DGI / Data Visualiser not working with XPlained-Pro
4 posts / 0 new
In case anyone in AVR world know about this, and doesn't see:
https://community.atmel.com/forum/dgi-not-working-saml21-xpro
(it's in the ARM section as it's a SAML21 board - but I don't think that should actually be relevant to the DGI / Data Visualiser?)
What about without the "autodetect protocols" setting?  (are you using ADP anyway?)
tried that - no difference.
frown
