How to fix low LED light?
36 posts / 0 new
I've connected the LED diode to a 1K resistor. When I tested it out on a breadboard it worked fine, the LED was very bright. Now, when I soldered it to the board, the LED light is poor. The connection is the same, with no changes. I don't know where is the problem. Everything else works fine, so that means the connection between components is good. Could the problem be in the tin or paste I use? Does anyone have an idea?
Btw, everything is connected to a 5V power supply. I measured voltage in some points on board, and it is about 4,65-4,75V. What else can I do to find an error?
SMarc wrote:
...The connection is the same, with no changes....
If that is the case then the LED will have the same brightness. So, as it is different that means...
1) your resistor is not the value you think it is
2) your LED is different
3) your PCB is not the same as the breadboard not matter what you think.
4) the LED is pulsed, like PWM.
When discussing H/W issues, a clear picture and a schematic will do wonders for us to help you diagnose the problem.
Gook luck
FF = PI > S.E.T
Total votes: 2
Or, if it is connected to a micro's I/O pin, then perhaps the internal pull-up resistor was activated instead of making the pin an output.
I am using the same resistor and the same LED I used on the breadboard.
When discussing H/W issues, a clear picture and a schematic will do wonders for us to help you diagnose the problem. There is a schematic and board picture.
+1
How can I fix that?
well at least 50% of the supplies are not connected.
you should connect all supply connections with decoupling caps.
Write to the pin's Data Direction Register (DDR).  Set that pin as an output.
Personally, I think they're right - a pin set as an input with a weak pullup (like what the AVR does) will glow very dimly as you have them wired up.  I typically turn LEDs on by pulling them low, but that's just me being an olde farte from back in the days when chips had different source/sink current capabilities.
  S.
Edited to add:  And yes, hook up ALL the chip's VCC and GND pins.  The internal connections are not designed to haul all the current everywhere - that's why they have lots and lots of VCC and GND pins!
digitalDan wrote:
+1
But he said that this worked on a breadboard but not on the circuit board so the software must be doing the right thing mustn't it ?
When, Mr. Lawson, was the last time you heard someone say "But I only changed this one thing!" and you believed them?  frown  S.
But the change seems to have been from one set of hardware to another?
There are no changes in the software. I just changed the board, so it has to be a problem with the hardware.
I wired up all supply pins, and nothing has changed.
Does anyone else have an idea of what could it be?
Lift the ends of the LED resistors closest to the chip and simply apply Gnd or Vcc to them and see how brightly they shine (hopefully the LEDs not the resistors!!). This tells you whether it's anything to do with the AVR.
With proper power and ground capacitors, does it still work on the breadboard?
Does it work correctly, i.e. do known inputs give you the desired output?
Did the compiler complain about unintialized variables?
Can you get simpler code to work correctly in both cases?
...and in future, use an IC socket...
Generally on the AVR, when a normally-bright LED appears very dim, it is often because the anode is connected to Vcc (+5 or +3.3) on the prototype and is disconnected from Vcc on the board-under-test.  The LED is being powered through the internal pull-up resistor when the cathode is taken to ground.   Check for a cold solder joint or missing solder connection at the LED's anode.
Lets troubleshoot your h/w:
1) use jumper to connect reset pin to gnd. this will hold micro in reset mode and all port pins are floating.
2) use another jumper from vcc to each port pin with an LED connected, does the led light up bright?
Repeat #2 for each LED, do all the LED's light up ok?
If so, then H/W is ok.
If  not, then check solder connections and that LED polarity is correct, fix and repeat the above 2 steps. check the LED ground connections too.
Write a small test program that:
Sets all the four port pins to outputs. DDRn = 0x0F;
then loop forever lighting one LED at a time for one second, turn off LED, then shift to the next, rinse and repeat.
That should identify any bad connections to port pins.
FF = PI > S.E.T
I just tried that and the LED is bright. So the problem is in the microcontroller?
It works on the breadboard with the same voltage and capacitors. The code works fine, it gives the desired results, just the LED is not bright.
