[TUT] [C] Using the EEPROM memory in AVR-GCC
359 posts / 0 new
Pages
Thanks you for helpingyes
Every Atmel Datasheet I've seen has code examples on how to access the EEPROM similar to this:
Containing a wait loop looking at the EEPROM busy bit.  No external delay needed.  How did you miss that?
FF = PI > S.E.T
Hi, I've followed the tutorial through and had some success. I'm trying to use the eeprom for counters so I know how often and on what mode the product is used and so at a point I want to increment one in an array of counters.
I tried to follow through on the example code but convert it to uint16_t array. Some save, some don't. Is my eeprom update block statement correct? Can I even do this?
Thanks in advance,
#include
uint16_t  EEMEM NonVolatileString[10];
	uint16_t  SRAMstring[10];
	eeprom_read_block((void*)&SRAMstring, (const void*)&NonVolatileString, 10);
	SRAMstring[1]++;
	eeprom_update_block((const void*)SRAMstring,(void*) NonVolatileString,10);
markah
10 bytes is not the length of a 10 element array of 16bit values. The size is actually 20 bytes (10 lots of 2 bytes). Of course you could just use:
eeprom_read_block((void*)&SRAMstring, (const void*)&NonVolatileString, sizeof(SRAMstring));
This way if you value the [10] dimension the number of bytes read/written will vary.
Well "some" means the first 5 save and the second 5 don't.
Doh!
Not the first time you have come to my rescue! Much appreciated
Mark
markah
I know it's been a long time since you posted this, but is there such library for the Arduino.
Cant you access EEAR, EEDAR, & EECR??...if you can you can easily get the value you need from EEPROM or store it...what more would you need to do?   That assumes you have a specific location you wish to access.
The EEPROM.h library is part of the standard Arduino distribution (and 3rd party cores) for those MCUs that have on-chip EEPROM, which include the common AVRs. Other MCUs, e.g. Arm, that don't have on-chip EEPROM may offer an emulation library using flash.
EEPROM is usually presented as an array, e.g. EEPROM[42] = 7; you can also write this as EEPROM.write(42, 7);
Pages
