AtmelStudio formating lost on cut/paste
4 posts / 0 new
Hi
I have looked in the forum and not found an answer to this question.... apologies in advance if it is there and I have missed it.
AtmelStudio periodically changes the formatting of my code. It happens at least when I cut/paste code but possible also at other times (that I can't describe). I know about the VA Snippet editor and think I am using it correctly.
For example if I have code like
switch(var)
    case value1:
        break
    default:
        break
and I cut and paste it, I end up with
switch(var)
    case value1:
    break
    default:
    break
Similar things happen with if/else indenting.
I understand that the formatting that I prefer might not be preferred by others... but the issue I am struggling with is how to preserve the format.
All ideas are welcome.
Regards
Greg
regards
Greg
In Visual Studio 2017, pasted code automatically gets re-formatted as you've described. Because I want consistent formatting in my project I generally just go with the imposed format.
BTW: Those breaks are placed at the correct indentation level because case labels are just that - labels - they don't create a new block scope.
An exception to going with the imposed format is for example when I have spaced out a lookup table so that columns lines up nicely. After pasting simply type one Ctrl-Z and the re-formatting will be undone.
Atmel Studio should behave similarly.
Do you know how to configure AS7.0 C or C++ formatting?
The default is horrible.
I know I am late to the party, but I just found this thread as I was looking for a solution for this exact issue.
To preserve formatting when copy/pasting, go to:
VAssistX -> Visual Assist Options... -> Editor
And then remove the checkmark at "Format after paste".
