needed.  I've seen protected write in two different forms:
_PROTECTED_WRITE(CLKCTRL.OSC32KCTRLA, CLKCTRL_RUNSTDBY_bm);  // enable internal 32K osc
ccp_write_io((void*)&CLKCTRL.OSC32KCTRLA, CLKCTRL_RUNSTDBY_bm);    // enable internal 32K osc
What is the difference between the two forms and is one form more preferable than the other?
I don't know what the other advantages and disadvantages are, but here's why I use _PROTECTED_WRITE:
1. You must include cpufunc.h to use ccp_write_io. _PROTECTED_WRITE is included in xmega.h, but no include description is required.
2. _PROTECTED_WRITE is smaller and faster than the build result.
sample:
#include <avr/cpufunc.h>
int main(void){
    _PROTECTED_WRITE(CLKCTRL.OSCHFCTRLA, CLKCTRL_FREQSEL_24M_gc);
    asm("nop");
    ccp_write_io((uint8_t*)&CLKCTRL.OSCHFCTRLA, CLKCTRL_FREQSEL_24M_gc);
    asm("nop");
    while (1);
LSS:
The macro is probably better as the function version is a library function that will get called, and the difference basically boils down to doing a sts in the macro version vs doing a call in the library function version (and you still are not done)-
https://godbolt.org/z/nWcbdKbvo
(mega4809, but close enough)
Thanks for this.  And your assembly listing is very helpful!
Paul
Thank you.
Paul
