LEDs and enclosures
24 posts / 0 new
Hi All
This is a simple question as I would like to know anyone has experience with a particular LED range or size.
I aim to place a PCB in an enclosure, I want to avoid making any holes in the enclosure for the LED to shine.  I have noticed from an initial experiment if the enclosure wall thickness is thin and if the plastic color is light, the led inside can still provide some light to shine to the outer wall. These LEDs I tested were axel-legged versions from amazon but do not that any spec information on them.
Has anyone else used LEDs in such way?
I would like to know is there a recommended package to use or a certain type of LED?  I guess I would still need to experiment with it but would prefer to use a package that has a wider range of led choices to be flexible.
Till now I have used simple 0805 LEDs for simple PCB indications.
Regards
DJ
In Australia we can get enclosures with clear plastic lids. Would that help?
A few here https://www.jaycar.com.au/search...
There are a number of IP65 or better enclosures with transparent lids. I can provide a partial list if that would help.
search for acrylic boxes ...you can get some for only 50 cents and seal them up with some glue
also acrylic flower boxes, ring boxes.....
https://www.containerstore.com/s...
Use leaded leds that can stand up from the board & touch the wall of the enclosure, otherwise it will spread out like a blur on the entire box.
avrcandies wrote:
... & touch the wall of the enclosure,
Same with a light pipe some of which touch to a SMT LED.
I don't have much choice on the enclosure, for this project.
I have been asked can we place an led bright enough to shine the through the plastic enclosure.
Regards
DJ
So what are your constraints? What choices do you have?
As others have said, a clear lid will be fine. A coloured translucent lid will also work. A 'normal' black or grey ABS/polycarbonate box will not work.
Yes - but there a light guide was used to funnel the light out.
I have seen a few products where the entire interior was illuminated - but they were cheap & nasty things. A USB extension lead with clear rubber overmould for example.
Looking around at some typical products I see some have really small holes: My wireless earphones for example have < 1mm diameter hole for Bluetooth Status indication.
Yes that i was is required a simple way to illuminate some light.
Regards
DJ
djoshi wrote:
Yes that i was is
translates as?...
Somehow these don't seem to go together, causing a stack overflow   Yes that i was is required a simple way to illuminate some light.
Sorry typing mistake, best not to use a phone to reply.
Regards
DJ
I will be sending some pictures of what i am trying to do.
Regards
DJ
This is a small paper bin, the circuit will placed in the inside wall. You can see an RED light.
Regards
DJ
To assist people I would ;
1) draw a square on the outside so that people know where to look for the light,
and/or
2) pulse (flash) the LED to indicate operating status. (slow flash = ok, rapid flash = fault)
+1
These are essential questions - can't really help you without answers to those!
Are you looking for an off-the-shelf, standard enclosure; or do you have an existing custom enclosure?
(#14 looks rather like a custom enclosure?)
mikech wrote:
To assist people I would ; 1) draw a square on the outside so that people know where to look for the light, and/or 2) pulse (flash) the LED to indicate operating status. (slow flash = ok, rapid flash = fault)
Yes, i will be adding some type of indication, to get people's attention.
But i would like to know is there any particular LED size or colour that i should use on my PCB to be more effective.
Regards
DJ
This is already an enclosure(paper shreader bin ) that is existing, therefore it can not be changed.
Therefore the only thing that can be changed is the LED size or color, so that example shown can be replicated with a SMD version.
Regards
DJ
Yes. Something bright - high efficiency LEDs are a good start. The human eye is most sensitive to green light, but it depends on the background light around your box; some tests with different colours will help you decide the best option.
Any type with a focussed (narrow angle) beam will be subjectively brighter but not so bright off-axis; again, you'll need to experiment to see what works well. A wider - 5-10mm - light source will be more obvious, which points to the larger leaded types. And if it's wide, you can mount it as close as possible to the casing.
Neil
How did it take 18 messages to mention that???
Use a tight beam so that it will have high contrast with the  plastic--spread out will do no good.  There really won't be an off-axis effect, since you are illuminating and entire square, flat,  area.
Move the led closer to the top, maybe....at the floor probably will be overlooked or hidden.  Note you can stick on a "fresnel/prism type" lens/material on the front to direct the light upward instead of straight out.
https://www.luminitco.com/produc...
http://www.opticalfilters.co.uk/...
Drill a hole slightly smaller than the diameter of a 5mm LED. Glue the LED into the hole and use a flying lead and polarised connector combination to attach to your pcb assembly.
Didn't you think that was essential information to know from the outset?
What about drilling holes - as Ross suggested?
An alternative to fixing the LED in the hole would be to fill the hole with something transparent - and put the LED behind that.
Does it even matter if there's an unfilled hole in this casing?
I'm confused. Back in post #14 there is a picture of an LED showing through your chosen (?) enclosure. Does this not achieve what you want?
I think djoshi was looking for ideas to improve what unfortunately looks a fairly shoddy implementation of an LED indicator.
@djoshi Just stating the obvious here - no offence meant.
