Attiny88 Setting up PWM outputs
18 posts / 0 new
How do i set up OCR0A, OCR0B, OCR1A, OCR1B all as outputs
phase correct mode
8x prescalar
Thank you
By looking at the datasheet  ---have you?
Not to be too snarky, but the tables for the timer show all the settings.  The WGM bits control whether the pins themselves change based on timer responses
Search the datasheet for WGM & you will be in golden luck garden
for example ,section 12.11.1
yes this is my setup so far...
    //ATtiny88 datasheet, page 140
    //Compare Output Mode, Set to 'Phase Correct PWM Mode' mode
    TCCR1A |= (1 << COM1A1) | (1 << COM1B1)); //OCR1A, OCR1B
    //Waveform Generation Mode, (Phase Correct 8-bit PWM)
    TCCR1A |= (1 << WGM10); //OCR1A, OCR1B
    //Prescaler
    TCCR1B |= (1 << CS11); // clock /8 = (~ KHz)
This will set Phase correct PWM on PB1 and PB2 pins.
    TCCR1A |= (1 << COM1A0) | (1 << COM1A1) | (1 << COM1B0) | (1 << COM1B1);
    OCR1A = 127;
    OCR1B = 127;
    DDRB |= (1 << PB1) | (1 << PB2);
    while (1)
I think you are missing to set the pins to output mode.
+1!
Keys to wealth:
How about pins PD6 and PD5.
I had pins in output mode
    DDRB |= ( 1 << PB2 );            // LED is an output (PB2)
    DDRB |= ( 1 << PB1 );            // LED is an output (PB1)
    DDRD |= ( 1 << PD6 );            // LED is an output (PD6)
    DDRD |= ( 1 << PD5 );            // LED is an output (PD5)
Does attiny88 support Phase correct PWM on pins PD6 and PD5?
Yes, OC0A & OC0B can be set to phase correct
???  So, we are to guess what code you are using?  Post a complete test program; tell how you are testing; tell what you observe.
#ifndef F_CPU
#define F_CPU 8000000UL			// Define software reference clock
#endif
void Init_ports(void)
	// Enable Pull-Up Resistors on Unused Pins
	PORTB = ((1 << PINB0) | (1 << PINB3) | (1 << PINB4) | (1 << PINB5) | (1 << PINB6) | (1 << PINB7));
	PORTC = ((1 << PINC0) | (1 << PINC1) | (1 << PINC2) | (1 << PINC3) | (1 << PINC4) | (1 << PINC5));
	PORTD = ((1 << PIND0) | (1 << PIND1) | (1 << PIND2) | (1 << PIND3) | (1 << PIND4));
void PWM_setup (void)
	// See ATtiny88 datasheet, page 126
	TCCR1A |= ((1 << COM1A0) | (1 << COM1A1) | (1 << COM1B0) | (1 << COM1B1)); //OCR1A, OCR1B
	//Waveform Generation Mode, (Phase Correct PWM)
	//Prescaler x8
int main (void)
	Init_ports();
	PWM_setup();
	OCR0B = 15;
	OCR0A = 100;
	OCR1A = 180;
	OCR1B = 255;
	return(0);
Only OCR1A is working.
I tested the other pins, they have no outputs on the pins.
So im guessing its the PWM setup
If I am not wrong, on attiny88 phase correct PWM is only supported on timer1. Only OCR1A and OCR1B will work.
In your PWM_setup function, the code only setups phase correct PWM for two pins only, which are PB1 and PB2.
Regular pwm (fast pwm) is very suitable for most things.  Rapidly varying motor speed (such as bridge drive transistors) appreciates phase-correct type
You are correct, the only OCR pins are OCR1a/b, to timer0 has not pwm output pins.
That leaves only softPWM via software if the OP wants to use T0 for pwm.
PS:  Has the OP confused a mega88 for the tiny88?  Please clarify what AVR you are using.
Keys to wealth:
i am using Attiny88-AU with Atmel Studio, i can use Fast PWM instead, how do i set up.
What DS are you looking at?
Your pin out is for an ATmega88!!!  not an Attiny88, are you looking at the correct datasheet?
Keys to wealth:
YUP! was using the mega88 datasheet instead of the tiny88.
No sweat, it's not like we all have not done that ourselves.   Good hunting!
Keys to wealth:
I need 4 separate PWM outputs
Since the Atmega88A has 4 PWM outputs, i will order some and program and update here.
I even design my board based off the Atmega88A, which is a good thing! Just had the wrong chip currently
Thanks!!
