Does the atmega8a can tolerate the current of two 7-segments ?
7 posts / 0 new
I'm making a digital dice with two 7-segments and an atmega8a
I want to connect 7-segments directly to Atmega8a pins with a 330 ohms resistor for each pin
As I measured, each segment has 5 mA consumption, and a 7-segment displaying numbers between 1 and 6 consumes a maximum of 30 mA, which is 60 mA for two 7-segments.
Due to  Atmega8a datasheet, the maximum tolerable current of each pin is 40 mA and the maximum consumption current of atmega8a can be up to 300 mA
is driving these two 7-segments with an Atmega8a a standard method?
would this method harm atmega8a in a long period of time?
Sounds fine to me but note that often displays are "multiplexed" to save pins. If you do that then even if you display 8.8. only one lot of '8.' would actually be illuminated at any one moment - but you switch between them so fast that it looks like they are all on at the same time.
So this is the part you need to pay attention to:
https://ww1.microchip.com/downloads/en/DeviceDoc/ATmega8A-Data-Sheet-DS40001974B.pdf - page 233; notes to Table  26.2,  "DC Characteristics"
So your total of 60 mA should be fine.
If you have enough port pins, yes.
If you're short of port pins, and/or want more digits, then as clawson said, multiplexing is the way to go ...
no.
thanks for your reply
previously  i used two 74hc595 to drive the 7-segments but i removed them to avoid a complex two layer pcb
no.
thanks .
i use DIP package
or, if that's still too many pins, an external driver; eg, the  74hc595  previously mentioned, or something on I2C or SPI ...
Of course, nowadays 7-Segs are passé - GLCD is the way to go ...
wink
awneil wrote:
GLCD
Which decade are you living in? I would have thought OLED was de rigueur? cheeky
