Level: Raving Lunatic
Posted by Brian Fairchild:
Mon. Feb 24, 2020 - 12:35 PM
For 99% of all cases this design is the right way to start with a '328 design...
And, if using a breadboard, please start neat and tidy and keep your wires short. This is the above circuit, without the reset switch and IO connections to the ISP pins...
#1 Hardware Problem? https://www.avrfreaks.net/forum/...
#5 "If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand."
Tags:
