Most efficient way of analysing 64 bits
14 posts / 0 new
Hi Guys,
Looking for some inspiration.
Atmega328P connected to 4 tlc5940's providing 16 x 4 outputs.
The problem:
I want to add individual outputs to a group which may have 1-64 ports assigned by the user. User then just needs to say "group on" and the appropriate outputs are enabled
Question: What's the most efficient way of manipulating/analysing the members?
I had thought of assigning 4 bytes and using the bits to determine if a port is a member which would work, but it means I have to loop though all 64 bits.  Any more efficient options especially as they're might be only a few set?
(I still need to send the data via SPI individually)
regards
nikm wrote:
What's the most efficient (sic) way
"efficient" in terms of what, exactly?
  • execution time?
  • code size?
  • RAM usage?
  • programmer effort?
  • other ??
As always, it's a tradeoff - some of those things will be directly contrary to others.
Good point.
Existing code is pretty tight, so a reasonable amount of RAM available so I guess execution time with minimum programmer effort :)
Is there a better way than looping 64 times?
I should add that I plan to have 16 groups in an array
regards
I'm still not entirely clear what you're trying to do.
Maybe a diagram (or diagrams) to illustrate would help ?
easiest is to explain my current thoughts.  Hope this helps
regards
sudo code
// Group storage
volatile  uint8_t groups[16][4];
// Examine group 1
for(y = 0 to 3)
  if groups[1][y] > 0 then
       for(x =0 to 7)
           if(bit set) then ..
You can just OR the bits
You must already have 8 bytes that you send out for the current 64 channels on/off settings.
Now you add 8 bytes that have ones in the channels that define the group  (ex  000101101 01011110 000101101 11001010 000101101 000101101 111101011 000101101 ) ...these ones mark which of the 64 are the user group channels
You just OR the original 8 bytes with these...send out the 64 bits and those channels will now be ON.   So you have 8 OR operations to do (if using a higher language, it will do so for you)
To turn off those channels invert the 8 bytes, then do an AND operation...send the 64 bit result out & those channel will go OFF
u8[16][4] is 64 BYTES. Why are you using one whole byte for a 0/1 state?
My first thought when the thread title said "64 bits" was simply ONE uint64_t.
The first element of the array is the group number then the 4 bytes containing 64 bits.  I know it's a waste of 16 bytes, is there a better option?
regards
Thanks for that, much appreciated
regards
It's a very good trick if you are able to get 64 bits in 4 bytes. Usually 4 bytes will contain just 32 bits ?!?
Anyway if you have a small group number then a large bit string a struct would seem to be the obvious. Something like:
typdef struct {
    uint8_t groupNum;
    uint32_t the32bits;
} bitInfo_t;
bitInfo_t allData[4];
But if you want to split 64 bits into 4 lots of 16 bits (say) why do you need a "group number" anyway? Surely you just have an array of bit groups and the index is the "group number".
I'd take a step back and very clearly state exactly what info and how much of it you want to represent then it should be easy to specify a good way to store it and how to manipulate it.
Total votes: 2
If he uses bool type from <stdbool.h> then that is what will happen. Sometimes though what seems an obvious waste of memory can result in cleaner or faster code.
There is a saying: "Unused memory is wasted memory". I concur.
Indeed.
Hence #2.
+1
See #4.
little side step...
why are you using a PWM controller to do digital outputs?
the chip is a 16 channel 12bit PWm controller so for 1 chip you could do with a 16 location uint16 array. for each channel you then have 4 bits left to act as a status indicator.