When I connect reset to ground the program won't even recognize the microcontroller.
I tried this code:
    DDRB=0xFF;
	DDRB   |= (1 << PB0);
    while (1)
	    _delay_ms(1000);
		PORTB &= ~(1 << PB0);
		_delay_ms(1000);
		PORTB |=  (1 << PB0);
And the LED is bright. I am really confused. Is there a problem with the sensor? Or is it a code problem? But if it worked on a breadboard it should work now.
Who knows? We can't see your code.
    DDRB=0xFF;
	DDRA=0x00;
	while (1)
		for (uint8_t i=0; i<4; i++)
			if((PINA &(1<<i)) ==0)
				    PORTB |= (1<<i);
				    PORTB &= ~(1<<i);
Here is the code I use.
That's a digital test, but you have analogue (potential divider) inputs connected to PA0-3.
Perhaps your inputs are noisy, so you are seeing noise on the outputs (LEDs) ?
Take a step back - just blink the LEDs to confirm that they are working.
I tried the same code with a switch and it gives the same result-poor LED light.
I tried blinking the led and it worked, the LED is bright. When it doesn't depend on the input it works properly.
I just tried it without integer i- uint8_t i(used to indicate the number of sensors and diodes) and it works well.
    DDRB=0xFF;
	DDRA=0x00;
	while (1)
		if((PINA &(1<<0)) ==0) //I used the first bit insted of i
		        PORTB |= (1<<0);
			PORTB &= ~(1<<0);
Can I somehow change the code to work for other LEDs as well?
		        PORTB |= (1<<0);     <<---- turns the LED on
			PORTB &= ~(1<<0);    <<---- immediately turns it off again!
EDIT
So Jim was right:
So wouldn't you at least:
#define F_CPU 123456UL // put actual CPU speed here
#include <util/delay.h>
    DDRB=0xFF;
	DDRA=0x00;
	while (1)
		if((PINA &(1<<0)) ==0) //I used the first bit instead of i
		    PORTB |= (1<<0);
		    _delay_ms(100);
		    PORTB &= ~(1<<0);
		    _delay_ms(50);
Personally I am not a great fan of the ==0 test so I'd probably go with:
if (!(PINA & (1 << 0)))
or perhaps even:
if (bit_is_clear(PINA, 0))
    DDRB=0xFF;
	DDRA=0x00;
	while (1)
				    PORTB |= (1<<i);
				    PORTB &= ~(1<<i);
It isn't clear to me whether you want the same state of PINA's low nibble reflected on PORTB, or the inverse state.  You can avoid the if statement and the for loop with a simple copy as follows:
while(1) {
    // Copy low nibble of PINA to low nibble of PORTB
    // while preserving the high nibble of PORTB
    PORTB = (PORTB & 0xF0) | (PINA & 0x0F);
Or, if you want the inverse state:
while(1) {
    // Copy low nibble of the inverse of PINA to low nibble of PORTB
    PORTB = (PORTB & 0xF0) | (~(PINA) | 0x0F);
But we're still left with the issue that you're feeding a digital input from an analogue source, which is OK when the input is "definitely high" or "definitely low" - but is going to cause trouble when it's "somewhere between" ...
I guess that somewhere you lost a else in the code so you either set a bit or clear it :)
that you take a bit at the time should work, just not speed optimal, but first it need it to work.
This is a classic example of where an oscilloscope (or a cheap logic analyser)  or a debugger would have shown you the problem immediately.
#IndispensableTools
So apparently this was the problem. I would never assume because it was working on the breadboard. Thank you all for your help! It would take a while before I would remember to look for a bug in the code.
Thanks for feeding back.
Then the code and/or the hardware must have been different.
They key thing about small embedded microcontroller systems like this is that it's not just about hardware, and not just about software - it's all about the two working together.
This is why it's so important to have some decent hardware test equipment - see #33 - as well as software debug facilities.
Locked after spam.
Topic locked
