SAMD21 Xplained pro set clock to output pin
9 posts / 0 new
Hello, all!
I have an SAMD21 Xplained pro. I need to set a 3MHz clock to one of the pins on one of the connectors.
I have the following code, which I assembled from snippedts on these forums:
This code successfully outputs 1MHz on pin PA14 (which is not on any connector).
#include <asf.h>
void InitClock()
	GCLK_GENDIV_Type gendiv =
		.bit.DIV = 1,   //Do not divide
		.bit.ID = 0,     //GCLK[0]
	GCLK->GENDIV.reg = GCLK_GENDIV_ID(0) | GCLK_GENDIV_DIV(1);
	GCLK->GENCTRL.reg = GCLK_GENCTRL_ID(0) | GCLK_GENCTRL_SRC_OSC8M |
	GCLK_GENCTRL_RUNSTDBY | GCLK_GENCTRL_GENEN | GCLK_GENCTRL_OE;
	GCLK_CLKCTRL_Type clkctrl =
		.bit.CLKEN = 1,
		.bit.GEN = GCLK_CLKCTRL_GEN_GCLK0_Val	//ID of the clock
	GCLK->CLKCTRL.reg =clkctrl.reg;
	while (GCLK->STATUS.bit.SYNCBUSY);
void PortInit()
		PORT->Group[0].DIRSET.reg |=  PORT_PA14;
		PORT->Group[0].PINCFG[14].reg |= PORT_PINCFG_PMUXEN;
		PORT->Group[0].PMUX[7].bit.PMUXE = 0x7; //Attach clock to I/O
void main()
	InitClock();
	PortInit();
I need this to be 3 MHz, and on another pin (for example, pin PA15).
I have tried achieving this, by:
1. in InitClock() , witching the GCLK_GENCTRL_SRC_OSC8M to GCLK_CLKCTRL_ID_DFLL48 (48MHz, which I can divide by 16) - this doesn't work, whatever I do, the clock rate remains 1MHz.
2. in PortInit, switching PA14 to PA15, by substituting:
    - PORT->Group[0].DIRSET.reg |=  PORT_PA14;    ---> PORT->Group[0].DIRSET.reg |=  PORT_PA15;
    - PORT->Group[0].PINCFG[14].reg |= PORT_PINCFG_PMUXEN;   ---> PORT->Group[0].PINCFG[15].reg |= PORT_PINCFG_PMUXEN;
   This also doesn't work. The clock won't appear on pin PA15.
Can you please instruct me on how to output 3MHz clock on PA15 (or another pin)?
Thanks!
You have two choices - use clkout like you have or set up a timer to divide your main clock and output to a pin. The choice of pins are limited.
You code toggle any pin with code, but the processor wont be doing much else.
That board has a 12MHz crystal, so you need to divide
the clock by four.  Using a timer to toggle an output
pin, you would have to configure it to count two clocks
only.  This will toggle at 6MHz yielding a 3MHz square
wave.
--Mike
Thanks for the reply!
SW toggle is out of the question, because I need to run logic.
I'm entirely new to Atmel, could you please show me an example of how to use clkout so I have 3MHz?
Thanks!
Thanks for the reply! Do you have an example of how to output the crystal to a pin? Also, I believe this MCU operates at 48MHz, no?
Hey guys, I'm still struggling with this. Can anyone please suggest a course of action?
    // Setup XOSC32K for external crystal oscillator 32768 Hz
    REG_SYSCTRL_XOSC32K = SYSCTRL_XOSC32K_STARTUP(6) |	SYSCTRL_XOSC32K_XTALEN | SYSCTRL_XOSC32K_EN32K;
    REG_SYSCTRL_XOSC32K |= SYSCTRL_XOSC32K_ENABLE;
    while ((REG_SYSCTRL_PCLKSR & SYSCTRL_PCLKSR_XOSC32KRDY) == 0);
    // GCLK2 at 32768 Hz
    REG_GCLK_GENDIV = GCLK_GENDIV_ID(2) | GCLK_GENDIV_DIV(1);
    REG_GCLK_GENCTRL = GCLK_GENCTRL_GENEN | GCLK_GENCTRL_SRC_XOSC32K | GCLK_GENCTRL_ID(2);
    // Provide DFLL48M reference from GCLK2
    REG_GCLK_CLKCTRL = GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN_GCLK2 | GCLK_CLKCTRL_ID_DFLL48;
    // Setup DFLL48M
    REG_SYSCTRL_DFLLCTRL = SYSCTRL_DFLLCTRL_ENABLE;
    while ((REG_SYSCTRL_PCLKSR & SYSCTRL_PCLKSR_DFLLRDY) == 0);
    REG_SYSCTRL_DFLLMUL = SYSCTRL_DFLLMUL_CSTEP(31) | SYSCTRL_DFLLMUL_FSTEP(511) | SYSCTRL_DFLLMUL_MUL(1464);
    REG_SYSCTRL_DFLLCTRL |= SYSCTRL_DFLLCTRL_MODE|SYSCTRL_DFLLCTRL_QLDIS;
    const uint32_t status = SYSCTRL_PCLKSR_DFLLLCKC | SYSCTRL_PCLKSR_DFLLLCKF;
    while((REG_SYSCTRL_PCLKSR & status) != status);
    // Set wait state (1) for running the CPU at 48MHz
    REG_NVMCTRL_CTRLB = (1 << NVMCTRL_CTRLB_RWS_Pos);
    // Use DFLL48M for GCLK0
    REG_GCLK_GENDIV = GCLK_GENDIV_ID(0) | GCLK_GENDIV_DIV(1);
    REG_GCLK_GENCTRL = GCLK_GENCTRL_OE | GCLK_GENCTRL_GENEN | GCLK_GENCTRL_SRC_DFLL48M | GCLK_GENCTRL_ID(0);
    // Output GCLK0 48 MHz on PB14
    PORT->Group[1].PMUX[14/2].reg |= PORT_PMUX_PMUXE(MUX_PB14H_GCLK_IO0);
    PORT->Group[1].PINCFG[14].reg |= PORT_PINCFG_PMUXEN;
Is a start, this sets up a 48 MHz clock (you can skip the last part which outputs this clock to PB14).
With that you can generate a 3 MHz output in lots of ways as mentioned. Here is one way
    // GCLK1 also using DFLL48M but divide by 16 for 3 MHz
    REG_GCLK_GENDIV = GCLK_GENDIV_ID(1) | GCLK_GENDIV_DIV(16);
    REG_GCLK_GENCTRL = GCLK_GENCTRL_OE | GCLK_GENCTRL_GENEN | GCLK_GENCTRL_SRC_DFLL48M | GCLK_GENCTRL_ID(1);
    // Output GCLK1 on PA15
    PORT->Group[0].PMUX[15/2].reg |= PORT_PMUX_PMUXO(MUX_PA15H_GCLK_IO1);
To understand why you failed to get GCLK0 output to PA15 you need to study "I/O Multiplexing and Considerations". It depends on having a GCLK_IO for the pin you want to use (function H in the table). So it is not by accident I use GCLK1 for the 3 MHz (GCLK_IO[1] is a function available for PA15).
/Lars
This is true but it's not connected to the SAMD21, it's used for the embedded debugger.
/Lars
Very helpful, thank you. :)
