RTClib not working with avr's native coding format.
15 posts / 0 new
This is my code,  i want to read the data from DS3231 RTC using the RTClib,h library and print it in 1602 LCD. It is compiled sucessfully. but the arduino got hanged after the rtc.begin() line. but it is working when i write the code in arduino's way. but not working in the standard coding format ( i mean, without using void setup and loop ,).  link to the adafrut's RTClib : https://github.com/adafruit/RTClib
#include <avr/interrupt.h>
#include <avr/delay.h>
#include "RTClib.h"
#include <LiquidCrystal.h>
#include <Wire.h>
RTC_DS3231 rtc;
const int rs = 7, en = 6, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
DateTime now;
int main()
    DDRB |= 0b00100000; //pb5/D13 as output
    lcd.begin(16, 2);
    lcd.print("hello world");
    _delay_ms(1000);
    lcd.clear();
    rtc.begin(); // after this line this code get hangged in arduino,
    //it is not responding the below lines.
    //Wire.endTransmission();
    lcd.print("after rtc");
    while (true)
        PORTB ^= (1 << PB5);
        lcd.clear();
        DateTime now = rtc.now();
        lcd.print(now.hour());
        lcd.print(':');
        lcd.print(now.minute());
        lcd.print(':');
        lcd.print(now.second());
        lcd.setCursor(0, 1);
        lcd.print(rtc.getTemperature());
        _delay_ms(1000);
And the below code is working with fine , i used same library and almost same code. the only differance is i used arduino's way of coding structure.
#include "RTClib.h"
#include <Wire.h>
RTC_DS3231 rtc;
DateTime now;
void setup()
    lcd.begin(16, 2);
    _delay_ms(1000);
    lcd.clear();
    rtc.begin();
void loop()
    // blink the led one sec delay and print time and temprature.
    lcd.clear();
    lcd.print(':');
    lcd.print(':');
    _delay_ms(1000);
i attached the working code's output below .
any help would be appreciated. smiley
thank you,
Try changing while(true) to while(1) like this
    while (1)
        lcd.clear();
        lcd.print(':');
        lcd.print(':');
        _delay_ms(1000);
true is not defined in following includes
So your code is compiling so it must be defined in the other includes where "true" might be defined as 0
Just guessing.
If that were the problem, the code wouldn't even compile.
So, presumably, the Arduino framework is setting up some stuff that you have omitted from your "non-Arduino" version ?
thank you Heisen for replaying.  smileyheart
i tried your suggestion. but the same problem is appearing. the code is hanging after rtc.begin().  ie , the "hello world" line is printitng with 1 sec delay and after clearing the display it shows nothing in display. thats why i tried to print "after rtc". the code is not working from that line.
SOORYADEV.K wrote:
replaying.
FYI, note that it's "replying"
It would - see #3.
See: https://forum.arduino.cc/t/can-you-use-main-in-a-regular-arduino-program/43239/4
awneil i searched a lot about it in internet. but nothing got helpful sad. i'm a beginner at this so, i don't know much about arduino's frameworks. i thinks the same, but i don't know, which thing that i missed in this code.
https://forum.arduino.cc/t/main-function/295213/5
I Googled[1] "how to write main() in Arduino"
At what, exactly?
If you want to do without the Arduino framework, that will require that you have at least a reasonable grasp of "bare metal" programming.
So what is your actual goal here? If the Arduino approach works, why not just use it?
Some microcontroller "getting started" tips: https://www.avrfreaks.net/commen...
Some C learning & reference materials: http://blog.antronics.co.uk/2011...
And don't forget the 'Tutorials' section on this site ...
[1] Other internet search engines are available.
Thank you awneil for sharing resources, i will try these.smileyyes
yes, you are correct. i know to program pic  base level and mid range ics using MPLAB X IDE ,and 8051 assembler languages etc..( not a pro, but i know to code in register level and can understand artitecture of ic by reading datasheet). actually i meant that , i don't know much about arduino's way of working.that is more confusing for me. i usually use registers level coding,  thank you for your replay. i think i should use atmel studio than the arduino IDE.
actually my entire code was done in the avr's native way.And i found something strange while i using this library. so for debugging purpose i use this example.
There's nothing to say that RTClib will work outside of the Arudino ecosystem. At the top of the .cpp file are a load of conditional '#defines' which will almost certainly need sorting out.
Brian Fairchild wrote:
There's nothing to say that RTClib will (sic?) work outside of the Arudino ecosystem
Did you mean "will" - or "will not" ?
And, presumably, a number of other things that the Arduino framework will have set up for it?
I guess it may also depend upon other Arduino things - which would also have their own dependencies ...
None of it is "native" to the AVR - a microcontroller neither knows nor cares what what IDE or framework you use to develop your source code.
If you want to use Arduino stuff in an Atmel Microchip Studio project, the easiest way is probably to start with a working Arduino project featuring all the facilities you want - and import that into Studio:
https://www.avrfreaks.net/forum/microchip-trying-wean-people-arduino-atmel-studio
Will. As in, RTClib is written to work in an Arduino ecosystem and might makes assumptions about the environment in which it is executing.
The GitHub page for RTClib says this...
yes
Arduino uses C++, although some of the lib's may work in C as well, but will depend on how it is written.  In AS7 you will need to start with a C++ project in order to use most Arduino lib's.
However the OP has stated the project compiles ok, so this may be a moot point.
