Does USB have error correction in it?
11 posts / 0 new
Hi Everyone,
I've been playing around with Paul's Teensy code here:
http://www.pjrc.com/teensy/rawhi...
My question is: Does USB inherently have error correction built into it? I've read that it uses a crc to validate data, and that is has an acknowledgement...
Alan
No, AFAIK there are no means for error correction in USB. However, some services provide error detection and retransmit packets if needed.
No RSTDISBL, no fun!
Yes, it does have error detection.
http://www.beyondlogic.org/usbnu...
says there's a 16 bit CRC for data frames.
Error correction or just error detection?
There is a principal difference between "error corection" as in ECC ("Error Correcting Code") and as in "error detection triggers a resend".
USB has detection of errors via a CRC on each packet; if corruption is detected, the USB controller will drop the packet and the host will have to (automatically) re-send it - unless it is an Isochronous type endpoint. For Isochronous endpoints, corrupt packets are just dropped and not re-sent.
- Dean :twisted:
Thanks everyone.
Dean - I haven't given LUFA a try yet, but I plan to.
I did get Paul's rawhid example down to 1.5k and it allows me to send a 64 byte packet every millisecond for 64,000 bytes per second. I got his code working in C++ Builder 6 which I know is old, but I've developed in it for years so it is familiar.
I really like the send a packet, receive a packet style communication.
Alan
- Dean :twisted:
What applications/device types use Isochronous end points? Keyboards?
Isochronous is for unreliable, time-critical data. In terms of defined USB classes it's pretty much just the USB Video (Webcams, etc.) and Audio classes. Keyboards use the HID USB class, which requires Interrupt type endpoints.
- Dean :twisted:
It does:
"If the data is corrupted while transmitted or received, the CRC check fails. When this happens, the receiver does not generate an ACK, which makes the sender resend the packet."
https://en.wikipedia.org/wiki/USB_(Communications)#Data_packets
I guess the world may still be interested but just to point out that you are replying to a thread that was last alive in 2013, eight years ago ;-)
Moderator.
